Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Chit Chat
Thread: What Program?
Old 08-31-2008, 01:17 PM   #1
Default What Program?
Any sugestions on a FREE program to use to design stuff like a tube chassi or plate chassi?
88toyota88 is offline   Reply With Quote
Old 08-31-2008, 01:23 PM   #2
06 Super National Champ
JasonInAugusta's Avatar
www.emachineshop.com has software available.
You can even have them make the parts.
JasonInAugusta is offline   Reply With Quote
Old 08-31-2008, 01:26 PM   #3
Thanks, im going to attempt to make my own tube chassi. and if i suck as much as i think i will i will just buy one.
Old 08-31-2008, 02:49 PM   #4
Team *
62PYRO's Avatar
I don't think you will find too much that will let you do 3d work for a tube chassis.Even if you can find one,it would take alot of experience to be able to do it.Good luck.
Pat
62PYRO is offline   Reply With Quote
Old 08-31-2008, 04:57 PM   #5
I did a couple drawings on paper but dont really like them. 1-I changed the position of where the shocks mount (same design as the new team sinastir tube chassis), 1-Other tube chassis that doesnt look good to me and 1 plate chassi. And on the one that says TG on the middle, i might put the front shock mounts below the tube instead of on top.
Feel free to tell me what you think. Dont hold back.
Old 08-31-2008, 05:22 PM   #6
Team *
62PYRO's Avatar
If you're just wanting to do 2d drawings,try emachineshop or maybe google sketchup.
Old 08-31-2008, 05:23 PM   #7
TEAM MODERATOR
Reflection's Avatar
MS Paint is what I used to do the drawings for my chassis.....
Reflection is offline   Reply With Quote
Old 09-01-2008, 12:29 PM   #8
Thanks. Anything i should change on the drawings Or just buy one already made?
Old 09-01-2008, 12:50 PM   #9
Your first chassis drawing looking just like our X-79....
Sinastir is offline   Reply With Quote
Old 09-01-2008, 01:05 PM   #10
i have a cad program from "expert software" named "quick and easy cad" that i bought from walmart from there electronics dept where you would buy the cpu games and software that are 9.88 each off the top of the rack....here's a couple of pictures i made up for my tuber....
i like this cad program cause you can click on any line drawn and move either end point to make it longer or shorter or move the whole line....it has a built in guide in the program explaining each fuction and how to do it..................bob
bob1961 is online now   Reply With Quote
Old 09-01-2008, 01:38 PM   #11
Its suppost to, but i changed where the shocks mount on the drawing. ill probably end up using the second tube chassis.
Old 09-01-2008, 01:44 PM   #12
Thanks, ill have to go check it out.
Old 09-01-2008, 02:05 PM   #13
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Designing a tube frame (for an RC Car) in CAD is pretty pointless. It takes a lot of hours to do properly and the only thing you gain is suspension modeling capabilities and that is only if you have good software.
In short, don't waste your time. Also emachine shop won't do tuber type stuff.
For about $10,000 you can get Solidworks though.....
Harley is online now   Reply With Quote
Old 09-01-2008, 02:17 PM   #14
$10,000? HAHAHA! never in my life would i spend 10,000 on a computer program.
Old 09-01-2008, 02:37 PM   #15
You would when you have the training and experience to use and and make a living off it. ;)
As an added bonus, that $10,000 can be written off as a business expense.
Old 09-01-2008, 03:21 PM   #16
True, but im 17 and i doubt my parents would buy it as a business expense
Old 09-01-2008, 03:24 PM   #17
This sucks. I made a design on eMachineShop and i cant do anything with it. I cant save it as the right file type :(
Old 09-01-2008, 07:56 PM   #18
Throwing Grenades
Harley's Avatar
That is not true. You can export the line drawings from emachine shop to DXF. I have done it many many times.
Old 09-01-2008, 10:13 PM   #19
Untitled.DXF:
Invalid File
Old 09-02-2008, 10:39 AM   #20
Throwing Grenades
Harley's Avatar
Can't tell you what you are doing wrong with that vauge of a description. The problem is mostly likely you, may be trying to open the dxf with a program that is unable to open it.
Hard to say, but I have never had a single issue doing it.
