07-31-2019, 10:33 AM | #1 |
Rock Stacker Join Date: Jan 2014 Location: Rockford MI
| Team Associated CR12 Performance Package
This bolt on Package for the CR12 is designed to improve steering, ground clearance, center or gravity, and overall drivability. The performance package is made from mostly 3D printed parts which are black PETG. The kit includes a front servo mount which also serves as the mount for the track bar as well as an open place for a servo winch. The track bar which is used for this upgrade is one of the top links from the front suspension. Adding a track bar to the front suspension greatly improves the steering faults which the truck struggles with from the factory. Moving back a low center of gravity battery tray will keep the weight down low. The high clearance transmission kit includes link mounts, the transmission itself, and an aluminum motor mount plate. The transmission uses the factory gears so it will also work with the GPM metal transmission gears. The rear receiver box helps keep the dirt off of your electronics and also has a drain hole in case you encounter some water on the trail. You can purchase this and many other CR12 upgrades on my website. Here is the link to the performance package: https://www.extremerc4x4.com/performace-package Here is the installation video: https://youtu.be/cev10O_1kwg Sent from my iPhone using Tapatalk |
07-23-2020, 07:21 PM | #2 |
Newbie Join Date: Jul 2020 Location: Green Bay
| Re: Team Associated CR12 Performance Package
Are these parts still available primarily the metal trans gears?
Team Associated CR12 Performance Package - Similar Threads | ||||
Team Associated CR12 Build | EXTREME RC 4X4 | General Scale Talk | 88 | 09-10-2021 01:31 PM |
Team Associated CR12 | modulator415 | Newbie General | 2 | 08-18-2019 03:03 PM |
Team Associated cr12 | phillysteak33 | Newbie General | 10 | 10-06-2018 06:07 AM |
Team Associated CR12 Trail Series | cul8tr | General Crawlers | 9 | 05-24-2018 06:25 PM |
Team Associated CR12??? | mjderstine | Scale Comp Rules | 3 | 05-22-2018 09:06 AM |
