05-25-2014, 07:54 AM | #61 |
Rock Stacker Join Date: May 2008 Location: Taylors
Do you sell full kits like these for the scx10 honcho.
05-27-2014, 07:37 AM | #62 | |
| Re: Losi LCC High clearance Titainium Links Quote:
I will send you a PM also just to make sure you get it. I dont but I could. I just need eye to eye measurements. | |
09-30-2014, 10:07 AM | #63 |
Heads up on this part. These will no longer be made the way the used to be with set screws and Losi rod ends. I am moving to a Revo rod end on the lowers and TRA1942 rod ends on the uppers. Also, these will be able to use my standard sliders and the rears will be made 1/4" longer for the extra wheelbase in the rear to get you to 12.5". |
10-10-2014, 08:16 PM | #64 |
Quarry Creeper Join Date: Oct 2014 Location: Barre
Erik, Just to clarify. For the Night crawler, on your product page if I add all 4 to basket i will be getting the correct combo of diameters? You mention something about 1/8" for "optimum performance" but there seems to be no detail of which is which in the 'add to bag' area. Thanks |
10-13-2014, 07:18 AM | #65 |
Yes, if you add all 4 you will get 3/16" lowers and 1/8" uppers. Unless you custom order from me, all uppers will now be 1/8" TI from now on. |
10-13-2014, 07:20 AM | #66 |
Thanks so much!
10-23-2014, 01:50 PM | #67 |
I guess I'm being thick here - but when installing these new 1/4" longer rears, the rear drive shaft is now too short. What am I missing here?
10-24-2014, 06:26 AM | #68 |
I responded to your email.
06-12-2015, 08:39 PM | #69 | |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
Thx brother | |
06-15-2015, 07:25 AM | #70 |
The LNC driveshafts work great but they can be hard to setup. For this reason, I would suggest getting the standard length lowers from my site and then if you want to move the bias, do it by either rolling out the rod end a touch or cutting down some Jato ends.
06-23-2015, 07:27 PM | #71 |
[QUOTE=Erik D_lux;5245208]The LNC driveshafts work great but they can be hard to setup. For this reason, I would suggest getting the standard length lowers from my site and then if you want to move the bias, do it by either rolling out the rod end a touch or cutting down some Jato ends. What makes it tricky? Do I need to do machine work on the stub shaft to make the set screw line up? I ordered a set.. if it's better for crawling In a sporty style crawler ill make them work Last edited by dasco; 06-23-2015 at 07:31 PM. |
06-24-2015, 07:16 AM | #72 |
The LNC shaft is a dog bone style so it can fall out or bind if there is too much movement either way. You need to have your links and shocks/shock travel setup perfect so this does not happen. Its not impossible, just difficult and time consuming. |
06-24-2015, 07:53 AM | #73 |
Thanks man..if you don't mind send the regular ones and I'll tackle the extension at a later date Sent from my HTC One M9 using Tapatalk |
07-24-2015, 11:10 AM | #74 |
Love me !!! My stack of Dlux stickers is about a 1/4" thick..hehehehehhe...going for a 1/2!!!! Thx again Erik for the awesome customer service and ever better parts �� |
