Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: Codyboy Coast to Coast to Coast in 45 days!!
Old 10-24-2016, 08:37 PM   #121
Default Re: Codyboy Coast to Coast to Coast in 45 days!!
Thank God it's not a 6.0! Ok then. Water in fuel will typically give you a shutter and or miss fires. Lack of power with engine still running smooth and no engine light is most likely lack of fuel, fuel pressure or lack of air. I have seen a plastic bag get sucked up off the road causing a restriction in air intake. Caused low power and a lose of fuel mileage. Also gas is allowed to have more contaminants than it did several years ago. I see plugged fuel filters causing problems like yours almost weekly. Even a throttle position sensor can cause power lose, but typically will end up throwing a lean code. Honestly it's hard to diagnose something you can see, hear run and hook a scanner. If you'd just came up my way, I could have checked her out and got you squared away
Jeepiac is offline   Reply With Quote
Old 10-24-2016, 09:17 PM   #122
CODYBOY's Avatar
Originally Posted by Jeepiac View Post
Now that's what I'd call hard rock porn....You knew somebody was going there
Somehow I knew it would be you!
Originally Posted by Natedog View Post
Awesome pics thanks Ernie!
Could be pinhole in fuel pickup tube inside tank. Could be moisture corrosion related or not.
Most modern fuel systems have two fuel pumps, pickup lower pressure and high pressure near the injectors. In tank pump could be weak and less fuel in tank is less fuel weight pressing down and helping pickup pump.
Just some things I've seen before, can be difficult to find problems like this.
That makes sense.
[QUOTE=snapon boy;5579278]I had to upgrade my lift pump when I hopped up my 12v. It was starving for fuel.
Sent from my SAMSUNG-SM-N900A using Tapatalk[/QUOTE
Originally Posted by BigSki View Post
" Don't even go there "
answer to gas/water weight: I looked up the specific gravities of each, at 60* F:
Water- 0.998
Gasoline- 0.713
Conclusion: water has a higher density, so it would be "heavier". It would go to the bottom of the tank. That would explain a lot. Short of draining the tank, maybe some 'dry gas' type of chemical additive ( as mentioned above) might help a bit.
Beautiful scenery!! One of the few times I'd like to be able to do a multiple "like"
I like the additive idea best!
Diesel motor home, but water specific gravity still higher.
Ok, Day 41 (I think)
A long day, 398 miles, made it to Tonopah Nevada, and crossed our last time change!
Thought I would start off with is.
I was glad to put this storm behind us, I mean it flat poured!
I tell you what, it is barren in northwest corner of Utah and southwest corner of Nevada. We were traveling HWY 50 and there was times when we didn't pass an oncoming car for 30 minutes or see a ranch for an hour.
"Oh lonely road" the wind was blowing so hard, and mostly cross/head winds. Once driving into a head wind, it was blowing so hard I was having trouble maintaining 60 mph and a 18 wheeler met us and as it passed it cause the Motorhome to kick into passing gear!!!
But all in all it was a great day of traveling, end saw a little wildlife.
Next we saw a sign saying Bighorn Sheep country. So Marcia and I strapped on our hiking boots and started climbing the rocks!!! We got up to around 6500' and stumbled on to these two guys
Come to think of it, I think the motorhome was doing most of the climbing, they crossed the road right in front of us, went up the hill and stopped. It was kind if like ok we will stop for just a couple pictures!
And then, we are out of here!
I think we will make it through Yosemite tomorrow??
Later"thumbsup
Marcia and Ernie
CODYBOY is offline   Reply With Quote
Old 10-26-2016, 01:07 PM   #123
Rhett wants to know when you will be back. it is amazing how you two leave such a profound impression with folks as you travel. I can't imagine how good it makes you feel to have friends from coast to coast. Karma.
SHOme is offline   Reply With Quote
Old 10-27-2016, 10:43 AM   #124
CODYBOY's Avatar
Thank you my friend for the kind words! It has been a great trip, and we feel that we have not only formed new friendships, but have extended our family from New Hampshire to Oregon.
OK, Day 44 and still in California visiting with family in Hilmar. This is the town I grew up in.
I think you guys are getting tired of the travel photos so not posting any today.
We will be moving on from here to Natedog's, near Sacramento tomorrow. Marcia and I are really looking forward to the visit!!!
See you tomorrow Nate, and you did ask me to bring the rain with us, right??
Ernie and Marcia
Old 10-27-2016, 10:57 AM   #125
Natedog's Avatar
Sounds good, looking forward to seeing y'all and the rain.
Old 10-27-2016, 07:05 PM   #126
Pictures are always good Ernie, makes those of us that are too busy enjoy being right there with you and Marcia
Mike Flea is offline   Reply With Quote
Old 10-28-2016, 07:45 AM   #127
These pictures are incredible... especially the bear ones.
Habanero is offline   Reply With Quote
Old 10-28-2016, 08:48 AM   #128
No idea what I'm doing
Agreed! A travel thread without pictures? No way.
More pics please!
C*H*U*D is offline   Reply With Quote
Old 10-28-2016, 09:27 AM   #129
Definitely more pic's, or we'll feel like you left us on the side of the road.
..... in Utah. :-(
.... and Thanks again.
dr frankenstyle is offline   Reply With Quote
Old 10-28-2016, 12:23 PM   #130
CODYBOY's Avatar
So Nate, it rained all night here in Hilmar, do I still need to bring it with me, or are you getting it in Sac?
Ok, sorry I just thought you guys were tired of seeing them!
Thanks Hab, it has been a great trip!
More pics please!
Ok CHUD, I didn't know yo were following along, so here you go.
..... in Utah. :-(
Sorry DOC, headed back to get you now!!!
Day 44, these are coming from Nevada and into California on HWY 120 and 140 going through the park!
Still in Nevada.
Crossing over the California border, snow on the Sierras.
Some Mono Lake history and the old gold mining town of Bodie. If you are history buffs google them, it is very interesting. We go into Bodie most every time we come through California on 395. But I didn't want to take the motorhome on that rough road, sorry, no pics of it.
You can see the cinder cone on the island and the tufas along the southeast shore.
Ok, climbing up and over the 9300+ pass into the park.
I was amazed at all of the bug kill in the park, they are really primed for a huge fire in the next couple years!!!!
I found this boulder very interesting!
The only pass that was higher than this one was coming over the Rockies, 11380'.
Ok, off to Nateogs in a little while!
More later, thanks for looking.
Marcia and Ernie
Old 10-28-2016, 12:34 PM   #131
Natedog's Avatar
Thanks for pic update, love Bodie, Mono Lake, Kit Carson Pass etc. lots of beautiful scenery all year round. See you soon!
Old 10-28-2016, 03:14 PM   #132
We need a like thread button!
hpiguy is offline   Reply With Quote
Old 10-28-2016, 03:19 PM   #133
You can rate the thread at the top. I gave it 5 awhile ago
Old 10-29-2016, 01:35 PM   #134
Natedog's Avatar
Yes, 5star rated here too. Ernie and Marcia, good to meet y'all in person, enjoyed our visit and you're welcome back anytime!
Nate and Thim
Old 10-29-2016, 02:01 PM   #135
Oppan Gangnam Style
chino63's Avatar
I love these road trip threads! I've been on a few myself and would really like to do another one. I've been wanting to go to Bodie since I was a kid, still trying to get to that area as well as Bishop CA. Thanks for sharing your adventures!
chino63 is offline   Reply With Quote
Old 10-30-2016, 12:49 PM   #136
I don't really get on here much anymore but I will say I have been following this thread closely. Thank's for taking the time to post all the pics to share with us on here.
lilpanther is offline   Reply With Quote
Old 10-30-2016, 07:29 PM   #137
CODYBOY's Avatar
Thank you hpiguy.
Thanks for the thread rating, I'm really glad it has been worth viewing to all of you.
Ernie
We have been to Bodie 4 or 5 times, I just really like the history and how the park has been restored. If you would like to see some Bodie pics I could post up some. You need to quit thinking about it, and make the trip!!!
Ernie
Hey lilpanther, thanks for following our trip, you all need to put something like it on your bucket list.
Day 47, what a trip!!!
We made it home this afternoon, thank the Lord for a safe and fun trip!! I plan a close out tomorrow with some of the facts and final pics.
Anything in particular that any of you might want to know.
Old 10-30-2016, 08:30 PM   #138
Total miles driven, fuel burned, best meal, favorite state, souvenirs you brought home and when's the axle production start back up
Thanks for taking us along and I think I can speak for everyone when I say we're glad you made it home safely. Even though the trip is over, I bet this thread will continue for a while
Old 10-30-2016, 08:39 PM   #139
snapon boy's Avatar
The pictures are amazing. Ive traveled a lot but I was working for Waukesha and we were half awake and not paying attention to the beauty of the country we were passing through. Thanks for taking the time to post what I missed and will have to revisit these places.
snapon boy is offline   Reply With Quote
Old 10-30-2016, 09:23 PM   #140
So glad you guys made it home safe and sound.
What an adventure! Thank you for sharing it with everyone.
I am curious about the miles driven, and fuel burned. And maybe a top 10 (or 5) location countdown, favorite being #1 of course.
Poprivet is offline   Reply With Quote
Codyboy Coast to Coast to Coast in 45 days!! - Similar Threads
North coast? summitcrawler Oregon 1 05-12-2012 05:49 PM
Coast get Together spankrjs Mississippi 2 09-11-2008 06:30 AM
Coast boys blackcatnastang Mississippi 3 06-06-2008 10:51 PM
Anyone near the NW coast of oregon? MaxxZilla Oregon 0 11-18-2005 09:13 PM
