View Poll Results: How HOT would you rate your area now. | |||
Not bad, I don't care. | 18 | 25.71% | |
So HOT I can't remember | 10 | 14.29% | |
SOO damn HOT I got heat stroke and don't know what I'm online for. | 11 | 15.71% | |
A refreshing glass of hell would be better than this. | 31 | 44.29% | |
Voters: 70. You may not vote on this poll |
07-22-2011, 03:01 PM | #61 |
| Not, because the wind has an effect on me I can feel. Just like it does in the winter time. A physical force. But if the wind is blowing on a thermometer, does the temperature change? Humidity doesn't do it for me. They don't talk about humidity when it's cold out, or do they? Can it be cold and humid? Is there a cold index? |
07-22-2011, 03:11 PM | #62 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| Actually, there is. We've always had ratings here in NE where the "actual" temp, would vary from the "wind chill factor". The wind isn't a constant, like the actual temperature. Due to humidity, stagnate air or wind, the "feeling" of the temperature can be different. |
07-22-2011, 03:13 PM | #63 |
Yeah, sadly, those were serious questions. |
07-22-2011, 03:31 PM | #64 | |
Typically, humidity is lower when the temperature is cooler (at least around here it is). Both wind chill and heat index are different from the actual temperature...effects that cant be determined by a thermometer. Trust me, when the sweat does not evaporate from your body, it makes it feel hotter. Just like when it is cold, but when the wind blows, it feels colder... | |
07-22-2011, 03:35 PM | #65 |
It's all bogus. What happens if I sit in front of a fan?
07-22-2011, 04:04 PM | #66 |
07-22-2011, 04:53 PM | #67 |
Satan called. He wants his weather back.
07-22-2011, 05:15 PM | #68 | |
And my the thermometer says it's 79 (brick building holding heat). I'm in Ohio, I know what humidity and wind chill are. Added the screen shot. Last edited by EeePee; 07-22-2011 at 05:21 PM. | |
07-22-2011, 05:43 PM | #69 | |
Another nice example....go into your bathroom and turn the shower on full blast hot for 20 minutes and sit there....then walk out the door. Are the temps the same? Yep (thermostat is regulating that). Does it feel hotter in the bathroom? Hell yes it does... | |
07-22-2011, 05:54 PM | #70 |
it hit 108* before heat index in Baltimore today, it was a humid day as well. The only thing keeping me from passing out at work was the 'dew rag' that I had wrapped on my head that I kept drenched w/ water all day long. Tomorrow is supposed to be even nastier and I just got the call that I have to work tomorrow. |
07-22-2011, 05:56 PM | #71 | |
That's my pre shower poopin routine. I've turned on my shower full hot, and put the thermostat and this little humidity gauge I have in there also. I would gather the full hot water will change the temperature of the air, and the thermostat will indicate this. My full hot version of water is tolerable to stand in without any cold water needed. | |
07-22-2011, 05:58 PM | #72 |
07-22-2011, 06:01 PM | #73 | |
And guess what, the thermometer is up to 90 and humidity is approaching 100% | |
07-22-2011, 06:03 PM | #74 |
07-22-2011, 06:05 PM | #75 |
I am. I will let it max out, then pull the gauges out into the room I'm in. |
07-22-2011, 06:07 PM | #76 |
Turn your thermostat up to the same max temp of the shower room...let them level out. Then sit in one room for a while....then the other. See which one feels best. My guess is outside the bathroom...
07-22-2011, 06:16 PM | #77 | |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
comeing to the vancouver area? | |
07-22-2011, 06:18 PM | #78 | |
Yep, will be at a conference from the 30th to the 4th at the Convention Center near Gastown. | |
07-22-2011, 06:19 PM | #79 |
I know what I need to do, since I've maxxed out in temps/humidity in the bathroom. Compare when it's just about exactly 90 outside and no rain to what it feels like in the bathroom with full blast hot water. Right now, when I open the door and hang there for a few, it feels the same as a hot ass 90 degree day. I need to temperature match, or its bogus. Objective testing! Pulled the gauges out, and both are falling rapidly. Back down to 78 degrees and 75% humid ness. |
07-22-2011, 06:23 PM | #80 | |
