07-27-2015, 04:42 PM | #21 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| re: I need help - we todd did
I don't get it I changed out the fuel pump and fuel filter and the truck is even worse now cause now it starts running bad and starts sputtering and back firing at 35 miles per hour so now I can't even drive the truck I don't get it, the gas was flowing pretty good from the lines until I remembered to take the gas cap off and it released the pressure on the lines and it stopped flowing while I changed out the fuel pump and filter how does it get worse and drop 10 miles per hour before it cuts out I'm lost no xxxxxxxx clue of what is going on now I called Mark this morning he suggested I change out the fuel filter and pump he also suggested that I drain some fuel out of the fuel tank cause the sock will not let water in so could be water in the fuel tank but I can't find the drain cause there is a skid plate and the skid if part of the fuel tank mounting and looks like you got drop the fuel tank I called Mark a second time and he is coming over tonight he thinks I still got fuel problems I'm thinking next is new plugs, wires, cap, and rotor cause it might be electrical Last edited by kgb424; 07-27-2015 at 04:56 PM. |
07-27-2015, 05:04 PM | #22 | |
Rock Crawler Join Date: Jun 2008 Location: Naples
| re: I need help - we todd did Quote:
"beaning to rich" ? no idea what that is, sorry! | |
07-27-2015, 05:56 PM | #23 |
Here is are 2 pictures of the new fuel pump and just cleaned and oiled the air filter it not pretty but she normally run good and have had a few problems Last edited by kgb424; 02-04-2016 at 03:46 PM. |
07-27-2015, 07:51 PM | #24 |
ok Mark came over to my house and took the truck for a test drive and it sputtered and backfired and we tested the fuel pump and the delivery is good and the are no cracked fuel lines or water in the gas he doesn't think its electrical or ignition or the coil cutting out he thinks it the carb, maybe the needle and seat and wants to take it apart and check it so when I can a ride I will take the truck in |
07-27-2015, 08:11 PM | #25 |
A haiku poem form you do type in
07-27-2015, 08:29 PM | #26 |
I'm a poet and didn't even know it |
07-27-2015, 08:58 PM | #27 |
| re: I need help - we todd did |
07-27-2015, 09:27 PM | #28 |
Rock Crawler Join Date: Oct 2012 Location: Casper
I was gonna say, days ago, that you need to pull the carb apart but, this HAS been a fairly entertaining thread.
07-27-2015, 10:05 PM | #29 |
| re: I need help - we todd did It's a carburetor not the space shuttle. There are 4 screws holding the air filter base plate in place then 6 more screws holding the top plate on the carb body. Once those screws are out and the e clip holding the choke linkage on the arm is removed the top plate comes right off and any issue will be right there in front of him. Or it could be as simple as the filter built into the top plate that I linked a schematic to but hey, what do I know? |
07-27-2015, 10:47 PM | #30 |
Quarry Creeper Join Date: May 2009 Location: India
Haiku poem. O snail , Climb Mount Fuji, But slowly, slowly! |
07-27-2015, 11:12 PM | #31 |
He showed me where the filter is on the front of the carb and I took it out and it was clean, no dirt it was hotter than shit today and when I tested the truck early it was around noon and would go 35 to miles per before sputtering and backfiring when Mark tested the truck it was around 6 pm and a lot cooler and would go almost to 50 miles per hour before it sputtered I installed the carb and tuned it and got it close to where it needed to be Mark fine tuned it after I installed it and other than cleaning the K&N air cleaner I have never have taken the carb apart and not sure if I want to attempt it cause I don't want to screw it more than it is and don't want to a clip or something that's hard to replace and Mark doesn't mind doing it and I rather have him do it so I know its done right |
07-27-2015, 11:19 PM | #32 |
I have rebuilt a few Mikuni 36 mm and 38 mm flat slide carbs for my four strokes and few Keihin carbs back when I had my old YZ, KX never rebuilt a Webber |
07-27-2015, 11:43 PM | #33 |
Weber my be the easiest carburetor to rebuild ever. There really isn't much to screw up that you can't find the answer to using google.
07-28-2015, 10:18 AM | #34 | |||
X2...git r dun! Also good to add a piece of heater hose or the Toyota factory black foam fuel line insulation over the fuel line, I did mine from the frame rail to the fuel pump and from the pump to carb. The insulation should not be wrapped tight around the fuel line, the extra little air space helps isolate and insulate from underhood heat. Last edited by Natedog; 07-28-2015 at 10:20 AM. | |||
07-28-2015, 12:59 PM | #35 |
07-28-2015, 01:00 PM | #36 |
Later to day when it cools off a lot not screwing with gasoline in 100 degree heat and it noon and getting hotter I'm going to take the Throttle body off Mark suggests I look and see if there is dirt in the Needle seat for the floats I bought some B12 carb cleaner so I can spray it out if it needs it, I hope there is not a blockage in the carb some where Is there anything else I should be looking at, beside if it clean, and needs a cleaning when I have it apart Last edited by kgb424; 07-28-2015 at 01:09 PM. |
07-28-2015, 01:17 PM | #37 |
Oh Natedog Why must you quote all It is god damn annoying as hell for crying out loud, man! |
07-28-2015, 03:36 PM | #38 |
Moderator Join Date: Jan 2004 Location: chicago
does it just cut out at speed or does it sputter and die? never messed much with yotas, but i wouldnt rule out ignition. i had a bitch of a time with an old pontiac falling flat on its face that turned out to be a bad pickup coil in the hei dizzy. |
07-28-2015, 05:47 PM | #39 |
it starts sputtering and some times backfires and the power goes away and the float bowl empty's out but if let off the throttle a little, it will continue to run and the power comes back and float bowl refills and if you step on the throttle again it will pick up speed until it starts sputtering again that why Mark suggests I take the carb apart and look at it we tested the new fuel pump, the delivery is good or it could be the coil going south, I will look in my Chilton and see if I can test it with an ohm meter tomorrow morning when its cool I'll work on it Last edited by kgb424; 07-28-2015 at 05:57 PM. |
07-28-2015, 06:25 PM | #40 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Mark is the most patient mechanic I've ever read about. I hope you pay him for each question.
Tags |
dafuk? |
I need help - we todd did - Similar Threads | ||||
The Increasingly Poor Decisions of Todd Margaret | JeremyH | Chit Chat | 11 | 10-03-2010 07:00 AM |
