06-03-2007, 08:34 AM | #1 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
| savage 25
does anyone know how to adjust the motor from being top speed to acceleration? if so can you describe well or show pics thanks Dave |
06-03-2007, 09:04 AM | #2 |
RCC Addict Join Date: Jan 2006 Location: Irritable Isle
Replace the clutch bell with one with fewer teeth. Turn the two-speed adjustment screw in to delay the shift. |
06-03-2007, 09:24 AM | #3 |
RCC Addict Join Date: May 2006 Location: California
It's like skeeno said, the gear ratio that makes that. I think it is the higher spur gear teeth, and lower teeth on the clutch.
06-03-2007, 09:28 AM | #4 |
it just seems to have no power because when my friend bought it (i made this thread for him) he was under the impression it could do wheelies but it can only just move itself!
06-03-2007, 09:33 AM | #5 |
It has to be tuned perfect for it to do wheelies. Or at least good enough to not bog down, and not be to lean. Then it will be quicker, and might do the wheely then.
06-04-2007, 04:19 AM | #6 |
I wanna be Dave Join Date: Nov 2005 Location: Here
I only was able to do wheelies when I changed to a Wasp .28. Then it was annoying so I added the long chassis (which I am selling). Savage was not made for wheelies. Tmaxx was the master of that...
06-04-2007, 04:42 AM | #7 |
RCC Addict Join Date: May 2006 Location: Aroostook county
| I would have to say the HPI Wheely King is the master of that. lol
06-04-2007, 07:44 AM | #8 |
Quarry Creeper Join Date: May 2007 Location: Brenham, Tx
lean out your lsn about an 1/8th stiffen up the rear shocks run a 13t clutch bell You can keep leaning your lsn until it sounds like popcorn after you release the trigger from wot. then richen it back up a little and you'll be set. What glowplug are you using? I think i ran the mc-59 in my s25. and then the OS #8 in the OS .30 a stock savage can wheely with no problems. |
06-04-2007, 08:52 AM | #9 |
Pebble Pounder Join Date: Apr 2007 Location: Deer Park
The way to know if your low speed needle is set properly is to run your truck around the yard a bit to get it to running temperature. When it is warm bring it in and pinch the fuel tubing until the engine cuts off. The rpm's should increase for about a second or so with the engine shutting off within 2 or 3 seconds. If the engine takes longer you can afford to lean it out a bit. If it runs up and falls on its face real quick its too lean. To get that vehicle to do wheelies you need to have the low end at its optimum tune. Its so long an heavy it wont want to do it on pavement but in grass it should do it with ease if tuned right
06-04-2007, 08:57 AM | #10 |
just to add to what he said. let the truck get to running temp and then let it sit for about 30 seconds. go WOT and if its really sluggish and pours smoke. you are too rich. |
06-04-2007, 12:19 PM | #11 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
Oh and all the vids of the hpi savage doing wheelies on their site are done by profesinals at hpi they know the truck inside and out lol
