Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: War Pig's new addition/shop.
Old 02-25-2015, 07:52 AM   #41
Default Re: War Pig's new addition/shop.
External entry only or will you have an entrance from the house too?
DickyT is offline   Reply With Quote
Old 02-25-2015, 08:19 AM   #42
Originally Posted by The Violator View Post
And I was proud that I broke out the tape measure and level to hang a picture for my wife. Nice work.
Hey man, pictures gotta be hung! Whatever it takes to keep the wife happy.
Originally Posted by BigSki View Post
5' ?? It makes sense now. I'll send you a PM for a box of cedar shavings.
Living on the east cast for so long, basements are just assumed to be a part of the building process. It's much less complicated to have a hole 10' below grade on this side of the continent.
Yeah, the codes here are pretty stupid, but with the "chance" of seismic activity I guess it's better to be safe than sorry.
Originally Posted by losikid View Post
What are you putting on that floor? A machine shop?
Massively thick plywood and such a tight spacing on the joists has gotta support a massive amount of weight.
I think my parents house has 3/4" osb on floor joists spaced 24" apart....it's been a lot of years though since they built it, I may be mistaken.
Family room. The I-joists are only 9.5" tall and span a 16' gap that's why they are 12" OC, the 1 1/8" was my idea. I have 4 rambunctious kids and will have hardwoods in that room so I figured what the heck. It only added a couple hundred dollars to the cost. I'm all about doing it right the first time.
His addition will outperform the entire original structure. I agree that the slab thickness on the addition would support a freight train. ( no pun intended)
I was surprised to see a glu-lam beam, when I saw the pocket in the wall I assumed a nice piece of steel was going to be set into the hole.
My dad pushed for a steel beam but the glulam works fine, plus I'm going to sand it down and finish it. It should be a nice display area for my collection of antique tools.
Originally Posted by salmonshark View Post
When I built my addition a few years back, I used 1 1/8" tongue and grove plywood for my main floor which is what that looks like to me. My joists were 24" OC. The inspector thought I was building a bomb shelter and I never had any write ups.
I could never use OSB. The thing with OSB is that "if" it ever gets wet, it swell up. When it dries, it stays swollen. With plywood, if it gets wet, it may swell some, but when it dries back out it will go back to its original form, or close to it.
I love the job you are doing. I think it look awesome so far! Great job!
SS
I agree with never using OSB, hate it. I started this project in June and put the last shingle on in the fall just as the rain started. The entire structure never got a drop of water in it. The entire addition is sheeted in plywood.
It has the concrete stairway to the back yard plus another stairway to the main level.
War Pig is offline   Reply With Quote
Old 02-25-2015, 08:19 AM   #43
Donkey Punch Champion!
BigBaller's Avatar
As usual for Tim, build it once...overbuilt!
Wow, what a project Tim. Congrats, I bet momma is gonna be HAPPY to have the space too.
BigBaller is offline   Reply With Quote
Old 02-25-2015, 08:26 AM   #44
More.....
I was lucky to get hooked up with some great framers. This is what I came home to the first day.
Second day.
Third.
4th
The last couple days were installing straps, small stuff inside and sheeting the roof. They framed the whole thing in 6 working days. Looks like it's time for me to roof....
Old 02-25-2015, 08:42 AM   #45
2013 2.2P Nat. Champion
SkaldidDog's Avatar
As my old summer camp owner said about such things, "a thing of beauty and a joy forever".
What is your design reasoning behind relatively few and small windows with some placed high on the walls?
Cheers,
J
SkaldidDog is offline   Reply With Quote
Old 02-25-2015, 09:01 AM   #46
Cheers,
J
Hah! You noticed that. The large blank wall in the front is going to be my big screen TV and the smallish high windows are where the Pingpong (and possibly pool) tables will be. Just didn't need the neighbors looking down into the house. The large windows in the front of the addition face west and will allow plenty of light in.
Old 02-25-2015, 09:06 AM   #47
Thanks! Now you know why I haven't been able to work on scalers for a while.
Ryana's excited to have her own laundry/sewing room with heated floors.
Old 02-25-2015, 09:13 AM   #48
Roof!
I had an awesome helper, and a nice view
Designed a way to work on the 8/12 pitch roof in 80 degree weather without tearing it up and sliding off.
Old 02-25-2015, 09:26 AM   #49
MODERATOR™
EeePee's Avatar
Been watching this the whole time. But now is the time I tell you I'm very impressed.
EeePee is offline   Reply With Quote
Old 02-25-2015, 09:42 AM   #50
Thank you sir! I was wondering what it would take to get you to comment on one of my threads
Old 02-25-2015, 11:17 AM   #51
What did you end up doing with the temporary floor supports of the existing structure? Maybe I missed but how much above grade sq footage are you adding?
lsone is offline   Reply With Quote
Old 02-25-2015, 11:17 AM   #52
Time for windows and siding!
Old 02-25-2015, 11:22 AM   #53
Awesome project man!
ctrwannabe is offline   Reply With Quote
Old 02-25-2015, 11:26 AM   #54
Once I frame in between the existing house and new foundation I jacked the house up a bit and removed the beams and posts. I reused them when I framed the basement for posts and headers. The main level (family and laundry room) and upstairs bedroom are 910 sq ft. The basement woodworking and RC shops are 635 sq ft, but it's unheated so it's not included in the square footage of the house. The bedroom we're adding is 14x17' so it's big enough for my two youngest boys to share for now.
Old 02-25-2015, 11:29 AM   #55
Nice work.
What are you doing for a ceiling in the basement? Is your house heated via forced air? Would be pretty simple to duct over using a false ceiling and add ducts that way
Old 02-25-2015, 11:40 AM   #56
Nice work.
It's just insulated R30 with 1/2" drywall. I could easily cut into the ductwork that runs through a soffet in the basement, but really, it stays a pretty consistent 55-60 degrees down there and that's a perfect temp for me to work.
Old 02-25-2015, 11:46 AM   #57
I see I asked my external entry question too quickly! You had not posted the framing photos yet, which would have answered my question.
Great work! I wish I could do a basement here, but the dang water table is too high.
Old 02-25-2015, 12:49 PM   #58
It's about a mile from the river up to the top of the hill (that I live on the side of) and I live half way between them. It's probably a 200-300 ft drop to the river from the top. I get a lot of surface water but there's really no "water table" to speak of. I plan to slope the yard around my house and will have lots of concrete patios and walkways to drain water away from my basement. Don't want any water in a woodworking shop.....
Old 02-25-2015, 01:01 PM   #59
Holy smokes! Your almost done....dannnnnnnnnnnng.
justinart24 is offline   Reply With Quote
Old 02-25-2015, 01:07 PM   #60
Man I wish. My area of South Florida has a water table about 9 feet deep, it makes basements a no go.
War Pig's new addition/shop. - Similar Threads
War Pig's EB Truggy War Pig 2.2 Scale Rigs 1053 01-19-2016 01:03 PM
War Pig's all new '34D War Pig 2.2 Scale Rigs 625 12-20-2015 11:47 PM
War Pig's new DD90 War Pig 1.9 Scale Rigs 148 04-06-2013 08:45 PM
War Pig's new 1.9 scaler War Pig 1.9 Scale Rigs 119 08-05-2012 05:03 PM
