![]() | #21 |
Newbie Join Date: Dec 2005 Location: Ogden
These are pics of RockRacer1's obstacles that he built. He asked me to post them for him...enjoy: ![]() ![]() ![]() ![]() Thats it...if you have questions about these obstacles, I'm sure RockRacer1 would be more than happy to answer them! |
![]() | #22 |
I wanna be Dave ![]() Join Date: Dec 2005 Location: Tax Nation
nice!
![]() | #23 |
we should get "the powers that be" to setup a forum for course construction
![]() | #24 |
Quarry Creeper Join Date: Jul 2006 Location: Formula Off-Roading some hill
That red 1 was the heavy bugger 70-80lbs , more concrete than foam also has red dye in it. the grey 1 is alot lighter 10-15lbs , used styrofoam and expandable foam with tile mesh. the concrete/mortar is thinner though, so I have to be careful when moving it (I dropped an end down hard and broke a chunk off) . so far Im into these obstacles 35 bucks each. the pic of the grey 1 is while under construction (wire mesh exposed) after atempting it and getting rejected 150 times I added alitlle more mortar til it was possible to climb. Last edited by RockRacer1; 10-31-2006 at 11:21 PM. |
![]() | #25 |
Ill be glad when spring rolls back around and I can build a course I dont have to be able to move. I put mine in the garage last night and have determined that it needs wheels
![]() | #26 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
You guys should seriuosly consider the styrofoam beadliner method. I can lift and carry one of our 4' X 8' sections by myself. ![]() |
![]() | #27 |
I considered styro since I have used it with great success with trainsets however, In the spring I plan to build a large outdoor perm. track and wanted to test the chiken wire form method
![]() | #28 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Rockpiledriver....am I correct in thinking you lay 1 sheet down flat and then take another sheet, cut into pieces and attach at 90 degree angles to the flat piece? Then carve out what you want? All of these look nice. I will start building mine in about 2 weeks, once I get my bonus. Hope to have enough built to have a comp on. Thanks, Casey |
![]() | #29 |
Im gonna try the foam/beliner method on my next two obstacles . I saw the SLC , UROC course get built so I had to try it .
