09-30-2016, 12:29 PM | #21 |
Pebble Pounder Join Date: May 2016 Location: Warwick
| Re: *** Krazed Builds -> 2.2S un-Stuck Chassis *** |
09-30-2016, 12:58 PM | #22 |
10-06-2016, 06:59 AM | #23 |
Got a few in stock last night fresh off the machine Apologize for the delay on stock, we did procure a better supplier for the braces so inventory shouldn't be a problem again. |
10-06-2016, 07:09 AM | #24 |
Great, I'll be taking 1 of those off your hands Sent from my HTC One_M8 using Tapatalk |
10-12-2016, 04:59 PM | #25 |
Pebble Pounder Join Date: Apr 2016 Location: Long Island ny :(
New to the crawler scene. Got my son a everest 10 and really liked crawling it around. I have a brushless V-maxx i built from the frame up that's fast as hell but found crawling a lot more fun. I decided I wanted my own and have learned my lesson about buying a new one then slowing ending up replacing everything. So I'm starting from scratch and like what Krazed Builds is doing to get new people into the hobby. So I ordered your frame kit a day ago. I have basic rc skills but noticed crawlers r completely different so I've been reading a lot to absorb it all in and I'm looking forward to building it as I learn. Sent from my SM-G900V using Tapatalk |
10-26-2016, 07:38 PM | #26 |
Snuck a few more in on the machine tonight ........ Store stock updated |
10-27-2016, 08:58 PM | #27 |
Good news for those needing Links - We been able to get setup with another vendor on here that can supply you with them. Thanks to Dlux for hooking us up and giving drivers a place to get Titanium links for our un-Stuck. He can do them for AX and AR axles |
10-28-2016, 07:50 AM | #28 |
Thanks for the opportunity to make them Robbob! Here is a direct link for those who need them. https://dluxfab.ecwid.com/#!/Krazed-...nks/p/73959391 |
10-28-2016, 08:20 AM | #29 | |
| Re: *** Krazed Builds -> 2.2S un-Stuck Chassis *** Quote:
Sent from S5 using Tapatalk Last edited by lonewolf8o; 10-28-2016 at 04:54 PM. | |
11-04-2016, 06:50 AM | #30 |
Got my Dlux lower links in. As far as my question above I guess it made no difference since I was never asked. Is the only difference with AR and AX axles is the diff housing being off centered? With my lower links being of a known size to you both Robbob and Eric D Lux , can you guys tell me what length driveshafts front and back I need? I noticed for example Locked Up RC has shafts that cover a certain size range Driveshafts Or do I have to wait till I figure exactly what size upper links / pinion angle I'm going to run and measure with it all together? Edit to add When you say "This is my link length, Not my eye to eye length with Traxxas ends" is that end to end including threads marked "A" or is it "B" in that diagram here?-> http://www.vanquishproducts.com/titanium-links-1/ I plan on using your "straight 115mm with 75mm on the front" for a general starting point for my upper links and want to know what your sizing points go by. Thanks Last edited by lonewolf8o; 11-04-2016 at 07:07 AM. |
11-04-2016, 07:05 AM | #31 | |
If youre gonna use one of the slipper/plastic ones from like a Losi or Wraith then those can be adjusted easily. My rigs torn down at the moment but I can take some measurements off my shafts and let you know what I have. My rear is a Losi shaft from an LCC and my front is a MIP. Last edited by Robbob; 11-04-2016 at 07:55 AM. | |
11-04-2016, 09:13 AM | #32 | |
PROPELLER SHAFT - Scale Designs International Had to google that and that was the most likely thing I saw. If I understand right they sell them over sized in the length and you cut them down to what you need? If that's the case you don't have to measure yours but thanks for offering. I'll order two and just cut them down when I'm at that stage in the build. Any websites I can buy them from here in the USA? Thanks for the fast replay | |
11-04-2016, 09:45 AM | #33 | |
12-04-2016, 04:47 PM | #34 |
| Re: *** Krazed Builds -> 2.2S un-Stuck Chassis *** Can't tell what side of the lower links get connected to the center piece or what ones are front and back. Above photo is the way I'm thinking it goes??? Sent from my S7 using Tapatalk |
12-04-2016, 07:40 PM | #35 |
01-30-2017, 09:11 PM | #36 |
Just off the machine ....... Axial kits in stock!
02-02-2017, 11:51 AM | #37 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
02-02-2017, 12:14 PM | #38 |
02-02-2017, 12:23 PM | #39 |
That'll be awesome. Thanks.
02-03-2017, 05:52 PM | #40 |
Newbie Join Date: Oct 2015 Location: US
| Re: *** Krazed Builds -> 2.2S un-Stuck Chassis *** In the bent position, with imaginary line drawn straight between eye's, the single bend is ~115mm eye to eye, and the double bend is ~112 eye to eye. If you straightened them they are both ~ 105mm end to end, including ~10mm of thread each end. Hope that is what you were looking for. Sent from my GT-P5210 using Tapatalk |
*** Krazed Builds -> 2.2S un-Stuck Chassis *** - Similar Threads | ||||
Krazed Builds un-Stuck line into 2.2S | Robbob | Axial AX-10 Scorpion | 122 | 08-09-2017 03:00 PM |
Krazed Builds Vacation 9/12-9/19 | Robbob | Vendors Market | 3 | 09-26-2016 11:55 AM |
Krazed Builds Joker chassis SK Car | Robbob | Non Crawler RC's | 3 | 12-18-2015 05:27 AM |
Krazed Builds - AX Axle Krazed Plates | Robbob | Axles, Trannys, T-case | 8 | 10-28-2015 07:13 PM |
