12-12-2012, 12:05 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Virginia
| Titanium Steering and Suspension Links for SCX10 Honcho and Rubicon BMRC 6Al-4V Titanuim Suspension and Steering Linkage Our Ti steering linkage is available for stock and high steer style knuckles. Steering links come with Revo rod ends. Rear suspension links replace stock. The front link kit is a 4-link conversion and comes with a new servo mounting plate made from 6061 aluminum and features the upper link mounts. More info and pictures here |
12-17-2012, 12:54 PM | #2 |
| Re: Titanium Steering and Suspension Links for SCX10 Honcho and Rubicon Ti Steering: |
12-17-2012, 03:19 PM | #3 |
RCC Addict Join Date: Jun 2009 Location: Australia
Hey Matt(think) I just installed the Blue Monkey Wraith steering and upper n lower ti links. Very good . In the new year I'll grab some of these Ti links for my scaler . Sent from my GT-I9300 using Tapatalk 2 |
12-17-2012, 10:21 PM | #4 |
Quarry Creeper Join Date: Apr 2011 Location: Mid TN
Is there a package deal?
12-18-2012, 01:12 PM | #5 |
| Re: Titanium Steering and Suspension Links for SCX10 Honcho and Rubicon |
12-29-2012, 12:46 PM | #6 |
Newbie Join Date: Dec 2012 Location: Weldon Il
Looks great. How do these wear as compared to the axial aluminum links?
12-31-2012, 09:38 AM | #7 |
01-07-2013, 11:41 AM | #8 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
these are nice. future order for sure!
01-15-2013, 11:23 PM | #9 |
| Re: Titanium Steering and Suspension Links for SCX10 Honcho and Rubicon Very nice, I like the whole deal, bent lower links are especially nice and looks like they don't hit the uppers during suspension cycle! What about link clearance with stock shock bumpstops removed? That steering servo plate is sweet too! Looks like 4mm titanium correct? Last edited by Natedog; 01-16-2013 at 12:20 AM. |
01-16-2013, 10:52 AM | #10 |
Rock Crawler Join Date: Nov 2009 Location: Wasilla Alaska
What do you get to all the links and all the steering with stock knuckles on scx10 rubicon?
01-16-2013, 11:58 AM | #11 | |
| Re: Titanium Steering and Suspension Links for SCX10 Honcho and Rubicon Quote:
many thanks! we design everything to work with a stock setup so i'm not sure if there will be interference with various configurations. most custom builders can defeat any issue by using simple spacers, bending the links out of the way of your custom wigits and thneeds, etc. we learned long ago its impossible to make bolt-on products work with every custom build so we make it work with stock and the rest is up to you. HTH. we use 3/16" 6Al-4V (grade 5) certified Ti round stock which is closer to 4.75mm. the servo plate was designed after researching what people DON'T like about the ones currently on the market. we got a lot of really good feedback before we put pencil to paper. | |
01-16-2013, 12:14 PM | #12 | |
we have 2 different lengths on the steering links. one fits stock plastic AND axial aluminum mid-steer knuckles. the other length fits axial aluminum high steer knuckles and most other aftermarket knuckles. | |
01-16-2013, 12:54 PM | #13 | |
01-16-2013, 01:07 PM | #14 | |
i will check. we did all of our testing/picture taking approx. 1 year ago with the delrin steering linkage. the Ti links are exact copies but with more clearance because the material does not have to be so...... fat. are you are curious if the long link hits the axle housing at full lock?????? the answer is no, absolutely not. we test all of our products and i would rather stick a fork in my eye than sell someone a piece of shit . | |
01-16-2013, 03:11 PM | #15 | |
01-16-2013, 04:33 PM | #16 |
01-22-2013, 09:43 AM | #17 | |
OK... this isn't exactly perfect but i hope it answers your question. i don't have low steer knuckles anymore,... these are the high steer; however in this picture the steering link is mounted under of the arms so it should be in about the same place. as you can see from the picture at full lock there is about 5/16" gap. you could turn the wheels a lot more and still have plenty of clearance. | |
01-27-2013, 04:07 PM | #18 | |
01-28-2013, 05:25 PM | #19 | |
Steering pics, didn't measure any steering angles but it is very nice. Truck now turns full circles in about 3 feet diameter. Only bummer is that my draglink is now in front of the servo horn (prolly why I bent the servo horn today) and I have lost some front suspension up travel because the buttonhead screw holding the draglink onto the horn hits the front crossmember during compression. Not sure what to do about that but it crawls great. What does your linkage setup look like with Axial high steer knuckles? EDIT: I'm thinking that your tie-rod goes under the knuckle arms (as you stated above ;) ) and that the draglink goes on top of steering knuckle arm (something I couldn't do with my stock Axial links, because tie-rod would hit the front of axle housing before full steering was achieved.) Last edited by Natedog; 01-28-2013 at 05:44 PM. | |
01-29-2013, 05:49 AM | #20 | |
i have seen customers do all kinds of things. mine is mounted below the knuckle and the draglink is on top. the 3/16" Ti links give you slightly more clearance so you might have more options than the 1/4" aluminum ones that it looks like you are using. | |
Titanium Steering and Suspension Links for SCX10 Honcho and Rubicon - Similar Threads | ||||
Steering/Suspension Aluminum, Titanium, Delrin links. Custom made | Erik D_lux | Chassis and Suspension | 72 | 07-31-2020 05:28 PM |
Secret Agent Titanium Suspension Links for XR10 | Chaotic Crawlers | Chassis and Suspension | 23 | 12-15-2013 09:55 PM |
SCX10 Delrin Suspension and Steering Links | Blue Monkey RC | Chassis and Suspension | 6 | 12-12-2012 12:15 PM |
Chaotic Wraith Titanium Suspension and Steering Links | Chaotic Crawlers | Chassis and Suspension | 9 | 09-01-2012 06:15 PM |
XR10 Titanium Suspension Links | Chaotic Crawlers | Chassis and Suspension | 6 | 06-27-2011 12:11 PM |
