12-26-2005, 08:51 PM | #1 |
Newbie Join Date: May 2005 Location: Niagara
| Are there any manual trannys??
is the semi truck tamiya tranny 3sp auto or manual?? is there any other manual tranny in the rc world that would fit a 1/10 scale vehicle?? |
12-26-2005, 10:53 PM | #2 |
Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
semi truck is manual i suppose. but its not like you have to shift it. you choose a gear for what you are doing and drive. But im sure you can shift on the fly for that scale feeling. the only problem is building a transfer case for it.
01-03-2006, 10:57 AM | #3 |
Newbie Join Date: Jan 2006 Location: Lenexa
Does anyone know of any manual shifted transmissions? I'm looking for a multi speed gearbox although I've had little luck finding anything other than the Tamiya semi 3 speed and the E-maxx tranny. at first, I wanted to use an E-maxx tranny although everybody has said that it has too much slop for a crawler. I've never personally used or seen one. I've only owned nitro's to this point. I'm excited to build my first electric. Tamiya also makes a planetary gear box that does ratios from 4:1 to 400:1. Does anyone have any experience in this field? Last edited by RhinoSS; 01-03-2006 at 11:01 AM. |
01-03-2006, 09:01 PM | #4 |
I joined the Band! Join Date: Aug 2005 Location: Cincinnati
PLanetary gearbox=toy if you want something trick get in contact with a guy named Matt he runs www.scalehobbies.com he should have a contact with someone that can get a trans kit.... he works with thundertech and rpm and others. Its worth a try.
