Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: Is An MMX And HH Puller Pro Good For A RR10 Bomber?
Old 08-15-2016, 07:01 PM   #61
I joined the Band!
Default Re: Tekin ROC 412
Or in the first one where you wrote "Yay!" Because you were happy that I got banned?
Sent from my SM-G920V using Tapatalk
K.C.'s RV is offline   Reply With Quote
Old 08-15-2016, 07:07 PM   #62
MODERATOR™
EeePee's Avatar
Neither of those infractions are why you got banned. Shall we rehash why you got banned or maybe you can get over it and move on? Or maybe you can delete all my posts? Or maybe instead of reading your reported posts about nothing because things don't go your way, I can show you the door again and not have to worry about it…
EeePee is offline   Reply With Quote
Old 08-15-2016, 07:09 PM   #63
I joined the Band!
Wow, thanks for adding completely useful *not* to this thread!
Old 08-15-2016, 07:34 PM   #64
Originally Posted by mikemcE View Post
CORRECT ANSWER......IS : the MMP and Holmes Hobbies TrailMaster BL ESC.......rated for vehicles up to 6.5 lbs on 3s
The MM2 and MMX for heavier vehicles......
The only listed difference for the HH TrailMaster BL is " Adjustable switching frequency allows for silent operation and efficiency tuning."
I own one and IF there is such a thing as " HOLMES HOLD" there is NO DOCUMENTATION included on how to use or set.
I am NOT complaining as I love the esc with my Tekin 17.5 sensored.....
I stand corrected, the BLE doesn't have holmes hold, its his BRXL esc that has it.
84yoda is offline   Reply With Quote
Old 08-15-2016, 08:36 PM   #65
Default Re: Is An MMX And HH Puller Pro Good For A RR10 Bomber?
rngrchad is offline   Reply With Quote
Old 08-15-2016, 08:37 PM   #66
I joined the Band!
Cool Fisher Price. That your daily driver?
Old 08-15-2016, 09:07 PM   #67
Originally Posted by EeePee View Post
Hah, rating ESCs for weight is a gimmick. And if you can't find documentation about the "Holmes Hold", then you can't search worth a shit.
Then I'm stupid and you must be god. WTF do I search and since I'm so feeble how about a link ?
mikemcE is offline   Reply With Quote
Old 08-15-2016, 09:10 PM   #68
Eee pee missed that .....
Does explain why I can't find it
Old 08-15-2016, 09:11 PM   #69
I joined the Band!
Careful, you might want to edit and combine your posts so you don't get harassed by the moderators. They're really strict here and will bicker over every little thing.
Old 08-15-2016, 09:52 PM   #70
Looking up the specs as to what motor an esc is rated to run or what it's rated output is will get you a long way ahead. Just beware that tekin likes to over rate their esc's and under rate their motors.
Looking around seeing what others run will give you an idea as to what is working good. I'd actually recommend looking in threads without a bunch of stars next to them in the list. The popular builds all use the same ol parts under the hood.
WHITE-TRASH is offline   Reply With Quote
Old 08-15-2016, 11:42 PM   #71
Man
There sure is a lot of crying in this thread. But I have some positive info to add. I have a MMX running a Holmes XL 3500 in my Bomber that I specifically made to be a U4/all around general purpose rig. I also added a DMG kit to it to make the front IFS. (B1B #6) It's a total beast and my most fun vehicle between my scx10, berg and what I call my Bomb-yeti because I tore apart my yeti and robbed the front end for this. The on the fly drag is amazing and I run the damn thing on 4s without issues. Locked front or open. Doesn't matter. I have A MMP but No BLE. I chose the MMX because of the overkill and the aux wire functions and the fact I could eliminate the need for a external b.e.c. to power my hitec 7950 on 7.4v. My closest friends run BLE's and Tekin RX8's with Roc 3100's and they are tired of watching me rip past them. Did I say rip? I meant smoke the f*$k out of them.
I own tekin stuff but not in this.
the kil is offline   Reply With Quote
Old 08-15-2016, 11:47 PM   #72
I joined the Band!
Originally Posted by the kil View Post
Man
Good point I had forgotten, I dont run a BEC in my top truck either, the 8 amp internal BEC from the MMX powers my HV500 flawlessly.
I especially like the data logging, being able to plug in after a comp and see various info. Mine is set to record BEC voltage, Battery voltage, and ESC temp..
More than anything the MMX makes me resent not being able to see more info about the rest of my electronics, I'd really love to see a data log from a regular 10 amp CC BEC we are all familiar with.
Capwn is offline   Reply With Quote
Old 08-16-2016, 03:31 AM   #73
Originally Posted by K.C.'s RV View Post
...Also, you were saying about heavy trucks. This Bomber when I'm done is gonna be a have truck. Going to have many aluminum upgrades, Vanquish Titanium links, Vanquish aluminum axles, all that stuff, and I'll be custom fabricating a aluminum roll cage and then I'm putting aluminum panels on it. Oh, and also I'm going to be putting the Super Shafty stainless steel trailing arms on it, which weigh 3.6 pounds.
Whiskey Tango Foxtrot, ol' chap?
Brake Weight is offline   Reply With Quote
Old 08-16-2016, 04:41 AM   #74
I joined the Band!
Is there an issue, ma'am?
Old 08-16-2016, 04:50 AM   #75
This shit'll never happen. I don't think you could 'custom fabricate' body panels out of your old Donald Duck cans. Let alone an aluminum cage.
#CamBrady2017
Old 08-16-2016, 08:02 AM   #76
I joined the Band!
#CamBrady2017
I'm not fabricating body panels. I'm buying Barndog Racing's ones. I never said I was fabricating panels, only the roll cage. And then I'm fabricating an aluminum rollcage out of aluminium rod, check out BGR Fabrications' RR10 Bomber roll cage, it looks sweet! And whats with these Donald duck cans? Also, how about you stfu? Because that would be great. As*hole.
Old 08-16-2016, 08:33 AM   #77
That's the way you swear and get banned, fyi.... Personal insults including obscenities. Just letting one fly conversationaly isn't usually a problem. Just trying to help, not incite more problems, BTW.
durok is offline   Reply With Quote
Old 08-16-2016, 08:35 AM   #78
Are you guys talking about the mamba monster x or the mamba micro x??hahahaha!! Lots of love in here....
shiftauto is offline   Reply With Quote
Old 08-16-2016, 08:39 AM   #79
Not sure, I stopped paying attention to the dream build that'll never come to fruition a while back. I'm just spitting out random thoughts on esc's whenever the mood suits me.
Old 08-16-2016, 08:43 AM   #80
Is An MMX And HH Puller Pro Good For A RR10 Bomber? - Similar Threads
tekin roc 412 or tekin fxr hand wound 35t DTA510 Axial SCX-10 10 12-23-2015 05:28 PM
tekin roc 412 or tekin fxr hand wound 35t DTA510 Formula Offroad 0 12-20-2015 09:29 PM
