Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Comments, Suggestions, and Help
Thread: Navagation issues
Old 01-26-2005, 06:35 PM   #1
TCS Team Manager
Fishmaxx's Avatar
Default Navagation issues
1. Once you are off the main/home page you can't get back to it
2. Using the home button takes you to the forums.
3. Tech Link is only on home page
I found a couple more, but I can't remeber them right now.
Fishmaxx is online now   Reply With Quote
Old 01-26-2005, 06:42 PM   #2
It's a setup!
jason's Avatar
All the way at the bottom of the page it says rccrawler.com, that'll get you there.
Home will be changed to go to the main home.
3. Tech Link is only on home page.
It's on all of the main html pages, but once you get into the forums, you're right it cannot be found.
jason is offline   Reply With Quote
