08-14-2007, 12:02 PM | #1 |
Rock Crawler Join Date: May 2004 Location: delavan
| lift kit
any one know were i can get a 4 inch suspension lift kit for around 600.00 for a 1990 chevy truck 3/4 ton 4wd every were i look the cheapest is 1200
08-14-2007, 12:04 PM | #2 |
RCC Addict Join Date: May 2006 Location: Aroostook county
make one... |
08-14-2007, 12:09 PM | #3 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
Ebay?
08-14-2007, 12:09 PM | #4 |
Does it have Leafs all the way around or no?
08-14-2007, 12:10 PM | #5 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
90 chevy should have IFS.
08-14-2007, 12:14 PM | #6 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
With the IFS your not gonna find anything that cheap unless you do blocks in the rear and crank the torsion bars and do a body lift.
08-14-2007, 12:16 PM | #7 | |
You should be able to find a 4in lift for $600 I would think...I'll look around for ya. Body Lift from BDS. http://www.bds-suspension.com/kits/9319 Rough Country. But it's listed for 1500 http://www.roughcountry.com/chevy_4wd_88-98_2-3.html Started looking around. Your Right.. There isn't much out there under 900.. I'd save your money a little longer and get a full kit. Last edited by run2jeepn; 08-14-2007 at 12:26 PM. | |
08-14-2007, 12:16 PM | #8 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
08-14-2007, 12:28 PM | #9 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
| Body lifts are ghey. The maximum body lift you would ever want to do is 1", any higher than that it mess with all your shifter linkages,steering column etc. Look around, you might be able to find a lift for around $600. |
08-14-2007, 12:39 PM | #10 | |
My dads old f-150 had a 4" body and 6" suspension lift on it...... | |
08-14-2007, 12:50 PM | #11 |
well i wanted todo a 4 inch suspension and a 3 inch body lift so i can throw some 38's under it . i was going to sell ithe truck and buy a new truck but my wife and i are going to be haveing a baby and with that in mind i decided to just keep the truck and do work to it to get it the way i want it that way instead of paying 27,000 for a new one i can do mine for right around 3,000 |
08-14-2007, 06:41 PM | #12 |
Newbie Join Date: Jun 2007 Location: Denver
| Fake
Doing a bodylift and cranking the torsion bars may be cheap, but it's like buying a WonderBra, someday, somewhere, someone will know you are lying. Save the $ and buy a real lift (no pun intended) |
08-14-2007, 07:26 PM | #13 | |
Mmmm, hockey pucks. No manufacture that I know of sells a 4" body lift. Just get some balls and cut the fenders if you want to fit larger tires on a IFS rig. Remember to change your gears to match the larger tires too. | |
08-14-2007, 07:35 PM | #14 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
i have some 6 inch blocks for sale, body lifts are retarded. straight axle swap that piece and get some front leafs.
