Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: Stu's Super Spectacular Static Scorcher!
Old 03-13-2012, 04:05 PM   #21
Default Re: Stu's Super Spectacular Static Scorcher!
Originally Posted by BigBaller View Post
Simple, he's a creep. Love the work Stu.
You do know, my wife will show you her tits if you sell it to her when done. ...maybe?
If she's silling to do that for a static model, maybe I could pork her for an RC
Probably not.
Today I finished the luggage shelf:
And the underside:
Sunroof track
Interior has been primed and will get the same blue as the dash. Hard to see, but I finished off the area behind the rear quarter windows with sheets of .005 styrene to give them the proper curve.
microgoat is offline   Reply With Quote
Old 03-13-2012, 05:17 PM   #22
Suck it up!
Duuuuuuuude's Avatar
Disgusting!
Duuuuuuuude is offline   Reply With Quote
Old 03-13-2012, 10:36 PM   #23
Nope..
Brainstain's Avatar
Awesome.
Brainstain is offline   Reply With Quote
Old 03-14-2012, 04:59 PM   #24
Today's progress:
Luggage compartment
Engine bay and hood hinges
Interior painted, with a little better shot at the rear quarter windows
Carbs from the T-Bucket kit (Stromberg 97's) with some homemade air cleaners.
My Kubelwagen arrived today, so I can get a start on the chassis.
Old 03-14-2012, 05:05 PM   #25
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Outstanding. If you ever decide to sell it...
Nova's Ark is offline   Reply With Quote
Old 03-15-2012, 04:55 AM   #26
You're gonna have to outbid Baller, and he's offering his wife.
Update!
Assembled the front suspension to the pan. Determined that the pan is about 7/8 too long, so I chopped it down. THe seam should be under the seats so it won't be too noticeable. I hope.
Made some filler strips and test-fitted the body to the pan. Oh yeah!
Started on the engine. I think this has more parts than the real thing. I used hi-temp header paint with a nice flat aluminum finish.
Change of plans up front. The Roady tires fit the wheels perfectly, but they look kinda big. Which isn't terrible on a Baja, but I wanted something more Vee-dubby. So I cut down some old Monogram tires.
Old 03-15-2012, 06:56 PM   #27
Painted the body a slightly darker blue. Obviously a cheapo re-spray, since the door jambs are still the original color.
More work on the engine. I was going to use both carbs, but since it's a single-port engine, one is enough. I replaced the kit distributor cap with a homemade one.
Test fit in the chassis. I had to do some serious hacking to make it fit this tightly; originally there was an inch between the firewall and the fan shroud, and the engine cover hit the generator. So I took half an inch out of the transmission and the rear fork. Now the axle shafts won't line up, but they're not as visible as the engine.
Cut the tail light lenses out and turned them around so I can use the clear ones included in the body set.
Two Firestones and one Maypop.
Old 03-16-2012, 12:40 AM   #28
I'd take the car over some ones old lady. at lest when your done with the car you can put it up in the closet and lock the door, with no back talken
spyderwebbcustoms is offline   Reply With Quote
Old 03-17-2012, 04:13 AM   #29
Sneak preview time:
Got the engine mounted and corrected the exhaust. Now all the tubes are equal length, or close to it. Also cut down some valve covers left over from the T-bucket. Can't mount the rear wheels until I make some adapter plates (where's my EMPI catalog?)
Got some simulated gelcoat (gloss white) on the fiberglass parts and cleaned up the overspray. I can't do a whole lot more until the paint cures fully. But I need to show the 1:1 ride some love today so I guess that's OK.
Old 03-18-2012, 04:36 AM   #30
In spite of the 1:1 maintenance, I made some progress yesterday:
Rear shock brackets, shocks and front engine tin (none of which are included in the kit). You can also see the valve covers I cut down.
Engine cover (seems a shame, really) and mismatched taillights. License frame is a cut-down Lindberg part. Rusted up the headers with PolyScale Rust (look for it in the train section, this is the best rust paint I've ever used).
And it opens up so you can see the Colt 45 can on the coil.
Old 03-18-2012, 01:38 PM   #31
Big day today, the body gets assembled to the chassis!
Also, glass cut and installed.
Front lights and license plate
Skull shift knob from the Lindberg T. I didn't use it on the T because the gold plating is uneven, but it looks worn enough to work here. I drilled into the base of the skull so the shifter would fit more securely (how often do you hear someone who's not a doctor or a serial killer talk about drilling skulls?)
Also, you can see the hillbilly plywood seat mounts.
Sunroof crank and rearview mirror
Rear wheels with adapter plates visible.
Old 03-18-2012, 02:55 PM   #32
Your a mad man.. Keep it up
sloppy is offline   Reply With Quote
Old 03-19-2012, 05:30 AM   #33
Added Bare-Metal foil to all the chrome (not that there's a hell of a lot of it)
Duct tape on the driver's seat
Random crap on the floor
Then I got distracted by the MG-42
Old 03-19-2012, 08:45 AM   #34
You need a cig burn on the seat Stu. I cant believe the amount of creativity you have and the skills to make it happen
hotwheels000 is offline   Reply With Quote
Old 03-19-2012, 09:39 AM   #35
Suck it up!
The floor is way to clean in there...
Old 03-19-2012, 01:56 PM   #36
Been thinking of how to make bug splats on the windshield that don't look painted on. Gonna experiment a little tonight.
I'm on it.
Old 03-19-2012, 02:58 PM   #37
Suck it up!
Originally Posted by microgoat View Post
I'm on it.
It needs little tufts of jute stuck to the floor pan.
Old 03-19-2012, 04:35 PM   #38
jeeper_05's Avatar
Been thinking of how to make bug splats on the windshield that don't look painted on...
Snot rocket?
This is an amazing build for sure!!
jeeper_05 is offline   Reply With Quote
Old 03-19-2012, 06:28 PM   #39
Lookin good
laxjj14 is offline   Reply With Quote
Old 03-19-2012, 06:45 PM   #40
Rusty floor pans with a few holes please.
GySgt Hartman is offline   Reply With Quote
Stu's Super Spectacular Static Scorcher! - Similar Threads
Honda CR-V, nothing spectacular SMUDGEBUG Tamiya XC/CC01 14 10-27-2009 12:16 PM
Spectacular crawling spot. Krakker Nebraska 2 04-09-2009 09:30 PM
tamiya super champ/sand scorcher f-150 ranger colonelangus Non Crawler RC's 16 12-11-2007 02:31 PM
1/18 nylint, nothing spectacular trickedoutTLT06 Videos! 1 09-03-2006 06:50 PM
