02-24-2019, 05:29 PM | #81 | |
Quarry Creeper Join Date: Aug 2014 Location: Los Angeles
| Re: Proline Releases a $600 Lexan Body <-That's not a typo Quote:
02-24-2019, 05:33 PM | #82 | |
02-24-2019, 05:45 PM | #83 | |
You only have to pay $600+ if you want it built a certain way and printed by Shapeways. Like all our builds using our parts, they get stupid expensive only if you want them too. Last edited by Toykid; 02-24-2019 at 09:38 PM. | |
02-24-2019, 05:57 PM | #84 |
Stupid expensive... Stupid expensive... Stupid expensive... It’s just what we do Sent from my iPhone using Tapatalk |
02-24-2019, 06:35 PM | #85 |
Wowsers is what I say! If you ever need a southern swamp tester send me a DM! I wouldn’t want to paint the shell, But detail everything else. Hang up and Drive |
02-24-2019, 07:18 PM | #86 |
I wanna be Dave Join Date: Dec 2006 Location: here
I didn't understand how 3d printed parts are so expensive.
02-24-2019, 07:30 PM | #87 |
| Proline Releases a $600 Lexan Body <-That's not a typo Quality parts on a large number need a quality machine and a well drawn .stl file from CAD. High $$$ machines and wages also Some machines extrude, others use a high end deposit practice...... more cost. Then add mark up for a profit. Shapeways makes great parts, but at High prices. They can print metal too. It’s a new quick method with relatively new company’s starting to use it. Hang up and Drive Last edited by mikemcE; 02-24-2019 at 07:36 PM. |
02-24-2019, 08:38 PM | #88 | |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
Thanks | |
02-24-2019, 09:18 PM | #89 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Proline Releases a $600 Lexan Body <-That's not a typo |
02-24-2019, 09:23 PM | #90 |
| Re: Proline Releases a $600 Lexan Body <-That's not a typo Correct. We will have some alternate lens styles in resin, whilst high in detail they are more fragile. We found with the Axial Honcho grills we did that you can get some good results using the lexan lens, and this certainly makes the body more durable. so we applied that learning to this design.
02-24-2019, 10:47 PM | #91 | |
02-25-2019, 04:10 AM | #92 | |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
02-25-2019, 06:11 AM | #93 |
| Re: Proline Releases a $600 Lexan Body <-That's not a typo You have to remember that Shapeways uses industrial resin printers that cost six figures. They have to recoup the costs of those machines. On top of that, they are the best at what they do right now. I haven't found a company that makes a higher quality print and they offer so many different materials. They are at the leading edge of 3D printing and being at the leading edge is never cheap. Plus, they have to profit while they can because, in my opinion, the days of print houses are numbered. Eventually anybody that wants one will be able to afford a resin printer for their home. |
02-25-2019, 06:44 AM | #94 | ||
Moderator Join Date: Aug 2017 Location: Readsboro, VT
02-25-2019, 06:50 AM | #95 |
02-25-2019, 07:05 AM | #96 |
| Re: Proline Releases a $600 Lexan Body <-That's not a typo I'd only be guessing when resin printers will be commonplace in the home. With the way technology advances I'd say within 5 years, but that's just a guess. You can actually have one now. It all depends on the build volume, print speed, print quality you require and, of course, your budget. Monoprice has a small 120mm x 70mm x 200mm resin printer for $400 and FormLabs has one that has a build volume of 145mm x 145mm x 175mm for around $3,500. As you can see the build volumes aren't all that different, but the price difference is substantial. I don't know anything about the Monoprice printer, but the FormLabs printers produce stunning results. The parts look molded. Here are parts that StangKill SS got printed on a FormLabs Fusion 2 printer. Source: https://www.facebook.com/TheScaleSho...type=3&theater Last edited by JatoTheRipper; 02-25-2019 at 07:09 AM. |
02-25-2019, 09:47 AM | #97 |
Resin printers are also extremely toxic. Both the raw materials, the printed plastic, and the fumes created. I had a dlp Photon ($500), which is pretty fast and accurate for the price but also had a good bit of flex to the frame. So any hard transitions of volume made the part warp a bit, requiring tilting the parts or sticking to more organic shapes. There are some better 4k resin printers for the $1000 range, but it is still a crap shoot on screen life. Sticking to name brands is the best bet for anybody looking to produce commercially. It's a dangerous process to deal with, health wise. Didn't want it in my shop or home, didn't want to deal with the cleanup of said toxic plastics and resins. Sold my resin printer and haven't regretted it. The break even for a LOW COST industrial printer is $3 an hour running 24/7, plus shop overhead. A 5 year service life is typical to keep up with tech, trade the old one in and re-up on a new machine to keep your business as fast as the Joneses. So realistically you can expect $5 to $6 an hour to barely turn a profit. What Shapeways will do is load up multiple projects that are using the same material to reduce the amount of time spent in setup/ teardown between runs and time spent between layer changes. So charge $5 an hour per part and gain a little efficiency by filling up the bed with parts. It aint a fun business to run. I've done a yearly assessment of buying an industrial printer and keep circling back to a big NOPE. I would rather buy an industrial Mill or Lathe again. |
02-25-2019, 09:53 AM | #98 |
More to the point of printing yourself and "saving" money, the best intersection of value would be to print on a normal printer in ABS and vapor smooth or bondo and paint it to a perfect look. Nylon is great too, but materials costs can quickly make Shapeways look pretty nice. But that is still trading a lot of time for money.
02-25-2019, 10:44 AM | #99 |
RCC Addict Join Date: Aug 2005 Location: Pocatello
So I'm starting to understand a little more the process involved and the cost that goes along with it. I really like the concept that Pro-Line and Knight Designs has introduced, and people will buy it, just not myself at this time. I was curious as to why a snorkel wasn't introduced? Most overland rigs are all gonna run snorkels. Sent from my moto g(6) using Tapatalk |
02-25-2019, 09:17 PM | #100 |
Pebble Pounder Join Date: Dec 2013 Location: Canada
This thread/post mades me chuckle,it`s kinds like people are complaining about a blank canvas that ahsn`t had a work of art painted on because its a blank canvas |
Proline Releases a $600 Lexan Body <-That's not a typo - Similar Threads | ||||
proline k5 Blazer + proline lexan interior? | STANG KILLA SS | General Scale Talk | 2 | 06-27-2011 06:14 PM |
Painting my XJ PROLINE SCX10 Lexan Body | rusty577 | Paint and Body | 0 | 02-22-2011 04:57 AM |
Clod Style lexan body???? not the proline 80 model. | Stangrocka | Paint and Body | 5 | 05-26-2010 10:10 AM |
Axial Releases Dingo Truck Body | whipnet | Paint and Body | 32 | 08-26-2009 03:37 PM |
