09-19-2010, 01:21 PM | #361 |
Hateraide Join Date: Dec 2008 Location: Mission BC
cant wait to receiver my foams should be here any day now |
09-22-2010, 12:09 PM | #362 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
sure could use a a set of 1.9 duel foams?
09-22-2010, 12:16 PM | #363 |
| He has has these for a while now http://crawlerinnovations.com/index....=products&id=1 |
09-28-2010, 10:28 AM | #364 |
just order my dual foams cant wait to try them on my swapers.
09-28-2010, 03:46 PM | #365 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
10-29-2010, 06:05 PM | #366 |
Rock Crawler Join Date: Aug 2010 Location: Socal
Just got my Rovers/Sedonas with DD foams. I can't wait to get them together. Thanks for the fast shipping and great products. -Trent |
11-18-2010, 09:31 PM | #367 |
Pebble Pounder Join Date: Apr 2010 Location: Monrovia
Hi! I am dead set on ordering some of these awesome foams, but was just curious from looking at the site, is weight mostly a factor when deciding on whether to use the 5.0", or 5.25", or 5.5" dual foams for 2.2's ? i have two set ups running HB rovers whites on one and the other HPI rock grabbers both with the stock foams and i'm trying to decide which of the three would be best to use for a sort of middle ground between driving styles and different crawling surfaces, or would it really depend on these as well, like will the standard 5.5 be best if i want an all around set up? ALSO, I was going to pick up a set of the dual foams for 1.9's, I have an SCX10 where the front wheels are off set and pointing inwards and the whole front side leans way hard when turning, there's way less traction now and am getting less out of my steering, and the tires are folding seriously bad, making roll overs in off-camber turning situations really frequent... http://i876.photobucket.com/albums/a.../Photo2939.jpg http://i876.photobucket.com/albums/a.../Photo2932.jpg http://i876.photobucket.com/albums/a.../Photo2933.jpg http://i876.photobucket.com/albums/a.../Photo2938.jpg http://i876.photobucket.com/albums/a.../Photo2937.jpg My first thought was to replace the foams inside, i think they are memory foams which is why they seem way too soft and i think have gotten wet inside, i tried drying them out and also rotating the tires, but that didn't really do anything, bought the rig used but it wasn't this bad when i first got it, so I was thinking, would the dual stage 1.9's help solve this??? are the tires themselves just worn out? I will have to figure out how to correct that offset too so (as in photo2939), that's really bugging me but am not sure what else i can do for that...any suggestions on that part as well is greatly appreciated...! Last edited by inebriatedmarmoset; 11-18-2010 at 11:44 PM. |
11-19-2010, 08:32 AM | #368 | |
To fix this issue, you can shorten your upper links or mount them further back on the chassis.... | |
11-19-2010, 08:38 AM | #369 | |
Rovers should get a 5.5" This is my opinion , but the most versatile Tire/foam combo that I have seen to this day has been the Rover white with 5.5" CI foam. And like Jeremy said.... Your pinion angle is way too high on your front axle. Shorten or relocate your front upper links. There is another option which will help the matter, and that is the Axial clockable C Hubs. They give you the option of clocking your c hubs back by offering two sets of mounting holes. They will allow for you to run more of a pinion angle and still have your C hubs at a better angle http://www.tcscrawlers.com/Axial-Rac...5-p-17308.html Last edited by helhedded; 11-19-2010 at 08:42 AM. | |
11-19-2010, 11:11 AM | #370 | |||
| Awesome, thanks, will pick up a 5.5" for my Rovers And what would be best for the rock grabbers? I know they're listed as 5.5" too but they seem slightly taller (and wider?) than the rovers....so would the 5.5"'s work too?? or would the difference not be noticible? was looking at the comparison from this thread Request: Side by Side Pics Quote:
will defintely get the 5.5"s for my rovers, and if i can get a 2nd opinion on the grabbers, ill be gettin a set for those too. will probalby get a set of the 1.9's for my scx10 anyway, since these foams are gettin such high acclaim Last edited by inebriatedmarmoset; 11-19-2010 at 11:15 AM. | |||
11-22-2010, 07:35 PM | #371 |
| payment sent!
just sent pm! couldn't wait for an answer ha ...for two sets of the 1.9 dual stage lil nova's and one set of 5.5" for the hpi rock grabbers w/ a 2.125" width for the inner foam, the compound is still a little stiff, hoping that the extra room will give it some flex on the rocks...will get another set for the rovers later, will try to get some feedback after testing...
12-14-2010, 11:09 PM | #372 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
just received my 1.9 dual stage foams... can't wait to get them installed. thanks for the fast shipment. |
12-18-2010, 08:15 AM | #373 |
Newbie Join Date: Mar 2006 Location: Castle Rock
Just ordered some tires and foams. Can't wait for em'. Need to build the rig they're going on first though |
12-23-2010, 03:48 PM | #374 |
That was quick, thanks for the great service Eddie!
12-28-2010, 02:48 PM | #375 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
Just got foams today, nice! I'm running 2.2 Rovers on 1.6" wide beadlocks and the foams are 5.5 x 2.25. My question is: should I trim the width down or just stuff it all in? Thanks in advance .
12-28-2010, 03:01 PM | #376 | |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Since the bead lock is so wide, it might be best to stuff the entire foam in the tire and mount it. On a 1" bead lock with a Rover tire, I prefer a 2" wide inner foam on a truck weighing 6 pounds. It's always best to test and tune. Some people have the time to do it and some don't. Thank you for your business and let me know if I can help you. - Eddie | |
12-28-2010, 03:15 PM | #377 |
The rig is in progress, so estimate on weight. I'll try them untrimmed and go from there. Thanks for the quick response!
12-31-2010, 01:22 PM | #378 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
Got my medium outers for my 5.5 DD & my med single stage 1.9 & the few extra tuning foams you threw in. Thanks again for the fast shipping & awesome products |
01-02-2011, 11:22 AM | #379 |
What would you suggest for a 1.9 wheel that is .500 wide? Running Chisels but will probably end up with Rovers soon enough. Edit: That is for the front. A suggestion for .750 wide wheels with the same tire setup would be great too. FYI your new website has price discrepancies on the 1.9 foams. Shows one price on the main page and then changes when you go to the pull down menu. Last edited by Erik D_lux; 01-02-2011 at 11:27 AM. |
01-02-2011, 12:01 PM | #380 |
Eric the 1.9 foams are extra wide, that way you can try them full width or narrow them for narrower wheels or lighter weight rigs. |
