| | #1 |
| RCC Addict ![]() Join Date: Dec 2006 Location: RENO
| These will not be going on our site because of the fabrication required to install them. After bending multiple tierods for the berg that broke or continued to keep bending, i had some machined out of aluminum. I only have 13 of these left. They will include the 2 required 8mm aluminum spacers for the knuckles and hardware needed to install. Only 11.99 shipped to the US. Paypal to ckrawler@sbcglobal.net Install: Pictures speak a thousand words so i have attached a few shots of my rig. My rig is running some new knuckles we will have out soon, but, the kit works with the included spacers. #1.The knuckles will need to be flipped left to right and re drilled. From the factory tierod hole in the knuckle, the new hole needs to be 5.7mm towards the center of the knuckle. re drill and remove the excess material from the arm. #2. I am using a CKRC r2 servo mount for my berg servo mount. I mounted the servo as far as possible to the center of the rig. The stock berg servo mount will work, but it may need to be ground a bit. #3. (2) Axial bent rod ends will be required for install. #4. Because of varied servo mounting locations, you will need to drill and tap your own drag link hole into the tierod. My set up is running 2 more axial bent rod ends with an axial 33mm drag link. #5. Limited directions! Most berg owners know what it takes to get this mounted and working properly. Some dont. |
| Sponsored Links | |
| | #2 |
| Team Y-Town ![]() Join Date: Oct 2007 Location: Houston
| Paypal sent, Thanks |
| | #3 |
| Damn-I need a chump RT!!! ![]() Join Date: Sep 2007 Location: Lost as hell.....
| | #4 |
| TEAM RCC ![]() Join Date: Jul 2006 Location: Novato
| i have this kit on my Berg and works great |
| | #5 |
| Back in the WATER! ![]() Join Date: Mar 2008 Location: Pacific Ocean
| PP sent, thanks! |
| | #6 |
| ✘ ɹǝʞɔɐʇs ʞɔoɹ ✘ ![]() Join Date: Jun 2008 Location: Wasilla
| paypal sent jake, thanks - tre |
| | #7 |
| Gavyn is my BFFL ![]() Join Date: Feb 2007 Location: hunting pandas
| i need one jake, set one aside for me please |
| | #8 |
| RCC Addict Join Date: Feb 2005 Location: Minneapolis
| 2 sets ordered. |
| | #9 |
| That was fast, all 13 are gone guys. i can get more if there is enough demand. Who else wants one? |
| | #10 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| I'd really like one in delrin...please? Also really want those prototype Delrin Berg Tranmission cases I seen in a Nationals Video... Last edited by binaryterror; 11-11-2008 at 03:44 PM. |
| | #11 |
| Im not sure about the housings. I gave out 6 sets away at nationals and no one got back to me about them. Lets discuss it. The catch is they are wider than the factory berg housing to make them stronger. Because of that your axle tubes would need to have approx 3/16" machined off of each one. It can be done with a grinder, but is it something everyone could do? |
| | #12 |
| Quarry Creeper ![]() Join Date: May 2008 Location: Mansfield, PA
| I would buy some delrin cases in a heartbeat...if they were made right and made strong. I definitely would not mind having to machine my axle tube a bit....and almost everybody knows a machinist or someone that could do it for them. Make them...please |
| | #13 |
| RCC Addict ![]() Join Date: Sep 2005 Location: Behind the torch!
| I agree make the delrin housings |
| | #14 |
| I see your point Jake, though make some delrin tubes shorter for us too then. I'd happily buy new delrin cases and tubes. All Delrin Berg housings and tubes would be pretty slick... |
| | #15 |
| RCC Addict Join Date: Jan 2006 Location: The Amish Ghetto
| i would be interested in that link too. |
| | #16 |
| I did try the tubes. they were way to weak. I was also thinking of making the tubes the correct length for the delrin housing but, have them machined to use axial axle c's instead of them being cut in delrin. If i do this, the housing would come pre clocked and have no adjustment, except at the axle c. |
| | #17 |
| Rock Crawler ![]() Join Date: Dec 2005 Location: Connellsville PA."fayettenam" lol
| i am interested as well, need two |
| | #18 |
| Wishing I was in MOAB ![]() Join Date: Apr 2008 Location: Boise, Idaho
| I'll take one of those tie rods when they are back in stock. Paypal ready! |
| | #19 |
| Quarry Creeper Join Date: Feb 2008 Location: Lagrange
| I want a tie rod too when you get more in stock...p |
| | #20 |
| Rock Crawler ![]() Join Date: Oct 2008 Location: God's country "Alabama"
| yup gonna need 2 of the tie rods and a set of dem dar fancy delrin axle housing everybody yappin about. Paypal ready!! |
| Thread Tools | |
| Display Modes | |
