12-29-2007, 06:03 PM | #1 |
RCC Addict Join Date: Mar 2007 Location: des moines
| pulling out a 4l60e tranny
what is the best way to get to the top bolts on a 4l60e tranny out I got the tc out and all the other tranny bolts out I just cant get on the top to bolts I have the rear of the tranny lower about 4" still didnt help much..anyway the tranny is in a 2002 chevy silverado 4x4 5.3 any tips would be appreciated
12-29-2007, 06:59 PM | #2 |
Quarry Creeper Join Date: Sep 2007 Location: okemos
you have to sit on top of the engine basically usein a box end wrench . it takes a while and putting them back in isnt any easyer .thats what i had to do when i had to put a motor in my 2001 gmc serria when i put a new crate motor in it after i took it for a swim and hydrolocked it:-( they dont run so well under water and a picture is worth a thousand words !!!!!!and i still hear it from my girlfriend " if i was there you would never have done it " it gets old . |
12-29-2007, 07:09 PM | #3 |
Rock Crawler Join Date: May 2006 Location: Georgia
An impact swivel and long extension work really well.
12-29-2007, 07:19 PM | #4 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
We had to use several extensions on a buddy's 1500. I think it was almost 3ft long. Or sit on the motor like Cruz said. We did that when re-installing it.
12-29-2007, 07:19 PM | #5 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
| Quote: Is that silver lake? |
12-29-2007, 07:34 PM | #6 |
Newbie Join Date: May 2007 Location: Mesquite
12-29-2007, 07:39 PM | #7 |
Rock Crawler Join Date: Jan 2006 Location: woodpile aka HELL
take off your tranny crossmember, tighten up some side bolts so the tranny dosent fall on you, let the tranny hang down a bit, and you should be able to get to it then, and if you cant, try jacking the tranny up, and it might give you some room between the block and fire wall. a impact swivle might work, but i wouldent do that right away, a swivle on a impact gun might strip the heads of the bolts |
12-29-2007, 07:43 PM | #8 |
on fbodys we have to use a couple 6" extensions and swivels. as theres only 1" of clearance between the bellhousing and the DS tunnel. i doubt its that tight on your silverado. consider yourself lucky. back when i was shattering clutches once a month i had it down to 90 minutes, pull tranny, new clutch, install tranny, bleed and drive in hour and a half lol. drive way and hand tools, no lift or air. |
12-29-2007, 08:40 PM | #9 | |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
12-29-2007, 08:54 PM | #10 |
the LS6 and Spec stage 2 clutches couldnt handle the power i was putting down. kept shattering the pressure plates. runnin a Ram powergrip HD now. i can drive just fine |
12-29-2007, 09:15 PM | #11 |
12-29-2007, 09:29 PM | #12 |
thanks guys i got them out now im trying to get the clip off the top coolerline im going tomarrow to get an external tranny cooler
12-29-2007, 09:44 PM | #13 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
yeah what every body else has been saying... use a long 3 or 4 foot extension and a swivel socket. my dad and i have a 4 footer that worked perfectly when we had to do it 4 times on the same truck |
12-30-2007, 12:25 AM | #14 |
yup I got them out thaniks..do you have to take the torque converter off to pull the tranny out?
12-30-2007, 01:19 AM | #15 | |
RCC Addict Join Date: Nov 2007 Location: BV
Edit: It just occurred to me; aren't you replacing the torque converter? if not, why? Edit #2: jasper rebuilt transmissions and engines suck. avoid them like the plague. Last edited by chrisjlittle; 12-30-2007 at 01:22 AM. | |
12-30-2007, 09:00 AM | #16 |
Quarry Creeper Join Date: Nov 2006 Location: Rats nest Grafton ND
^^^^^ what he said. Torque converter and trans must come out as a unit and go back in as a unit unless you are throwing them both away and getting all new.
12-30-2007, 10:15 AM | #17 | |
I think i seen that same puddle too. We went up over the summer for a week i think i got some pics. We stayed at the Dunes waterfront resort overlooking the lake and the dunes. we had a pretty good time there. I think the best part was watching the "parade" at dusk when everybody was coming of the dunes and seeing all the cool rides. Here is the view from our room And here is my fav ride i seen. | |
12-30-2007, 10:37 AM | #18 | |
yeah Im replacing the torque converter..I just didnt want to pull them in one paice if I didnt have to thanks again guys Quote:
12-30-2007, 01:02 PM | #19 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
Make sure when installing the new converter you make sure it's all the way in. You'll feel it click once, then you'll have to keep turning it until it clicks again, otherwise you'll break the pump behind the converter.
12-30-2007, 04:31 PM | #20 |
I cant get the tc bolts out this is starting to piss me off is there a easy way to get them out?
