Go Back   RCCrawler Forums > Vendors > Vendors Market > Chassis and Suspension
Thread: ToyZuki's angled skid scx10 chassis
Old 08-31-2015, 11:58 PM   #1
Default ToyZuki's angled skid scx10 chassis
ToyZuki's Fabrication is excited to release
a cool new upgrade for the scx10
This is designed to bolt up to all your stock components and therefore should work with all your aftermarket components as well.
These are made from a composite called G10. Supposed to be stronger than carbon fiber.
Here's a list of what has changed from a stock set of rails.
Angled skid to promote fwd movement when high centered
Integrated shock hoops for strength
Integrated servo and servo winch mounts
Raised front rail for more drag link clearance and better approach angle
Added link risers for suspension tuning and allowing you to run a flat skid (working on that too)
Added shock mounting holes to adjust your ride height
For display purposes this was mounted to a box stock rig to show how it works, but I have a few build threads with earlier prototypes showing it with bent rear links, servo mounted to the chassis, ToyZuki motor mount, soon to be released ToyZuki transfer case. I've been beating on these rigs for over a year now with great results!
$60 shipped in the continental U.S. PM me for international shipping quotes
Also still have these available in aluminum. Have had a few requests for steel too. If I get enough interest I will cut a batch in steel, but their 13.5oz in steel. We will have to get a head count and discuss something thinner than .125
ToyZuki is offline   Reply With Quote
Old 09-01-2015, 12:02 AM   #2
Default Re: ToyZuki's angled skid scx10 chassis
Saved
Old 09-01-2015, 12:02 AM   #3
for
Old 09-01-2015, 12:02 AM   #4
later
Old 09-01-2015, 12:08 AM   #5
Liked and subbed.
Sent from my Nexus 5 using Tapatalk
sdmf is offline   Reply With Quote
Old 09-01-2015, 02:25 AM   #6
I think its time to build a new C3!
VMGontheRocks is offline   Reply With Quote
Old 09-01-2015, 03:03 AM   #7
It's always time to build a new rig! I have to build 3 now!
Old 09-01-2015, 05:59 AM   #8
Moderator Rule Breaker
eric113's Avatar
Tick-tock till AZ.
eric113 is offline   Reply With Quote
Old 09-01-2015, 07:45 AM   #9
I'd think in steel you could get away with 14 maybe 16 gauge. I will be watching though.
I'm in the same boat, I have 2 builds going and would like a new C1 before Nats. Not sure how much I'll be able to actually drive there though...
Big Daddy is offline   Reply With Quote
Old 09-01-2015, 09:04 AM   #10
Plexi----------------------1.8oz
Delrin/Alum hybrid------ 2.5oz
G10-----------------------3.6 oz
Aluminum ----------------4.5 oz
steel---------------------13.5 oz
G10 is black, lighter, has the same rigidity if not more than the Aluminum and most of all sexy
Disclaimer: So Toyzuki doesn't get bombarded with requests---Only alum and G10 are currently available, the others were R and D.
hotwheels000 is offline   Reply With Quote
Old 09-01-2015, 12:01 PM   #11
I have a C3 in the works and a C2 I never did a build thread for with the Ally Chassis. The C2 pulled 3rd in Class3 at the 2014 RC4WD Scale Challenge.
doublej is offline   Reply With Quote
Old 09-01-2015, 12:10 PM   #12
Very nice work.I to have some future project this winter.....
One particular rig is a 6x6 tow rig any thoughts on making chassis rails for a 6x6.
rustneversleeps is offline   Reply With Quote
Old 09-01-2015, 05:44 PM   #13
I edited the post on weight. It should have been ounces, not grams.
Old 09-01-2015, 06:06 PM   #14
I have made a few for people but they are very hard to ship. The regular chassis is a 17" long flat package.
Old 09-01-2015, 06:08 PM   #15
I did one out of .125 mild steel and it was over 13oz of sprung weight. I'll make a few more out of thinner material and see what happens.
Old 09-01-2015, 09:39 PM   #16
As always another awesome product ben
idaho is offline   Reply With Quote
Old 09-05-2015, 06:58 AM   #17
Can you show a pic with the tranny installed and how it affects the drive shaft angles? Looks like it would help the front but increase the output angle even more on the rear.
gillbily23 is offline   Reply With Quote
Old 09-07-2015, 09:28 AM   #18
Here's a pic of mine running MIP shafts with the 5mm extended out drive on the trans side. WB is set at 12.3"
yotapower07 is offline   Reply With Quote
Old 09-07-2015, 04:13 PM   #19
Check out the links in the first post. Plenty of pictures of finished rigs!
Thanks for the pic yotapower!
Old 09-09-2015, 05:16 PM   #20
Checked out the carbon ones last weekend at East Vs. West scale comp, they look great - i already have a aluminum one on my class 1 build and it's great.
Pat M is offline   Reply With Quote
You may edit your posts
