Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Chit Chat
Thread: Axle Truss question
Old 03-07-2008, 09:14 AM   #1
Lankenstein's Avatar
Default Axle Truss question
I have seen a bunch of rigs with just the axle truss in the rear, same with 1:1 vehicles. Is it not common to have an axle truss on the front axle?
I have searched and have not seen anything on it.
Any help would be appreciated so I can decide if I want to put both on my scale truggy.
Thanks.
Lankenstein is offline   Reply With Quote
Old 03-07-2008, 09:18 AM   #2
~The Scale Shop~
STANG KILLA SS's Avatar
was reading crawl this morning and the 1:1 bombshell betty has a truss on the front......
im not quite sure what your asking.
Old 03-07-2008, 09:24 AM   #3
OK thanks.
Im just asking if its common for 1:1 rigs to have an axle truss on the front. Most of them only have them on the rear. Guess I just put them both on and see how it looks
Old 03-07-2008, 09:41 AM   #4
~The Scale Shop~
i take it youll be doing frame mounted steering then?
cause i dont think there room for the truss and the servo.......
Old 03-07-2008, 09:52 AM   #5
yes, the servo will be mounted on the frame.
Old 03-07-2008, 10:28 AM   #6
I'm Dracula, Bitch.
JeremyH's Avatar
Well, since a crawler (both small and larger) spends quite a bit of its time climbing, that means that most of the weight (and therefore stress) is put on the rear axle. A lot of times the tubes will flex which is what causes the axle shaft breakage. You will sometimes find front axle trusses on crawlers...when they are trying to compensate for a weak front housing. You will generally find them on desert race trucks...because, well, I think the reason is obvious.....JUMPS!
JeremyH is online now   Reply With Quote
Old 03-07-2008, 10:32 AM   #7
I have them on the front and rear of my 2.2 scaler, simply because they make for nice spots for a 4 link without a plate on the front axle.
BlueMonster is offline   Reply With Quote
Old 03-07-2008, 10:35 AM   #8
Thanks for the input guys. I appreciate it.
BlueMonster, do you by chance have a pic of what yours looks like with both truss' ? That is why I wanted both of them on there, so that the link geometry is the same.
Old 03-07-2008, 10:50 AM   #9
Old 03-07-2008, 10:52 AM   #10
Thanks man....that looks good
Old 03-07-2008, 10:57 AM   #11
Thanks, that's Big Rhonda.
