12-20-2014, 06:25 PM | #1 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Electrical question
I was just wondering, if I have an adjustable power supply and turn it up to like 60V at 0A will it still supply power? Or will I have to turn up the amps to get power? Also, what do amps do? I know tazers work because they have a really high amp rating coupled with 50,000 volts. I just don't want to electrocute my self while messing with my new power supply.
12-21-2014, 05:42 AM | #2 | ||
Quarry Creeper Join Date: May 2009 Location: India
| Re: Electrical question Quote:
Voltage is like pressure and amphere is like amount of flow. Everything in the universe is made up of atoms. An atom is a cluster of protons, neutrons and electrons. Protons and neutrons make the nucleus of an atom, where as electrons orbit around this nucleus. Electricity is made up of these electrons. Two out of these three have a charge to them. Protons have positive charge. Neutrons have no charge. Electrons have negative charge. Opposite charges attract each other and Like charges repel each other. This is why positive charged Protons attract negative charged electrons which orbit around them. These electrons when loose their orbit around protons and neutrons, they become free to rome around and are called electricity. Electricity is a bunch of electrons trying to jump into orbit of some atom that does not have the adiquate amount of electrons orbiting it. Atoms loose and gain electrons while rubbing against each other. So if you had to slap someone, there will be some exchange of electrons between the person you slapped and your hand. To make it easy to understand lets consider 100 electrons are flowing from left to right in a copper wire 1 meter in length. If 1 electron is leading and the other 99 electrons are following one after the other then it is somewhat like 1v @ 1 amphere If 10 electrons are leading in a line and anothe 10 follow them in a single line and so on until all 100 electrons occupy 10 lines, then it is somewhat like 10v @ 10 amphere. In reality, do not relate number of electrons to voltage, amphere in the ratio I did. I just made it easy to understand. ------------------------------------------------------------------------ Tasers do not have high amphere In fact they have amphere in the range of milliamps. The higher the amphere goes, the thicker conductor we have to use. The high voltage in tasers, makes it possible for electricity to jump any resistance in its path. Any biological body is nothing but resitance for electricity to pass through, hence high voltage helps to easily pass through it, distorting the bodies electrical signals to muscles. The 5V and 1 amphere adapters don't even sting. But take the voltage to 24volts @ 1 ampere and you will feel the pain. 5volt is not capable of effectively penetrating your skin but 24 volt does it with ease. If tasers had 50000 volts and even 1 amphere current, then the power would be 50000 volts x 1 amphere = 50000 watt. In 1 HP there are 746 watt. So 50000/746 = 67 HP Any body that gets tased with a 67 HP taser would literally burn down instantly. Tasers generally have power under 10 watt. P.S - Do not play with electricity unless you are fully knowledgeable. Last edited by wings_of_fire; 12-21-2014 at 05:53 AM. | ||
12-21-2014, 06:09 AM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Holy shit there Dr. Science!!
12-21-2014, 03:54 PM | #4 | |
12-21-2014, 03:57 PM | #5 | |
12-23-2014, 01:32 AM | #6 | ||
Technically, there's issues with this. Its accurate with an old model of the atom but the "modern/current" model is much more complicated, especially when it comes to the electrons and how/why they stay around nucleus...but it's good for getting a picture across. Also, describing how "electricity" flows, really depends on what type of conductor you're using and going further than whats taught in k-12 and introductory college courses...there's a lot of different relations made to try and explain electricity to something mechanical. But they're all wrong in one way or another and need an aspect or two from many different mechanical examples to explain electricity...there's more ways than just moving electrons to make electricity. ... ... I'm not really going to go in depth, mainly because I have archived it all into a deep hole in my brain and i don't want to dig it all up. But if you're interested this is a good site I have saved in my favorites (Yes, I think i've read it all)...it does a good job at clearing up all the false knowledge you're taught. (the truth is too hard to teach to someone who doesn't give a **** or can't process complex processes...and very time consuming to cover it all the right way) Articles on "Electricity" . . . . WJ Beaty Quote:
So while you think what he said common, other people learned something else. | ||
12-23-2014, 01:33 AM | #7 | |
Here's a decent overview snippet from one of pages Quote:
12-23-2014, 01:44 AM | #8 |
| Re: Electrical question |
12-23-2014, 01:59 AM | #9 | |
I've stuck my fingers in tons of things I'd never stick my ding dong in. You can do with out a finger or two, but the ding dong gets the presidential treatment. But, when it comes to electricity all the body parts are kept away from stuff that'll zap my ass. | |
12-23-2014, 07:01 AM | #10 |
Pebble Pounder Join Date: Jan 2005 Location: st. louis
| Re: Electrical question Most people don't realize they are using Algebra and Geometry on a daily basis. Every time you do the math at the gas pump to figure how much gas you can get with the cash available you're using Algebra... |
12-23-2014, 09:34 AM | #11 | ||
They teach the old model because it's easy...but it is wrong. You were taught the bohr model of the atom which is very easy to talk about and in most cases the "outcome" of an occurrence is usually predictable. But it has it's short comings The "current" model is the quantum model. Here's a video explaining it https://www.youtube.com/watch?v=accyCUzasa0 Also, there are more complex models out there based off the quantum model and may other different models that came before hand. But the base quantum model is the current one that is often taught and does a much better job at predicting the atom compared to the bohr model which is taught until you get into high level science classes when the differences matter. I'd give you a link to a more complex current model I learned about but I don't feel like digging my notes out to get the name of it. But to get a better a feel of the atom you need to dive deep into quantum mechanics, which is a very confusing place. Also, an atom is more than protrons, neutrons, and electrons...you have to go deep. Such as that protons and neutrons are made from quarks and other subatomic particles...it gets more complicated too. Quote:
If you're perfectly fine losing a finger, then good for you | ||
12-23-2014, 01:47 PM | #12 | ||
And you can work around a missing finger or two. A missing johnson is a different story, you only get one of those. | ||
12-24-2014, 10:01 PM | #13 |
Algebra ALWAYS has a letter in it... and yes you use those letters and the algebraic procces everytime you do math to answer a question. You just don't realize it... Geometry is not algebra. It's shapes...now you can/do use algebra to solve geometric problems. And believe it or not... you do Calculus in everyday life to. |
12-24-2014, 10:11 PM | #14 |
Electrical question - Similar Threads | ||||
electrical help | openeagle | Newbie General | 8 | 03-02-2010 07:53 PM |
Electrical problem | makahacrawler | Losi Mini-Rock Crawler | 5 | 04-24-2009 07:13 AM |
Electrical help | wolfattak | HPI Wheely King | 9 | 12-26-2007 02:15 PM |
Need some electrical help..... | Thorsteenster | Chit Chat | 9 | 12-24-2007 08:51 AM |
Electrical question | truegaintfree | General Crawlers | 2 | 03-04-2006 08:57 AM |
