Go Back   RCCrawler Forums > Regional > West > Colorado
Thread: Steering servo upgrade
Old 05-24-2011, 07:00 PM   #1
Talking Steering servo upgrade
How's it going guys, nutternugz here. Got a quick question, getting ready to upgrade my servo and was wondering what all of your thoughts were on which way to go.
Running a Nightcrawler, pretty stock. Only major mod so far was a motor swap to a traxxes Titan motor.
...And by the way had a great time at RCH last Friday, you guys are awesome to hang with and i learned a lot, looking forward to running my rig with you guys again.
Nutternugz is offline   Reply With Quote
Old 05-24-2011, 07:04 PM   #2
Hi Tec HS-7950 is the best in my opinion. They aren't cheap but they are awesome.
Most of us here run them, but some run the JR8711's I just don't have any experience with them.
James003 is offline   Reply With Quote
Old 05-24-2011, 09:04 PM   #3
X2 hitec 7950. You find them online for about $125 but a worth while investment
The Crawl Space is offline   Reply With Quote
Old 05-24-2011, 09:44 PM   #4
X3 on the Hitec HS7950 but remember once you get a big servo like that you need a BEC as well to power the monster. Plan on another 24.99 for a Castle BEC.....Just want to make sure you do it right the first time.
Bigpopa is offline   Reply With Quote
Old 05-25-2011, 06:03 AM   #5
If you don't mind paying full retail for the HiTec HS-7950 and a Castle BEC, look at a few of the local area stores.
I purchased my HiTec HS-7950 and Castle BEC from Colpar Hobbies (west store location). They also programmed the BEC for 6.0 volts (increased from the stock 5.0 volts).
waltgpierce is offline   Reply With Quote
Old 05-25-2011, 06:24 AM   #6
Well walt you need to have the BEC programmed to 7.4v for the 7950 for max performance ..........
Old 05-25-2011, 07:50 AM   #7
True but even at 6 volts its got over 300 torque and will probably last longer since it won't be maxed out.
Old 05-25-2011, 08:16 AM   #8
I wasn't sure at what voltage I should have it programmed. Since I run 7.4 volts (2S LiPO), I thought that was a good compromise.
Even at 6.0 volts, it sure beats the 100 ounce of torque that my previous servo put out!
Old 05-25-2011, 04:11 PM   #9
This is true James didn't even think about like that....................
