Go Back   RCCrawler Forums > Vendors > Vendors Market > Chassis and Suspension
Thread: *** Krazed Builds -> 2.2S un-Stuck Chassis ***
Old 09-30-2016, 12:29 PM   #21
Default Re: *** Krazed Builds -> 2.2S un-Stuck Chassis ***
Originally Posted by Robbob View Post
New Stock just in!
Thanks again for all the support - We greatly apprecaite it!
Anymore on the way? I'm interested when you get them!
Xtacy33 is offline   Reply With Quote
Old 09-30-2016, 12:58 PM   #22
Custom Carbon Fiber
Robbob's Avatar
Yup more coming ...... have a bunch to restock on in the new few weeks.
Robbob is offline   Reply With Quote
Old 10-06-2016, 06:59 AM   #23
Custom Carbon Fiber
Robbob's Avatar
Got a few in stock last night fresh off the machine
Apologize for the delay on stock, we did procure a better supplier for the braces so inventory shouldn't be a problem again.
Old 10-06-2016, 07:09 AM   #24
Great, I'll be taking 1 of those off your hands
Sent from my HTC One_M8 using Tapatalk
Old 10-12-2016, 04:59 PM   #25
New to the crawler scene. Got my son a everest 10 and really liked crawling it around. I have a brushless V-maxx i built from the frame up that's fast as hell but found crawling a lot more fun.
I decided I wanted my own and have learned my lesson about buying a new one then slowing ending up replacing everything. So I'm starting from scratch and like what Krazed Builds is doing to get new people into the hobby.
So I ordered your frame kit a day ago. I have basic rc skills but noticed crawlers r completely different so I've been reading a lot to absorb it all in and I'm looking forward to building it as I learn.
Sent from my SM-G900V using Tapatalk
lonewolf8o is offline   Reply With Quote
Old 10-26-2016, 07:38 PM   #26
Custom Carbon Fiber
Robbob's Avatar
Snuck a few more in on the machine tonight ........
Store stock updated
Old 10-27-2016, 08:58 PM   #27
Custom Carbon Fiber
Robbob's Avatar
Good news for those needing Links - We been able to get setup with another vendor on here that can supply you with them.
Thanks to Dlux for hooking us up and giving drivers a place to get Titanium links for our un-Stuck.
He can do them for AX and AR axles
Old 10-28-2016, 07:50 AM   #28
Wanna get? Gotta want.
Erik D_lux's Avatar
Thanks for the opportunity to make them Robbob!
Here is a direct link for those who need them.
https://dluxfab.ecwid.com/#!/Krazed-...nks/p/73959391
Erik D_lux is offline   Reply With Quote
Old 10-28-2016, 08:20 AM   #29
Just ordered a full lower set. Didn't see a area to mention if its for AX or AR axles. Do I need to tell you? Is there a difference? I'm using your modified bearing axles I bought from u a week ago.
Sent from S5 using Tapatalk
Old 11-04-2016, 06:50 AM   #30
Got my Dlux lower links in. As far as my question above I guess it made no difference since I was never asked. Is the only difference with AR and AX axles is the diff housing being off centered?
With my lower links being of a known size to you both Robbob and Eric D Lux , can you guys tell me what length driveshafts front and back I need? I noticed for example Locked Up RC has shafts that cover a certain size range Driveshafts
Or do I have to wait till I figure exactly what size upper links / pinion angle I'm going to run and measure with it all together?
Edit to add
When you say "This is my link length, Not my eye to eye length with Traxxas ends" is that end to end including threads marked "A" or is it "B" in that diagram here?-> http://www.vanquishproducts.com/titanium-links-1/
I plan on using your "straight 115mm with 75mm on the front" for a general starting point for my upper links and want to know what your sizing points go by.
Thanks
Old 11-04-2016, 07:05 AM   #31
Custom Carbon Fiber
Robbob's Avatar
If youre planning on using an SDI shaft that is more precise then I would probably wait till you get your upper links on.
If youre gonna use one of the slipper/plastic ones from like a Losi or Wraith then those can be adjusted easily.
My rigs torn down at the moment but I can take some measurements off my shafts and let you know what I have. My rear is a Losi shaft from an LCC and my front is a MIP.
Old 11-04-2016, 09:13 AM   #32
By "SDI shafts" you mean these guys?
PROPELLER SHAFT - Scale Designs International
Had to google that and that was the most likely thing I saw.
If I understand right they sell them over sized in the length and you cut them down to what you need? If that's the case you don't have to measure yours but thanks for offering. I'll order two and just cut them down when I'm at that stage in the build.
Any websites I can buy them from here in the USA?
Thanks for the fast replay
Old 11-04-2016, 09:45 AM   #33
Custom Carbon Fiber
Robbob's Avatar
Yup those are them - Ive seen many use them since they are smaller and just as durable.
Old 12-04-2016, 04:47 PM   #34
Can't tell what side of the lower links get connected to the center piece or what ones are front and back. Above photo is the way I'm thinking it goes???
Sent from my S7 using Tapatalk
Old 12-04-2016, 07:40 PM   #35
Custom Carbon Fiber
Robbob's Avatar
Old 01-30-2017, 09:11 PM   #36
Custom Carbon Fiber
Robbob's Avatar
Just off the machine ....... Axial kits in stock!
Old 02-02-2017, 11:51 AM   #37
Curiously, what's the length of these links eye to eye with Revo links? Especially the front. Any info is greatly appreciated.
Mudsy is offline   Reply With Quote
Old 02-02-2017, 12:14 PM   #38
Custom Carbon Fiber
Robbob's Avatar
Ill measure tonight
Old 02-02-2017, 12:23 PM   #39
That'll be awesome. Thanks.
Old 02-03-2017, 05:52 PM   #40
In the bent position, with imaginary line drawn straight between eye's, the single bend is ~115mm eye to eye, and the double bend is ~112 eye to eye. If you straightened them they are both ~ 105mm end to end, including ~10mm of thread each end. Hope that is what you were looking for.
Sent from my GT-P5210 using Tapatalk
icculus is offline   Reply With Quote
*** Krazed Builds -> 2.2S un-Stuck Chassis *** - Similar Threads
Krazed Builds un-Stuck line into 2.2S Robbob Axial AX-10 Scorpion 122 08-09-2017 03:00 PM
Krazed Builds Vacation 9/12-9/19 Robbob Vendors Market 3 09-26-2016 11:55 AM
Krazed Builds Joker chassis SK Car Robbob Non Crawler RC's 3 12-18-2015 05:27 AM
Krazed Builds - AX Axle Krazed Plates Robbob Axles, Trannys, T-case 8 10-28-2015 07:13 PM
You may edit your posts
