06-27-2007, 07:10 AM | #21 | |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
contact ace, the last i talked to him, he said he had some 1" widers or 3/4" wideners. also i think cpe has some too. | |
06-27-2007, 03:11 PM | #22 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
I don't know why nobody makes them because you can find 1" wide 8mm 23mm adaptors for truggies no problems but none for the 17mm wheels. You would think that Maximizer would make some for there wheels?
06-27-2007, 10:31 PM | #23 |
RCC Addict Join Date: Jul 2006 Location: barstow
yeah i talked to cpe and he does not make and will not make what is needed for the axial wheel. i can understand that he said it is not cost effective as i am only 1 guy asking for these. i really dont want to stack adapter on top of adapter you will run into problems in time with wear and creating a wobble by doing this. i will try to get a pic up of an axial wheel and you can see why this is a problem.
06-27-2007, 11:11 PM | #24 | |
06-28-2007, 10:30 AM | #25 |
Has anyone contacted Integy, they already make them for 23mm/8mm and stock clod axles It would be pretty easy for them to make a 17mm one. I would think it would be useful to many of the Truggy guys also, and they seem to be really getting into the crawling stuff, seems most people are using CVD's on the clods so it only makes sense to make a 8mm adaptor.
06-28-2007, 12:11 PM | #26 | |
I wanna be Dave Join Date: Nov 2005 Location: Here
http://integy.automated-shops.com/cg...45107238321.0c | |
06-28-2007, 12:43 PM | #27 |
if you look at the picture you will see that the 12mm hex is for use on the stock clod axle i am also not sure if the hub itself is 1 inch long when i emailed them before they said they didnt have anything for a ttr axle and nothing that was 1 inch
06-28-2007, 01:30 PM | #28 | |
Yes....that is an adapter that has to be stacked....RC4WD has them too...I am looking for something that attaches directly to the axle via a pin... and not stack hexes. like this only 17mm Quote: Last edited by clarkrw3; 06-28-2007 at 01:33 PM. | |
07-17-2007, 10:11 AM | #29 |
update please on the bearings you were having made do you have any yet and if so did they fix the problem with the ttr axle?
07-17-2007, 10:27 AM | #30 | |
Yes they fix the problem... There is no longer a Problem with them. | |
07-17-2007, 12:51 PM | #31 |
ok thanks for the reply just wondering
08-22-2007, 08:23 PM | #32 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
