Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Chassis and Suspension
Thread: Shocks Back in Stock
Old 07-12-2007, 02:28 PM   #1
Default Shocks Back in Stock
I have every shock but 60mm in stock... I'll have the 60mm in a 7-10 days..
$37.50 for all Four...
at
www.jpcustomrcs.com
Old 07-12-2007, 02:44 PM   #2
Any chance I could get a pic of the 80mm shock and 60mm shock side x side? I bought the 80mm ones from you awhile ago, and now Im thinking of putting the 60mm on my one truck that has the 80mm on it currently, but I dont know if I want to sacrifice 20mm of suspension movement. would it be a 20mm difference in compression, or will it be more like ~10mm or so with the actual shock body taking up some of the difference in length? Ideally a 70mm shock is probably what I really need, but I cant seem to find them anywhere.
Mirage is offline   Reply With Quote
Old 07-12-2007, 02:46 PM   #3
did you ever find out about those shock cap kits with the upper ball mount?
Thorsteenster is offline   Reply With Quote
Old 07-12-2007, 02:51 PM   #4
Do those have ball ends on both side?
PaulEZK is offline   Reply With Quote
Old 07-12-2007, 04:20 PM   #5
Nothing new on the Rebuild kits yet. Nope these shock only have ball ends on the bottom. They are just like Max Shocks.
Old 07-12-2007, 07:25 PM   #6
You can use some Fuel line tubing to shorten the shocks from the inside. you can make those 80mm into 70mm. If it doesn't work you can change it back...
Old 07-12-2007, 07:30 PM   #7
DUH, some times I swear Im borderline retarded!!!! Thanks, I cant believe I hadn't thought about that, but at the same time, it would be easier to just swap the shocks out and use them on another truck instead. Once I finish up the build I will give that a shot. Thanks again, I just can't believe I didn't think of such a simple solution,
I too am interested in that shock cap upgrade, if in fact it has everything needed to make a ball end in the shock cap. Keep us all posted
Old 07-12-2007, 07:45 PM   #8
you ought to see if you can get the upper ball mount standard.
Old 07-12-2007, 07:46 PM   #9
Thats what I've been working on.
You may edit your posts
