04-03-2015, 09:03 PM | #1 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
| Boom Racing wheels
Copied from my Dingo thread... I haven't see these mentioned around here yet. They are Boom Racing aluminum beadlocks from AsiaTee's. These particular wheels are called Bar-6B's. Back ring weighs 37g, clamping rig is a whopping 75g and the front ring is 44g, for a total weight of 156g ea. They're hefty. I didn't bother adding any more weight. I also forgot to measure the width. They come with a cheesy 2mm socket that lasted about a wheel and a half. Luckily each set of two came with one, so being careful, I was able to finish the rest. I'll have to hit up a vendor here for a new tool if I need to take these back apart. I may be able to use a 2.5mm screw as well, but it might be a tight fit. Fit and finish is excellent, based on my limited exposure to beadlocks (these and a set of RC4WD on my Highlift). The locking comes from the 6 hub screws. The 6 screws around the outside are removable, but serve no other function than to fill a hole. Last edited by Jeckler; 04-03-2015 at 09:05 PM. |
04-05-2015, 03:13 PM | #2 |
Rock Stacker Join Date: Aug 2014 Location: So. Cal.
| Re: Boom Racing wheels
Those look pretty nice. I was curious about their quality.
04-05-2015, 05:20 PM | #3 |
I've run into one small issue. I don't know if it's STRC's problem, Axial's problem or Boom Racing's problem though. I'm running STRC universals up front w/stock Axial narrow hexes and the wheel nut bottoms out before the wheel is fully tightened. I put a 4mm washer under the nut to take up the slack. In the back they're nice and tight against the hex. Stock axle shafts back there. |
01-15-2016, 11:04 AM | #4 |
Newbie Join Date: Sep 2015 Location: harrisburg
ok so I bought a set of boom racing high mass wheels and tried to mount my 1.9 super swampers onto them and the bead of the tire is too thick to set into the beadlock. I do not know what to do? I really want to use the tires soon!!! Does anyone have any suggestions????? Thanks, Dustylee4400 |
01-15-2016, 11:48 AM | #5 | |
Rock Stacker Join Date: Dec 2015 Location: Ashland, VA
| Re: Boom Racing wheels Quote:
01-16-2016, 04:19 AM | #6 |
Quarry Creeper Join Date: May 2009 Location: India
Those wheels look good.
01-20-2016, 07:53 PM | #7 |
Newbie Join Date: Oct 2015 Location: My House
Combine those with their steel axles and that's a lot of weight down low...
01-21-2016, 06:28 AM | #8 |
578 grams to be exact. Have a set of these wheels obviously, and agree they are pretty nice. Paint could be a little crisper, but the overall machining and tolerances are good. Agree the little socket and 2mm screws are somewhat flimsy. Got mine mounted, but it was harder than it needed to be. Last edited by OSRC; 01-21-2016 at 06:32 AM. |
01-21-2016, 05:03 PM | #9 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
Nice! Boomracing makes some nice wheels for sure! I run their Cyclones on my Losi NC and they are great....
04-13-2016, 02:59 PM | #10 | |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
Sent from my Nexus 10 using Tapatalk | |
04-13-2016, 03:19 PM | #11 |
I've held Boom Racing 2.2 High Mass wheels. They are so nice. But they are insanely heavy. Too heavy for my liking. But I will own a set of the 1.9's at some point. Boom has stepped it up a notch with their Krait series of wheels. |
05-23-2016, 07:37 PM | #12 |
Quarry Creeper Join Date: Nov 2008 Location: Cincinnati
| Re: Boom Racing wheels Any idea if these Krait wheels will mate up to an SLW style hub?
05-26-2016, 12:25 PM | #13 | ||
Maybe use VP 1.9 inner lock rings or SSD RC blue Proline specific inner lock rings. | ||
05-30-2016, 08:49 PM | #14 |
Newbie Join Date: Mar 2016 Location: USA
Does anyone know if the Krait wheels will ever be produced in 2.2?
Boom Racing wheels - Similar Threads | ||||
Boom Racing parts??? | RABIDFOX | Chit Chat | 118 | 11-19-2017 04:20 PM |
Boom racing | G2rebel | Vaterra Twin Hammers | 16 | 01-15-2016 03:10 PM |
Boom racing products/ asiatees.com products | nwcrawler | Axial SCX-10 | 11 | 12-29-2014 05:11 PM |
ABS Jeep and land rover hard bodies from boom racing | Calderwood | Paint and Body | 6 | 07-26-2014 03:40 PM |
