HomerJ | 03-16-2009 03:22 PM | Yep, just set up an excel spreadsheet. You can organize it to auto calculate all of your data fairly simply. Main thing you need to know is this: Start each function with an = sign, then after that enter your formula as you would set up any math problem. Say if you wanted to total the guy on row C's points for 4 comps, the formula would look like this: =C1+C2+C3+C4 Just stick that formula in the cell where you want the total points accumulated to appear. That is the longhand version though, you can do an autosum, select your cells and viola, you have a total. I just mentioned the longhand so you kinda grasped the concept first. Believe it or not, Excel really does have a great help section. It's really easy to figure out how to set up complex formula's, even for someone that has never been in excel before. Give it a try, you'll see how easy it is "thumbsup" |
