Go Back   RCCrawler Forums > Miscellaneous > Chit Chat
Thread: 2020 can-am maverick x3 x rc turbo rr rock crawling review
Old 10-31-2019, 12:52 AM   #1
Default 2020 can-am maverick x3 x rc turbo rr rock crawling review
We recently picked up a new 2020 Can-Am Maverick X3 X RC Turbo RR. First we took it on a quick desert ride in Nevada, then we wanted to try it out in the rocks, so we scheduled a trip to the world famous Rubicon Trail here in Northern California.
The big changes for the 2020 Can-Am Maverick X3 X RC Turbo RR are:
32-inch Maxxis Liberty tires (up from 30″)
195HP (up from 172HP)
CVT was recalibrated to match the new performance levels, larger tires and improve belt longevity.
7.6-in. digital display. An all-new onboard keypad simplifies drive mode, trip and DPS selection.
2020 Can-Am Maverick X3 X RC on the Rubicon Trail
Smart-Lok Front Differential
The X3 RC first came out a few years back and the big advance for this model was the Smart-Lok front differential. The Smart-Lok system has two automatic modes for 4×4: Rock and Trail. Rock mode is all automatic and works very well for most rock crawling situations. But the unique thing about Can-Am’s Smart-Lok is they also allow you to fully lock the front differential as well. This system is a blend of all other manufacturers systems and works very well in extreme terrain and for all driver’s style/preference.
Nothing has changed for the 2020 Can-Am Maverick X3 X RC Smart-Lok Front Differential, so here is a quick demonstration we filmed for the 2018 model that still applies:
For our trip to the Rubicon, I wanted to focus in on the tire size changes and the CVT calibration since these features are a big deal for technical rock crawling. More horsepower doesn’t really apply on the Rubicon, but it sure makes a difference in the dunes and desert. Plus if you want to race King of the Hammers, big horsepower definitely comes into play for qualifying and also for the desert loop.
Rubicon Trail
We decided to do a day trip and try to cover all the more difficult parts of the trail, then turn around and get back before sunset. This takes you through Little Sluice, down to Buck Island, down Big Sluice, into Rubicon Springs and then up Cadillac Hill. We also added Old Sluice which is much more difficult than the slabs when coming down the hill to Buch=k Island. Once you turn around at the Observation Point at the top of Cadillac Hill, it is like you are on a different trail . This that were easy dropping off, become more difficult ascending.
One thing to note is all rock crawling is not the same. Some features that are a minus on the Rubicon (e.g. longer wheelbase) are a plus in Moab.
Low range gearing is low enough to allow for extreme technical challenges without belt slip.
32-inch tires stock with enough clearance for 35-inch tires and a low range that is geared low enough to do so without worrying about belt slip.
Smart-Lok front differential system works well and has something for every situation and personal taste.
4-point harnesses are comfortable and allow for shoulder movement.
Great suspension articulation.
Comes with a winch already installed.
Comes with a HMW skid plate,additional rocker protection and suspension protection.
I want a vehicle that can handle all terrain (rocks, desert and dunes) well, and the X3 X RC is certainly top of the food chain.
Can-Am finally has the ride height set appropriately from the factory
cleoleach is offline   Reply With Quote
Old 10-31-2019, 06:21 AM   #2
Default Re: 2020 can-am maverick x3 x rc turbo rr rock crawling review
What exactly do they do in CVT calibration?
I am guessing they don't change the cones but probably change belts with greater contact area or higher coefficient of friction.
wings_of_fire is offline   Reply With Quote
Tags
rccrawler
2020 can-am maverick x3 x rc turbo rr rock crawling review - Similar Threads
C3 twin turbo W.E. ROCK buggy "Mog Sled" distinctive pd 2.2 Scale Rigs 30 02-14-2021 06:51 PM
