04-11-2017, 11:17 PM | #81 |
| Re: Napa pissed me off
I don't know Things can be pretty strange like Want more beer (Did I do that right?) Edit: nope, it's 5, 7, 5 and I did 3, 7, 3 Last edited by EeePee; 04-11-2017 at 11:23 PM. |
04-11-2017, 11:27 PM | #82 |
I'll try again. I don't know bzzzt ding Things can be pretty bzzzzt ding Strange as shit bzzzzt ding |
04-11-2017, 11:37 PM | #83 |
Rock Crawler Join Date: Oct 2012 Location: Casper
lmao perfect I hate haiku |
04-12-2017, 07:40 AM | #84 | |
| Re: Napa pissed me off Quote:
I usually try to stay out of your threads...they give me bad dreams and make me poop a lot...but this one is just another example of how confrontational you are. Not just here on RCC, but in person too. It's almost like you wear it as a badge of honor or something. The hose popping off after doing all that work wasn't Karma. It was all of us collectively thinking to ourselves, "Just let this shit end already"! Karma's a bitch, but you pick at it like an old scab and then you're shocked with the results...you make your own circumstances. | |
04-12-2017, 02:33 PM | #85 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
You can close your eyes and pretend it's all a bad dream That's how I get by almost everyday of my life, My Mom passed in 2006, it ****ed me up, cause she always had my back, and my Dad started having health problems and when he passed in 2012, it really ****ed me up and I've been lost ever since And its the same shit year after year, I got a good women that loves me, and keeps me grounded, other wise I'd be in a even darker place, then I am now and ****ing out there man and ****ing loving it I promised my girl, I would take it down a notch but never said for how long Last edited by kgb424; 04-12-2017 at 02:37 PM. |
04-12-2017, 02:38 PM | #86 |
Many of have had worse, but if you want something YOU have to earn it and work for it...... Karma ?? Yeah that is always bs Hang up and Drive |
04-12-2017, 06:36 PM | #87 |
Quarry Creeper Join Date: Nov 2006 Location: DeSoto
| Re: Napa pissed me off |
04-13-2017, 01:08 AM | #88 |
Nope not going there, but will share a side project my 1983 Tamiya Brat I made brackets to center the steering servo and lengthened the connecting rods Still need to power up the servo to center it and see how the wheels turn cause there is a lot of play in the steering But that's the way the vintage RC's were, that's part of the fun when running one Last edited by kgb424; 12-11-2018 at 01:06 AM. |
04-25-2017, 02:12 PM | #89 |
I took the Toyota dash board apart enough to see the top of the heater core, where the O-rings and tubes connect and started the truck and let it idle and warm up It took a couple minutes and I could see bubbling on the right connector and it pissed out antifreeze again, now I know its the seal were the O-rings seat I called the local Radiator shop and going down there in the morning, they are going to replace the O-rings and seat the tubes and pressure test the core I hope that fixes the leaks, and got a working heater and defroster Last edited by kgb424; 12-11-2018 at 01:05 AM. |
04-25-2017, 02:45 PM | #90 |
I took the core out, and took the clamp off of the tubes and found the one on the right side, the tube is unseated and the u shape retainer has came loose I'm hoping with the right sized O-rings, the tubes will seat and retainer clips will stay in place and not leak the second time around Last edited by kgb424; 12-11-2018 at 01:05 AM. |
04-26-2017, 07:18 AM | #91 |
Quarry Creeper Join Date: May 2009 Location: India
WTF! How on earth did you manage good english? Good job on the yota Probably that ends your trouble this time. Last edited by wings_of_fire; 04-26-2017 at 07:40 AM. |
04-26-2017, 10:07 AM | #92 |
Thanks Chicken Wings, I can do good English when I want too The radiator shop was able to replace the O-rings and seat the tubes and pressure test the core, and it doesn't leak, they didn't charge me, I will have bring them some beer as a thank you Now just waiting until it warms up a little to work the Toyota, its cold and shitty and might rain, waiting on the weather again Last edited by kgb424; 04-26-2017 at 11:22 AM. |
04-27-2017, 08:44 PM | #93 |
I started putting the dashboard back together and got about 95% done, when I hooked up the hood release cable, and pulled it to test it out, and it wouldn't open the hood cause I thought the cable stretched So I had to yank on it, the hood popped open, I took the hood latch out and found the plastic piece on the end of the cable was broke, and no longer releasing the hood latch I ripped the barrel off the end of the cable when I yanked on it, but did get the hood open and the cable is easy to replace Last edited by kgb424; 12-11-2018 at 01:05 AM. |
05-11-2017, 10:08 PM | #94 |
It's on, I'm fixing my heater core, and do it this way, with some 3/4'' ID Silicon heater hose and some 1'' ID heater hose and some High Temp RTV and 4 1 1/2'' hose clamps I have to due it this way, cause I can not find a copper heater core to solder the tubes and they do not make aluminum tubes too weld to the aluminum cores I got the first part done and letting the RTV cure completely before I attach the clips and try to slide the bigger hose over Last edited by kgb424; 12-11-2018 at 01:04 AM. |
05-17-2017, 10:56 PM | #95 |
Alrighty then The guy at the radiator shop helped me again to seat the tubes and assemble the pieces of hose and the clamps It was pressure tested again and no leaks, and the tubes are solid this time, now they shouldn't move when I connect the inlet and outlet hoses Going to connect the heater core and start the truck and let it idle until it warms up and see if it leaks before I start reassembling the dash board For the third time, I hope this fixes it Last edited by kgb424; 12-11-2018 at 01:04 AM. |
05-17-2017, 11:21 PM | #96 |
Rock Crawler Join Date: Apr 2014 Location: Portland
Third times a Charm. Good luck.. |
05-18-2017, 07:30 AM | #97 |
Pebble Pounder Join Date: Jan 2005 Location: st. louis
So over a month without your vehicle, multiple trips to parts store, and multiple times taking dash apart.. all to save $640. Not sure what your time is worth, but I would have paid the $640 to the guy that does it all the time and had my shit up and running a month ago, with less aggravation, and month to do other projects.. |
05-18-2017, 05:21 PM | #98 |
Yeah Baby I got this time, I started the truck and let it idle and warm up and there are no leaks and I now got heat I checked everything out before I put the dashboard back together, it took me awhile And I almost gave up, but My Momma didn't raise No Quitters, I got it Smarter then a XXXXXXXX Toyota at least today I am Last edited by kgb424; 05-18-2017 at 05:34 PM. |
05-18-2017, 05:50 PM | #99 |
05-18-2017, 09:11 PM | #100 | |
Tags |
#bestpartrandownmommasleg, #ipissexcellence, #painfultowatchandread, #wilthisguyevergetabrain? |
Napa pissed me off - Similar Threads | ||||
Napa free test and tune | Tin Soldier | Pennsylvania | 0 | 02-03-2014 08:52 PM |
my future 1.55 rig: the napa s10 | AX10wannabe | General Scale Talk | 6 | 11-16-2013 06:46 PM |
Help with older Napa R/C car | Bobbyocean | Non Crawler RC's | 0 | 03-31-2012 10:36 PM |
