09-30-2012, 08:48 PM | #1 |
Newbie Join Date: Dec 2011 Location: Canada
| Stuck Driveshaft
Hey guys my driveshaft is stuck on the axle of my axial wraith and I already took the screw out of it but it wouldn't come off. any suggestions on how to get it off? Thanks |
09-30-2012, 08:57 PM | #2 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
| Re: Stuck Driveshaft
Ya---yer dumb.......
09-30-2012, 09:00 PM | #3 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
just pull it right off. but if it really is stuch. heat it up a little bit and it should loosen it
09-30-2012, 09:46 PM | #4 |
ok thanks
10-01-2012, 07:54 AM | #5 | |
| Re: Stuck Driveshaft Quote:
Heat may be needed, or a little PB Blaster (rust solvent). I have used a pair of Dyke's (diagonal wire cutters) as a cheap puller at times. Lightly grab the axle shaft with the dyke's and pry against the axle housing & back of the driveshaft. Just be easy on it since you CAN break stuff. | |
10-01-2012, 10:35 AM | #6 |
Wheres the for sell area?
Stuck Driveshaft - Similar Threads | ||||
need advise for a stuck driveshaft | AX10wannabe | General Scale Talk | 16 | 02-18-2012 04:14 PM |
A TJ stuck... stuck really bad. | K_B | Chit Chat | 15 | 03-16-2007 07:21 AM |
Getting stuck... | CrawlAZ | Newbie General | 9 | 08-13-2006 08:32 AM |
