09-10-2016, 05:37 AM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
| Hiking & Crawling
09-11-2016, 10:08 PM | #2 |
Newbie Join Date: Feb 2015 Location: The middle
| Re: Hiking & Crawling
I don't hike for crawling but hunting and a good external frame pack so you could tie stuff to it
09-11-2016, 10:21 PM | #3 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
I hike and run trucks all the time. Regularly do 2-3 mile trail runs with the truck running the whole time. It's great because my wife comes and she loves hiking and just being outside while I get to play with my toys. I just bring the things you listed and normal hiking supplies like Clif bars and water in a nice soft pack I have. The pack has lashing points on the outside that go around the truck axle perfectly in case I break something and have to carry the truck out which has happened a few times. Also nice if you need to do any climbing and you need two hands free. It's rare these days I don't measure my RC outings in miles.
09-12-2016, 06:29 AM | #4 |
09-13-2016, 10:25 PM | #5 |
Rock Stacker Join Date: Aug 2005 Location: Spain
Hello, here are some pictures and info about this activity that I practice for more than 10 years ago https://www.facebook.com/TruckTrial/ also in this forum The best of my mountains hiking & crawling |
09-14-2016, 12:42 PM | #6 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
I'm pretty bad; I can't hardley even think about hiking without taking my crawler. There was a time in my life before rc crawlers when I would go hiking simply to have fun. Well now I don't even have fun hiking unless I'm packing; my crawler of course. I can be out for 4 hours on two batteries. I've missed dinner more than a few times lolol I have a Plano 2700 loaded with tools and a few spare parts like rod ends and spare driveshafts spurs and even axle shafts. Stuff it in a pack along with some candy bars water and coffee and off I go. The most important thing I've learned is to have extra transmitter batteries. I've so learned when I'm approaching a dog on the trail to pick up the truck. Some dogs go absolutely f'ing berserk over rc's so I try to avoid those kind of situations. Last edited by rngrchad; 09-14-2016 at 12:50 PM. |
09-14-2016, 01:17 PM | #7 |
Pebble Pounder Join Date: Jul 2013 Location: El Centro
Regularly hike 2-3 miles with my Rigs. I use one, my lady uses one. Most important thing for me is spare batteries for the rigs, as well as making sure everything is well put together on the rig. I have had many times where something comes loose, and even falls off (driveshaft). I don't notice it until it's too late. Just make sure you have all the necessary tools, and some possible spares. Be ready to carry it out if need be. -Corrupt |
09-14-2016, 02:05 PM | #8 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
Just curious - what are some of the specs for you guys' rigs that get taken out for miles at a time? In terms of gearing, motor and battery sizes. I guess I've run mine pretty far but never really paid much attention. Need to get back exercising and "playing" at the same time would be a better motivator than "because i need it" |
09-14-2016, 03:19 PM | #9 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
I routinely take mine out for hours and hours, we quite often trek 1-3 miles and sometimes even 3-5. It's just about the only decent exercise I get these days.. I run bone stock SCX10 gearing on either an 18.5T brushless or a 35T brushed motor; and for batteries I have 4 regulars - all are 3S, mAh's are 1800, 2200, 2200 & 2650, I also carry a couple 2S units for other people to use if they run short. I usually go through about 1000mAh per hour. As far as what to bring? Water, tools, spare parts, food, more water, more spare parts. I always keep a grocery bag in my pack to cover my Tx if it starts to rain. I need to figure out a cup holder that mounts to my Tx so I can take a coffee/beer with me though... |
09-14-2016, 11:20 PM | #10 |
My Emaxx mountaineer setup more setup pics https://www.facebook.com/media/set/?...1&l=a74f2c3d50 /Motors , Radio, -2 Integy 45T motors in parallel at 2s or 3S Lipo. Low power and high torque, very smooth. -1 CPU fan 60 mm , motor. -2 Al heatsinks. -1 Novak ESC fan -stock ESC -Airtronics-Sanwa 2.4 3 channels. //Battery, Charger. -48000 mah in 10 Lipos 2s/3s. 30 to 50c. Gens Ace, Jamara, Vant,Traxxas, Turnigy -4200 mah NiMh 9,6 V to power Led lights in emergency. -1 Rx lipo 2200 mah + 1 Rx Nimh 1600 mah in emergency. -Lipo Battery Voltage display integrated in the rear bumper. -SkyRc D100, Imax B6 and Digipeak chargers //Rims and tires, summer: -Axial_ax8046 Beadlock rims, 3.8" 40 series. -Proline Trencher 3.8" 40 series. //Rims and tires, winter: -Proline Velocity 3.8" 40 series. Mip steel Cvd, front -Traxxas E-Revo style axles and carrier, rear -Robinson Racing diff gears. -2 Traxxas diff spool lock. -Integy Al diff case //Driveline, suspension -Rpm arms, front. -Rpm axle carrier, front -Rpm Truetrack, rear. -Hitec 645 MG Servo -Traxxas Big Bore shocks. 1b position. -Silicone oil. 50 front, 60 rear. -Custom dual spring rate, soft 10 mm + hard 55 mm. -Integy shock spring set Tmaxx -red-. //Bumpers & Skid plates -Rpm bumpers -Custom skid plate ,front -Rpm skid plate ,center. -Integy Al skid plate, rear //Hardware, Bearings -All external bearings rubber sealed //Body -Proline F650 body. Daylight. -Proline Humvee body , 2 * 7W 12V led, 1400 lumens. Night rides. |
09-21-2016, 04:40 PM | #11 |
Newbie Join Date: Nov 2015 Location: Canada
Pretty much all my crawling involves hiking. I don't bring anything special with me, so if the truck breaks (hasn't happened yet), I guess I'll just pick it up and turn around. I did run out of battery power once, so had to coast it downhill for the last bit, but haven't had any issues since I switched to brushless. I don't bring a spare, but I get a solid 2 hours out of my 5,000mAh battery, which is plenty. I have a great little hike nearby that I go to with the dogs and my Wraith. Internet says it's 4 kms to the peak, with 600m elevation gain. So far, I figure I've been about 2/3 of the way up. Not sure if it will be possible to make it to the peak with the truck, but there's only 2 small ledges on the bottom 2/3 that require the "Hand of God," otherwise it's all driveable. Best part is that the trail is on an exposed ridgeline, in a super windy spot, with southern exposure, so the bottom half stays bare of snow almost all winter (at least it did last winter.) |
09-21-2016, 05:36 PM | #12 |
Beautiful pics Helicrawler.
Hiking & Crawling - Similar Threads | ||||
The best of my mountains hiking & crawling | trucktrial | Traxxas Crawlers | 127 | 02-17-2024 06:05 AM |
RS10XT good for R/C hiking? | 2WheelFlyer | Redcat Crawlers | 10 | 03-21-2013 10:24 AM |
What R/C for hiking? | justadork | Newbie General | 23 | 02-07-2013 02:12 PM |
went hiking today | Dfrog | Axial SCX-10 | 10 | 02-08-2011 04:38 PM |
Need a hiking pack. | mrwonderful | Chit Chat | 9 | 07-27-2006 07:14 PM |
