Where to get Scale Diamond Plate sheets ?? I wana make a Trailer to scale of my current one.. http://www.imagestation.com/picture/...4/f189d2b4.jpg Unless someone knows where i can get a scale version of that.. Like 10th scale.. or maybe smaller |
http://www.rccrawler.com/forum/showt...=diamond+plate Post #3 Searching does wonders................................... |
Thanks for your wonderful words of wisdom ! :roll: |
JIA I am sure would know where to get this. I believe he used it on the Scorpion project. He'll chime in sooner or later? |
I see nothing wrong with Robb's post. READ IT! :lol: He said "Post #3" Post number three is my post with TWO links to the stuff on Tower. You don't search, someone gives you the answer, you don't pay attention to what they're tellin you, then you give'm chit. :roll: I don't get it. Anyway, here's a direct link to the post Robb was referring to, for those that need it. http://www.rccrawler.com/forum/showp...25&postcount=3 Also check out post #10 in that thread. |
man jia you through a loop when you say chit :lol: btw when is the new mag hitting the shelf? |
Does anyone know how STRONG that plastic diamond plate is ?? |
I backed mine with some thin aluminum. Cut the aluminum to shape, spray it with 3M spray adhesive, and stick the styrene on. |
Check here. http://www.oakridgehobbies.com/g_scale/g_142-144.html Click on "g grade diamond plate" it will show a picture. Don't know much about the size but they make scaled down versions of everything. (like for doll houses and such) |
diamond plate gardentrucking.com go to welcome page then to products then to hardware 471 checker plate, 2 sheets 6.5x7 This is what Badger used on his bruiser and this is what is used as side armor on my 4runner, its made out of aluminum. should be plenty good for a trailer. Mike |
