![]() | #101 |
Pebble Pounder Join Date: Nov 2012 Location: Stoke on trent , England
Everythings here and It's started Couple of Questions : Am i correct in saying it needs a way short servo horn ? Milled one down just now Will the stock wraith upper link mount have to be shaved off ? What's everyone using for hingepins ? Cheers Jack |
![]() | #102 | |
Rock Crawler Join Date: Dec 2011 Location: Virginia
| ![]() Quote:
negative | |
![]() | #103 |
Rock Stacker ![]() Join Date: Mar 2012 Location: Orlando, FL
| ![]() Really STOKED with how this kit runs and crawls! |
![]() | #104 | |
| ![]() Quote:
All sorted now cheers , She'll be running tomorrow . Kit went together very well cheers ![]() Jack. | |
![]() | #105 |
![]() | #106 |
Rock Crawler Join Date: May 2012 Location: Columbus
![]() | #107 |
![]() | #109 |
Pebble Pounder Join Date: May 2012 Location: Eastern Sierras
![]() | #110 | |
Quarry Creeper Join Date: Dec 2012 Location: Seattle
| ![]() Quote:
I haven't cleared any room out for the mip bell yet without knowing. thanks, -Aaron | |
![]() | #111 |
Rock Stacker Join Date: Dec 2009 Location: Calgary, AB, Canada
Well it took me long enough to finish this build but it is finally done. IFS and twin shock trailing arms and a 3600kv short course motor on 3s powering it. ![]() ![]() ![]() And of course, a series of pictures wouldn't be complete without... ![]() After getting all the shocks tuned in and ride heights set, it now jumps like a champion and flys like an arrow. You sir, are a magician. |
![]() | #112 |
Rock Crawler Join Date: Apr 2011 Location: beautiful rainy washington
working on getting my kit together got some parts coming and workin on the body ![]() |
![]() | #113 |
![]() | #114 | |
Pebble Pounder Join Date: Jan 2007 Location: Darwin Australia
| ![]() Quote: ![]() | |
![]() | #115 |
| ![]() it started out as this hard body off some random cheapo rc car ![]() ![]() |
![]() | #116 |
Hey blue monkey i have a question, did i do something wrong my steering is hitting the side of the lower chassis and the steering cross piece is like a 1/16" away from hittint the output on the diff, no room for a driveline or a drive cup, Any HELP would be awesome!!! Thanks Hopefully im just a retard and did somethin wrong i havent taken it back apart to check it out yet ![]() ![]() |
![]() | #117 | |
| ![]() Quote:
the traxxas bellcrank is adjustable so you can gain clearance from the plate if needed and apparently the traxxas unit is not as close to the diff input either. yours looks good but unfortunately you need the adjustability of the traxxas bellcrank. the only other option is if you want me to run some custom plates thru the process that will work with that bellcrank. | |
![]() | #118 |
| ![]() FYI we're making a MIP/locker conversion kit for the EXO diff based on a suggestion and specs provided by frdtrkguy. totally bolt-on. we do all the machine work and provide all the hardware. i'm just waiting on a batch of parts from MIP to complete the first few sets for testing. we're also extremely close to having a working prototype of the SCX10 IFS using the ultra-common traxxas IFS. we chose the traxxas because its width matches the scx10. Last edited by Blue Monkey RC; 10-15-2013 at 02:54 PM. |
![]() | #119 |
| ![]() Awesome news. If you need a tester/hot off the press/pre-order buyer, I'm your huckleberry!
![]() | #120 | |
| ![]() Quote:
Your IFS kit is on point! ![]() | |
Is a IFS Wraith possible? | BigSki | Axial Wraith | 5 | 08-08-2012 08:21 PM |
IFS/Wraith TW | Unfadingpyro | General Scale Talk | 13 | 12-13-2011 11:57 AM |
