02-06-2007, 12:37 PM | #1 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| How about a column for trannies /gearing ?
A place for tranny talk likes and dislikes upgrades mods weight info low center of gravity scale simliar tranny's gear reduction applications sticky for calculating your gear ratio I think this would benefit all as these builds are getting very custom Scale guys are not using clod axle same as shafty rigs like max's trannies are swaping between different trucks and is difficult finding. What do you think ? Thank you |
02-06-2007, 12:58 PM | #2 |
RCC Addict Join Date: Dec 2004 Location: Central NY
Maybe just a thread in general would be nice. Just something with all the different combinations. But as for its own section, its not really a hot enough topic. Yeah sure every now and then something pops up, but not often enough.
02-06-2007, 12:58 PM | #3 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
I started a tranny guide once! TLT transmission options for your crawler Last edited by TLTCrawlin; 02-06-2007 at 01:01 PM. |
02-06-2007, 01:13 PM | #4 |
how come you didn't finish?
02-06-2007, 01:15 PM | #5 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
I think a tranny sticky would be cool, with all the info on each tranny, and no BS. We could also make that info available on the main page if anyone would like to gather it all up. |
02-06-2007, 01:45 PM | #6 | |
I'd do it if I had the time. | |
02-06-2007, 01:47 PM | #7 | |
02-06-2007, 02:17 PM | #8 |
there was a thread startede a while back about ratios. Ill find it.
02-06-2007, 02:23 PM | #9 |
one of many found after searching for "gear ratio" Gear Ratio Equation and Chart I Made for us Crawlers... |
02-06-2007, 04:33 PM | #10 | |
Let's update and elaberate on it !!? Let's start on the hottest tranny, would that be the stampede ? Steps to make it fit in max or others ? Can I use a stampede trans with Revo D-shafts to Max Diff to revo A-shafts to revo knuckles, I'm thinking of going this route | |
02-06-2007, 04:37 PM | #11 |
Stealth is the number one I believe, way stronger then anything other for durabilty, and weight! Losi would be next, then pede, then evader would be last, duratrax only makes good packs/and chargers!!! |
02-06-2007, 07:57 PM | #12 | |
Brand? car? picture? where to find? specs? can you fit a gear reduction unit ? | |
02-06-2007, 08:41 PM | #13 |
You don't see allot of them but the Twin tranny is BOMB proof. In stock configuration,it's big and fits a TVP chassis,but.....The tranny can be broke down and rebuilt in a hundred different configurations to fit nearly any chassis out there. The Twin tranny I'm running in my super right now,is the same tranny I started with more than 2 years ago and about 124 builds ago I've had it in TVP chassis's,tuber style chassis and even a pan style chassis. The 8mm outputs,chain drive and 6mm main shaft makes for a super strong set up. I've thrown monster horsepower and monster size tires to it while beating on it HARD without failure. The ratio out of the Twin Force chain drive tranny is 2.4 |
02-07-2007, 01:38 PM | #14 | |
it sounds cool, but a lot of that I do not understand ? What is a twin tranny, are talking about the Stealth? What is a TVP? Again, What is it, where is it from, ?custom ? where to buy? Pictures? Link? | |
02-07-2007, 02:51 PM | #15 | |
Nah just razzin ya Twin as in Twin Force built by Kyosho It's an 1:8 scale basher thats a GREAT platform for a super class crawler. If you want,the axles are EASILY narrowed and can be built into a 2.2 spec crawler Check out the Twin Force/X Factor forum. Theres some nice builds in there and you'll see the Twin tranny. You can look at any of my builds or Volkswagenut's(my brother) stuff. They are soley Twin stuff Can't downgrade ya know TVP.....Twin Verticle Plate style chassis | |
