Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Chit Chat
Thread: How Fast is Your Connection???
Old 11-01-2008, 01:33 AM   #1
Default How Fast is Your Connection???
was just wondering what people are getting in general for their internet connection.
You can test here
http://reviews.cnet.com/internet-speed-test/
THIS IS WITH VERIZONS "AIR CARD"
I THOUGHT IT WAS PRETTY DARN FAST CONSIDERING
THIS IS BASICALY A CELL PHONE CONNECTION.
jc052685 is offline   Reply With Quote
Old 11-01-2008, 02:00 AM   #2
hardhead's Avatar
Faster providers
28.8 KbpsClick the image to open in full size. Dial-up 28.8k
33.6 KbpsClick the image to open in full size. Dial-up 33.6k
53.3 KbpsClick the image to open in full size. Dial-up 56k
384.0 KbpsClick the image to open in full size. DSL/Cable 384k
768.0 KbpsClick the image to open in full size. DSL/Cable 768k
1500.0 KbpsClick the image to open in full size. Cable/DSL 1.5Mbps
1544.0 KbpsClick the image to open in full size. Full T1 1.544Mbps
2779.3 Kbps - YouClick the image to open in full size. 2779.3 kbps
3000.0 KbpsClick the image to open in full size. N x T1 3.0Mbps Bandwidth.com
6000.0 KbpsClick the image to open in full size. T3 6.0Mbps Bandwidth.com
15000.0 KbpsClick the image to open in full size. T3 15Mbps Bandwidth.com
30000.0 KbpsClick the image to open in full size. T3 30Mbps Bandwidth.com
hardhead is offline   Reply With Quote
Old 11-01-2008, 02:37 AM   #3
Not bad for being in the woods - 920kbps
2JSC is offline   Reply With Quote
Old 11-01-2008, 03:06 AM   #4
Sorry to ruin your speedtest results, but those are not even close to accurate (think about server loads etc). The easy way to test your connection speed is to download some big archive, like linux distribution from a known fast server.
Anyway I tried your test and it gave me 570Kbps (of course, I'm from "wrong" country and so on. These tests should always be done at least from the same country, preferably from a server nearby).
Then downloaded a linux distribution from a known Finnish server (not LAN) and the speed was steady at 1,6MB/s (which is just about what this DSL-line will be up to).
tomik is offline   Reply With Quote
Old 11-01-2008, 05:22 AM   #5
Connection speedConnection typeFaster providers
3679 Kbps - YouClick the image to open in full size. 3679 kbps
P47TBolt is offline   Reply With Quote
Old 11-01-2008, 07:11 AM   #6
I'm Dracula, Bitch.
JeremyH's Avatar
28.8 Kbps Dial-up 28.8k
33.6 Kbps Dial-up 33.6k
53.3 Kbps Dial-up 56k
384.0 Kbps DSL/Cable 384k
768.0 Kbps DSL/Cable 768k
1500.0 Kbps Cable/DSL 1.5Mbps
1544.0 Kbps Full T1 1.544Mbps
3000.0 Kbps N x T1 3.0Mbps
3784.8 Kbps - You 3784.8 kbps
6000.0 Kbps T3 6.0Mbps
15000.0 Kbps T3 15Mbps
30000.0 Kbps T3 30Mbps
JeremyH is online now   Reply With Quote
Old 11-01-2008, 09:09 AM   #7
Connection speed Connection type Faster providers
28.8 Kbps Click the image to open in full size. Dial-up 28.8k
33.6 Kbps Click the image to open in full size. Dial-up 33.6k
53.3 Kbps Click the image to open in full size. Dial-up 56k
384.0 Kbps Click the image to open in full size. DSL/Cable 384k
768.0 Kbps Click the image to open in full size. DSL/Cable 768k
1500.0 Kbps Click the image to open in full size. Cable/DSL 1.5Mbps
1544.0 Kbps Click the image to open in full size. Full T1 1.544Mbps
3000.0 Kbps Click the image to open in full size. N x T1 3.0Mbps
6000.0 Kbps Click the image to open in full size. T3 6.0Mbps
9251.7 Kbps - You Click the image to open in full size. 9251.7 kbps
15000.0 Kbps Click the image to open in full size. T3 15Mbps Bandwidth.com
30000.0 Kbps Click the image to open in full size. T3 30Mbps Bandwidth.com
ClodMonster is offline   Reply With Quote
Old 11-01-2008, 12:23 PM   #8
offlander1's Avatar
16320 Kbps - You Click the image to open in full size. 16320 kbps
offlander1 is offline   Reply With Quote
Old 11-01-2008, 02:08 PM   #9
RIP Buster
badger's Avatar
You can test here
That test isn't even close to accurate.
badger is offline   Reply With Quote
Old 11-01-2008, 08:41 PM   #10
1/6 Willys Extreme Scaler
reddevildemo's Avatar
Newb question here. What does 56 mbps mean?
reddevildemo is offline   Reply With Quote
Old 11-01-2008, 08:53 PM   #11
it can either mean megabits or megabytes per second.
kurt is offline   Reply With Quote
Old 11-01-2008, 10:16 PM   #12
1301 Kbps - You Click the image to open in full size. 1301 kbps
1500.0 Kbps Click the image to open in full size. Cable/DSL 1.5Mbps Find ISP
1544.0 Kbps Click the image to open in full size. Full T1 1.544Mbps Covad
3000.0 Kbps Click the image to open in full size. N x T1 3.0Mbps Bandwidth.com
6000.0 Kbps Click the image to open in full size. T3 6.0Mbps Bandwidth.com
not to shabby...i guess
Kranberry is offline   Reply With Quote
Old 11-01-2008, 11:09 PM   #13
RIP Buster
badger's Avatar
That means megabits per second, and that is fast.
Megabits (lowercase b - Mbps) are used with anything transfered over a network or data transfer rates, megabytes (upper case B - MB) refers to storage size or file size.
Old 11-02-2008, 11:03 AM   #14
4197.5 Kbps - You Click the image to open in full size. 4197.5 kbps
NOt too bad.
Badger, do you have a more accurate test?
O.C.D. is offline   Reply With Quote
Old 11-02-2008, 11:42 AM   #15
I'm Dracula, Bitch.
JeremyH's Avatar
I usually test mine here:
http://speakeasy.net/speedtest/
It currently gives me these results:
Download Speed: 5273 kbps (659.1 KB/sec transfer rate)
Upload Speed: 660 kbps (82.5 KB/sec transfer rate)
Old 11-02-2008, 12:11 PM   #16
RIP Buster
badger's Avatar
[/B]
I like this one. http://www.speedtest.net/
But even this test is more accurate only up to a certain speed. But for your typical home connection it should be fine.
Here is a test I did a couple days ago when I got my new home connection.
Old 11-02-2008, 01:31 PM   #17
Doesn't seem too bad.
Edit: Consistent test results eh?
Download Speed: 15034 kbps (1879.3 KB/sec transfer rate)
Upload Speed: 2317 kbps (289.6 KB/sec transfer rate)
-from speakeasy
2771.7 Kbps (upload I assume? Just says connection speed)
-from CNET
chrisjlittle is offline   Reply With Quote
Old 11-06-2008, 08:06 PM   #18
2623.8 kps
crawldad91 is offline   Reply With Quote
Old 11-07-2008, 01:13 AM   #19
I hate my new router, drops off about 20% of my throughput...
Trikster is offline   Reply With Quote
Old 11-07-2008, 03:30 AM   #20
& from Speakeasy:
Download Speed: 4813 kbps (601.6 KB/sec transfer rate)
Upload Speed: 491 kbps (61.4 KB/sec transfer rate)
tubed-n-lubed is offline   Reply With Quote
