12-17-2010, 05:48 AM | #1 |
RCC Addict Join Date: May 2008 Location: Green Bay
| 1:1 Toyota Pickup info needed
Hey all, I am looking to pick up a low to mid 90's 4x4 Toy. I need some info on what to look for or stay away from on these used trucks. I have found several in my price range but don't want to miss anything. I know there are some Toyota Gurus on here so lets here the info Will be a daily driver for a year or 2 then turned into a trail truck. Last edited by reddevildemo; 12-17-2010 at 07:06 AM. |
12-17-2010, 06:33 AM | #2 |
Rock Crawler Join Date: Jan 2010 Location: SOUTH CRAWLINA
I would go with one that has the 22re engine, look for rust on the frame rails around the rear wheel wells, and check for oil leaks around the timing chain area. Other than that nothing really, they will run forever. |
12-17-2010, 07:06 AM | #3 |
Def will have the 22RE and thanks for the info on the oil leak and frame rust.
12-17-2010, 07:15 AM | #4 |
Quarry Creeper Join Date: Aug 2008 Location: back where I belong
timing chain head gasket frame rust ( really check it bust out a little hammer and listen for dead spots etc etc. use a screwdriver see if you can poke it through. if it is dead) |
12-17-2010, 07:26 AM | #5 |
Quarry Creeper Join Date: Mar 2009 Location: Raleigh
Remember, Toyota makes this..... |
12-17-2010, 01:48 PM | #6 |
The problem with the 22RE isn't so much the timing chain, but the timing chain guides. They are plastic and do break. There are companies that sell metal backed guides so if you have to do a replacement, do a search and don't put the stockers back in.
