01-31-2010, 07:01 PM | #21 | |
01-31-2010, 09:40 PM | #22 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
| way way more than 10,000 lines laser scanning to create geometry and programming the machine are two completely different things, hence where the term cad/cam comes from. That was not done with scanned geometry, it was done original an solid, laser scanned geometry is very innacurate. that geometry was perfect. the software that did that was likley automotive grade sowtware and half the cost of the machine. i would guess something like http://www.tebis.com $125k for begginer seat |
01-31-2010, 09:43 PM | #23 |
| did you do any linear filtering ? convert line to arcs ? million line program on a vertical is extreem |
01-31-2010, 09:47 PM | #24 |
RCC Addict Join Date: Nov 2007 Location: in the woods
01-31-2010, 09:49 PM | #25 |
| i understand, ive been programming 3d for 20 years.. even mastercam will create programs with tiny inefficent line segments, it does not convert them to arcs automatically, most people dont know the difference, but you can filter the line segments out, using a chordal deviation tolerance and you part runs smoother and faster, with much less code. and while we are at it, your finish on delrin has very little to do with the coolant you run, you can piss on delrin and get a good finish if you use the right tooling. Last edited by tom@vp; 02-01-2010 at 03:16 PM. Reason: spelling |
01-31-2010, 10:51 PM | #26 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
Unigraphics $100,000. a seat and we had 5 seats. If I remember, maintenance was like $100,000. a year. We also had Gibbs, mastercam and we had this other software called Inpact. Inpact was like $1500.00 a seat and was the most fun and easiest to use. I think they went out of business. Now I use Surfcam. There is a few things I would like to change but for the most part it works just fine. Cut delrin dry except for tapping. Last edited by Mayhem Eng.; 01-31-2010 at 10:56 PM. |
01-31-2010, 10:51 PM | #27 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
That video was amazing!
01-31-2010, 10:55 PM | #28 |
| another real good one, where did you work before ? i think the only thing i cut dry is roughing steel. and phenolic or something like that Last edited by tom@vp; 01-31-2010 at 11:00 PM. |
01-31-2010, 11:08 PM | #29 |
What I have found cutting it dry is the chip is lite and fluffy and doesn't stick to the cutting tool as much. You can really see this in drilling. When I used coolant during drilling cycles the chip would wrap around the tool and become hard from being cooled and stick to the drill. With milling the finish looks good better then when using coolant. Just my .02 |
01-31-2010, 11:29 PM | #30 |
anyways the key is not dry or wet, it is the tool.. what exact type of tool should be used for delrin or most plastic,, |
01-31-2010, 11:42 PM | #31 | |
| oh that could so easily be taked out of context... Quote:
01-31-2010, 11:55 PM | #32 |
02-01-2010, 12:13 AM | #33 |
I know this thread has deviated from its origin, but I want to speak to a couple points. Tom, I do use the filters to minimize line segments. I am looking for some pictures of the parts in question and I think they will explain the huge amount of code needed to run them. Not sure where this came from but....alright |
02-01-2010, 12:17 AM | #34 |
02-01-2010, 08:12 AM | #35 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I'm just glad the CNC control manufacturers are actually starting to put some memory on their controls so you can get away from drip feeding. Paying $4k for 4mb of memory really sucks. Arcs ad tons of code especially during the finishing operation with a very small stepover. You can only make the minimum arc lenth so large depending on the geometry being cut. Last edited by dkf; 02-01-2010 at 08:17 AM. |
02-01-2010, 08:50 AM | #36 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
02-01-2010, 02:18 PM | #37 |
ok, do you filter ? that is question im asking but is getting over looked. one arc movment can be broken into 100 or more line segements, or you filter, the filter flips the program with work plane g17/g18/g19 and writes a simple arc movement as a XYX IJK move in one line, this can reduce a single pass on a part from a 1000 LINES TO 1, 10 OR 100 but if you just select surface and say go, yea you can write a program way too big, and say hey i wrote the biggest 3d program in the world, when it didnt need to be... Last edited by tom@vp; 02-01-2010 at 02:55 PM. |
02-01-2010, 03:34 PM | #38 | |
02-01-2010, 03:37 PM | #39 |
but i said arcs not lines... i was trying to help, not hurt... i quit... have a nice day.. |
02-01-2010, 03:39 PM | #40 | |
