| | #61 |
| Tire&Foam Extraordinaire ![]() Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Sponsored Links | |
| | #62 |
| WHOLE GRAINZ 4 GAINZ ![]() Join Date: Nov 2007 Location: Memphis
| | #63 |
| '08 2.2 National Champ ![]() Join Date: Nov 2006 Location: UTRCRC
| Like Nova's Ark said, I like to keep things secret that are huge advantages on my crawler but I said I'd test them for him and give input so here it is. If you want to get the most out of your tires RUN THESE FOAMS! I got some good run time today on my main practice rocks and I am 100% impressed with these foams in my Panther Leopard tires! I run Panther Leopards, about a 6.5 lbs rig, Mayhem UCW front with the 5/8" ring on the front and no extra weight, derlin rear wheels with no ring or weight. Last edited by Just Zach; 10-02-2009 at 09:13 PM. |
| | #64 |
| Rock Stacker ![]() Join Date: Sep 2008 Location: Gilmer, Tx
| Nova, can i meet up with you next week to pick up a set? I'll be in Tyler on Wednesday afternoon (after 5pm)... LMK |
| | #65 |
| Satan is amused... ![]() Join Date: Sep 2005 Location: Houston, TX
| I ran these on my heavy crawler with Leopards and they worked quite well! Thanks for a great product Nova! |
| | #66 |
| Gold Star Baby! ![]() Join Date: Jun 2005 Location: Prosser
| Still running these foams from Nova, they are incredible in the rovers, going to try them tomorrow in X-locks, thanks Nova!!! |
| | #67 | ||||
| You should've got them Saturday Quote:
Zach, you are the best. Thank you for your kind words on the product, and for your support and input. You opinion carries weight and it was a blessing to me to receive positive feedback from you. Thank you so much sir Quote:
| | #68 |
| Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
| Mine showed up today already ran two packs on them, Doing better than my old setup. Running them in a rtr 5lb 4oz berg. |
| | #69 |
| Rock Crawler Join Date: Apr 2008 Location: Lexington
| Just got mine installed the other day in a set of Panther Leopards. I've not gotten a chance to get on the rocks with it yet, but should be able to today. All I can say about them right now is that they feel great mounted up!! I am actually really excited about testing these bad boys out |
| | #70 |
| As soon as I get my tire glued back up I should be able to give these foams a good testing. The leopards wear fast! Especially when burning them on the same friggin rock for about 15 minutes. I plan on hitting a few local spots with your foams so I can get them in every situation that I possibly can. That outer foam is soft! Do you think it's too soft to run a full foam like that in a tire that has a strong sidewall with inner webbing? They could possibly replace memory foams, that foam is so soft. The inner reminds me alot of the f400. Me likey!!! |
| | #71 |
| Like a boss... ![]() Join Date: Feb 2008 Location: NorCal
| I got ours today Eddie. Perfect timing for our big comp. I'm hoping we'll be reordering next week. Thank you. |
| | #72 |
| RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
| | #73 |
| I wanna be Dave Join Date: Dec 2008 Location: ?
| just got mine yesterday. thanks |
| | #74 |
| Well, finally got to get out on the rocks with these foams mounted up in the Leopards yesterday. Running a berg with VP rims, 6 slugs per up front, 3 ea in the rears. The leopards have 3 runs on them now, and they are just getting broken in good. Now on to the good stuff, the foams.... I ran a lot of the same lines that I had with cougars and F400's. For the record, it's going to be hard for me to fully distinguish the differences since I've changed both tires and foams, but these sob's just flat out work!!!! The outer layer of the foams allows the tires to get a nice 'mold' over lips, points in the rock, etc. While climbing a ledge about the height of my rig standing upright, I got these foams to wad up from traction. The didn't wad up so that it proved useless, but they did just enough so that I could kick it into 4wheel drive and shoot right up the ledge. Perfect amount of wadding imo. Now, on to sidehilling.. The stiffer second layer really keeps you from buckling tires over like a memory foam will (but with some of the 'give' in the foams like a mem foam due to the softer outer layer). They held most of the lines that I took on a side hill, they did try to push through a couple of spots while turning uphill, but I think that was just more lay of the land kind of thing than the foams not doing their job. Steep uphills are really predictable also. Rear tires won't buckle under on you throwing you over backwards while at the same time, they have just enough soft layer to keep you from bouncing. I'm a firm believer in the 2 stage foam now.. Soft enough on the outside to give you the conformity you need, yet stiff enough through most of the inside to provide the stability also. Hope that helps any of the curious minds!! |
| | #75 |
| | #76 |
| WNYRCRC ![]() Join Date: Nov 2008 Location: Western New York
| I have to have a set of these. I will be trying them out in the October weather in Buffalo NY. About 50 degrees or less. Will be sending paypal soon |
| | #77 |
| Rock Crawler Join Date: Feb 2007 Location: sweden
| How about running the 1.9:s in a set of rok lox that are 4.5" in height? Would it be possible to get a taller 1.9 of these? |
| | #78 | |
I am going to work on more foam sizes next week. The biggest problem with 1.9 is getting the sizing right, and then the foam compounds. I made the 4 1/4 because I needed them for my Flat Iron's on my scale truck and 1.9 Cougars on my Losi MRC. I am going to make some smaller 1.9 foams for my 1.9 Cobras and 1.9 Chisels and have them sent out for testing next week. I want to offer some options in all the foam sizing I offer, but it takes time and testing to get there. I will look into the 1.9 rok lox next week as well. Thank you for your interest and your question. | |
| | #79 |
| I wanna be Dave Join Date: Jul 2008 Location: appleton
| got mine the other day for the 2010 berg build what kind of glue did you use to glue them together |
| | #80 | |
| Thread Tools | |
| Display Modes | |
