| | #1 |
| Rock Crawler Join Date: Nov 2004 Location: Thats a Good question
| So i picked up a project truck and decided to put a cd player in it. the guy that owned it before me had one in is so all the wiring was there and did work. I hooked everything up and NOTHING. I checked the fuses, all good, so my problem is somewhere in the wires, anyone know of anything else to check before i spaz.????? |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jun 2006 Location: Massachusetts
| did you use the existing wiring harness from the old deck? |
| | #3 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| First you need to find a volt meter. Next test the yellow wire with the vehicle on or off and make sure it has at least 12 volts. Next test red wire with the vehicle off and make sure it has no power. then turn the key on and make sure there is 12 volts. Make sure you black wire has a good ground, you can just take it strait to bare metal if it isn't already. Just hook those wires up only, leave the speaker wires off to test it. That will take care of it. Josh |
| | #4 |
| Rock Stacker Join Date: Nov 2006 Location: wixom
| What year? |
| | #5 |
| The wires are smoked. Its a 93 dakota, using the "factory" harness and an adaptor. The yellow wire has no power at all, same with the red. Fuses are all good, even swapped in a new one. So im gussing i have a short somewhere between the fusebox, and the end of the harness. |
| Thread Tools | |
| Display Modes | |
