So that's what you did to it? WOW that's awesome! Not really....... |
It's all about the A-Team! IMO, the white body looks much better. Do you still have the Airtroniks XL 2P? My sister used to have one, but it sucked so much that now she has a Futaba Magnum. But, the old one sure is ghetto! |
Did i start off on the wrong foot here?? What is the bad part of the new look?? I didnt paint that body, but I thought it would be easiest to match paint and make it look like a statium truck... What I did today: Repainted the chassis, finished it off with clear coat. Painted the springs, finished with clear coat to hold it on the spring. Modified another Body I had lying around, this one is for the REALLY hot days, for cooling. |
Sorry but that looks jacked up now, bodys should never be raised up higher then needed for tire clearance. And even then, they should be trimmed before raised. RC body lift kits are unsafe, it can lead to mental damage. |
Something dont look right on that suspension. The left arm looks out of whack. And it looks like its drooped out FULLY, like you tried to "lift" the truck. |
I setup this suspension so that it has a good rebound and stay pretty low to the ground without bottoming out after a 2ft. drop. It feals to be a 70w shock oil. |
Forbidden You don't have permission to access /54/1/79/84/398917984DuYjDV_ph.jpg on this server. awww i dont even want to see porn im not in skool so wuts up with that :flipoff: :lol: :roll: |
