New Project: 1:1 '89 1-Ton Blazer Picked this up as a new 1:1 wheeling project for my boys and I. Got it in trade for a Mustang I was'nt useing 1989 Chevy Blazer ( Running gear from a '79 K30 ) 350 c.i. SM465 Manual Trans Full Float Corp. 14 Rear (Posi / 4.11's) Dana 60 Front (4.11's) 6" BDS lift (front/rear springs) Whooped 33's (for now) Body has some typical Ohio rust on the rockers / lower doors Frame is SOLID / Mech A1 Plan is to go CHEAP! find some used 35" to 37" tires Harbor Freight / Badlands 12,000lb winch ($329 with coupon...I know guys who swear by these Chinese winches!) beat the snot out of it!:twisted: http://i844.photobucket.com/albums/a...0630-00157.jpg |
Re: New Project: 1:1 '89 1-Ton Blazer Posi? Only lockers were available for it (posi is limited slip), G80's in the civilian trucks and Detroits in the CUCV's. Looks like a solid toy. Did you get a positive ID on that front axle? |
Re: New Project: 1:1 '89 1-Ton Blazer Quote:
Re: New Project: 1:1 '89 1-Ton Blazer The top of the pumpkin looks a bit too flat to be a 60 to me, and the 60's I've usually seen have longer hubs and stick out further. Looks like a big hub "HD" Dana 44 to me, only the lockouts are a bit odd if it were. |
Re: New Project: 1:1 '89 1-Ton Blazer Its definitly a Kingpin 60 front http://i844.photobucket.com/albums/a...0630-00156.jpg As far as the Posi? This is the first Corp 14 I've owned, always had Fords... It is Locked and axles not from a CUCV so I assume its the G80 you mentioned."thumbsup" |
Re: New Project: 1:1 '89 1-Ton Blazer Id get some better offset wheels to widen its stance so and make it look itt better to narrow track looking |
Re: New Project: 1:1 '89 1-Ton Blazer Nice K5!!! Man I miss the daily driver part of mine before I hacked it all to play on rocks. |
Re: New Project: 1:1 '89 1-Ton Blazer I thought All GM 60's were King pin.:roll: And yes, there is a limited slip available for the 14. My friend put one in his crew cab. I think it's made by Eaton. 35's would be great for that drive train/gear combo. Grind and shave the front and rear and you'll be good. I turned my 14, into a 13 bolt with a little patience, a sawz-all and grinder.;-) |
Re: New Project: 1:1 '89 1-Ton Blazer All GM D60s are king pin. GM never offered a limited slip/positraction differential stock. There was only ever the G80 locker, which is a piece of junk, though better in the 14 bolts than the smaller axles due to a larger carrier (where all the stress is placed when the locking mechanism is activated), as well as the Detroits in the CUCV's (may have been available in civ trucks, but not sure). There are LSD's available aftermarket, but a completely pointless upgrade when a Detroit or Yukon Grizzly can be had for less. I would buy some 37" Goodyear MT's rather than spend more money on 35's. You'll get better clearance at the axles without having to shave them, and they work pretty well and last long. They can be had for 4-600 for a full set 90% tread life. How much would you say that Mustang was worth, because those D60's alone go for 800+ around here in non-running condition. Should be plenty of fun, though. Nice score. |
The G80 was an epic fail- it used clutches as well as a centrifugal ratchet paw to give full 'lock up', all they are go for is blowing up and wiping out the entire differential. They were used from 1999 to present. |
Also, G80 is the RPO code for the Gov-Lock, which was renamed using that code by Eaton in the late 90s. The Gov-Lock from the 70's, 80's, and 90's, are the same exact thing as the G80. |
Re: New Project: 1:1 '89 1-Ton Blazer Nice truck... How many channels do you get with that satellite on the roof?? :ror: |
37" MTR's is actually my first choice for a tire...we shall see As far as the rear end, once it cools down around here, i'll pull the cover and check. Want to change all the fluids anyway... Mustang was a roadrace / autocross project. Had it for sale for $3200, guy wanted $3000 for the Blazer so we traded strait-up http://i844.photobucket.com/albums/a...0531-00117.jpg http://i844.photobucket.com/albums/a...0531-00120.jpg |
Back to the original post, that's a nice K5! Did the PO keep the TB injection system in tact? IMO it was the best of all of the offerings, a TB 5.7, OD transmission and a straight axle up front (although I realize that someone has upgraded to the 1ton axles in your truck) |
Is it a possibility that the LSD's you encountered were installed aftermarket? |
Re: New Project: 1:1 '89 1-Ton Blazer The Eaton LS was a "dealer" installed option, also done at some conversion places, (like camper specials) they were an option to the Detroit that some ranchers and "camper" people didn't care for. Similar to the "Hurst" mods that were done only for trucks. |
I had a 78 Pontiac formula that had the Hurst T-tops on it with the shifter of course. Seen a convertible 79 Trans at a car show earlier this summer that was pretty rare also. Back to the Blazer, I miss mine (all 3, 72, 90, & 94) They make a really solid platform to wheel on the cheap with. Not sure what they did with the braking system, but I'd recommend the the E-350 van master cyl. I also like pretty much every product that DIY4X4 offers. Pinion gaurd and diff protection are important with such big axles and sub 40" tires. I've got their rear diff ring and pinion gaurd, with the axle shaved, I'm looking to make a 3/8" thick narrow skid from the lower part of the ring that ties into the pinion gaurd. PS, mine will be for sale as soon as I get it completed."thumbsup" (sorry for the personal pimp'n) |
