Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Chassis and Suspension
Thread: * Axial SCX-10 CMS Kit Instructions and pics *
Old 03-15-2009, 01:27 PM   #1
1 man, 2 sons
Unimoger's Avatar
Arrow * Axial SCX-10 CMS Kit Instructions and pics *
Thank you for purchasing the Handbrothers SCX-10 CMS steering kit. We strive to bring you only quality, original American made products.
Starting with a Stock SCX remove the electronics box, steering servo and servo mount.
Remove the left mounting post from the axle housing. The right mount may also be removed for a more scale look
Remove the upper Y-link and axle mount
Remove the 4 3mm set screws and set aside with the old upper links
Using 4 of the supplied link ends assemble the new panhard bar and drag link
Reverse the hardware on the steering knuckles and install the new draglink
Disassemble the original drag link as shown. Using the supplied upper link and the last rod end assemble the new upper link
Install upper link into chassis
Reusing the original mounting screws and 2 of the 3x6mm stainless screws install the new axle bracket then attach the panhard and upper link to axle bracket with the 3x10 mm hardware
Remove shock tower brace trim as shown and reinstall
Using original hardware install servo to new servo mount
Install the new servo mount and attach loose end of the panhard with the last 3x10 mm screw
And just like that, you are all done. Thank you for buying another Quality product from Hand Bros Off Road and MSD.
Unimoger is offline   Reply With Quote
Old 11-08-2009, 11:40 PM   #2
Is it normal for my SCX10 to have the whole truck shift to one side when compressing the whole front end down? I know it sounds confusing but when i push down on the front, it does not go down level. It shifts slightly to the drivers side (front of truck is facing you). Ill post up some pics of what i mean if it sounds all too confusing.
ser3100 is offline   Reply With Quote
Old 11-10-2009, 08:26 PM   #3
Location: Stuck on a Rig in the middle of nowhere Utah.
Any time you mount a brace from the chassis to the axle that is perpendicular to the chassis this will happen ( i.e. panhard or track bar ).
70duncan is offline   Reply With Quote
Old 12-31-2009, 07:53 PM   #4
This is impossible, the pictures are vague and the instructions are ill worded. Anyone else have a tutorial on this?
TNZ Softmouth is offline   Reply With Quote
Old 01-01-2010, 12:15 AM   #5
Team *
62PYRO's Avatar
What part are you having a hard time with?I found the instructions easy to follow.Maybe one of us can help you out.
62PYRO is offline   Reply With Quote
Old 01-01-2010, 04:18 PM   #6
When I install the panhard bar, it restricts front movement entirely, the truck cant physically articulate.
If someone has photos of the system in the truck from a few angles, I can probably figure it out.
Thanks,
Luke
Old 01-01-2010, 06:54 PM   #7
Team *
62PYRO's Avatar
See if these help.If you need others,PM me and I'll do what I can to help you.
Old 01-02-2010, 01:25 AM   #8
Got it goin Pyro, thanks aton buddy. Turns out the idiot I bought the truck from had hacked the chassis so nothing was lining up.
Thanks again
Old 01-02-2010, 01:44 PM   #9
Team *
62PYRO's Avatar
Thanks again
Old 01-10-2010, 02:40 PM   #10
Will this kit work with VP high steer knuckles?
calikingcrawler is online now   Reply With Quote
Old 01-10-2010, 04:27 PM   #11
Team *
62PYRO's Avatar
Several people have used them together.Check out the scx10 section for more info.
Old 01-10-2010, 09:09 PM   #12
rcjunky3's Avatar
any ideas when you guys will have the honcho version
rcjunky3 is offline   Reply With Quote
Old 01-12-2010, 02:24 PM   #13
KevMc's Avatar
Are the links that were used on the Y reused in this kit?
KevMc is offline   Reply With Quote
Old 01-12-2010, 04:30 PM   #14
Team *
62PYRO's Avatar
Yes.
Old 01-12-2010, 08:22 PM   #15
KevMc's Avatar
Originally Posted by 62PYRO View Post
Yes.
They serve as the panhard and the upper link then?
Old 01-13-2010, 04:00 AM   #16
Team *
62PYRO's Avatar
Panhard and drag link.They supply the new upper link.
Old 02-23-2010, 04:59 PM   #17
Ordered mine!
BrianB is offline   Reply With Quote
Old 03-06-2010, 10:52 AM   #18
MSH
Can the upper link be mounted on either side of the chassis?
MSH is offline   Reply With Quote
Old 03-08-2010, 09:12 PM   #19
Chief of Slapaho tribe.
TheSCorpionKing's Avatar
Doubt it. the three link mount is one way only and the servo will probably interfere with the link if mounted on the other side
TheSCorpionKing is offline   Reply With Quote
Old 03-09-2010, 01:05 AM   #20
MSH
I do mean the one i marked in the pic i stole from Pyro.
Not the panhard.
You may edit your posts
