08-26-2012, 10:05 PM | #181 |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_*
Just put in a big order tonight! I am looking forward to getting them.. Thanks Crawler innovations |
08-30-2012, 03:16 PM | #182 |
I received my foams today. Yet to test but i do have one pair mounted up. These really woke up my 2.2 Irocks.. Just an amazing difference. Thank you for the awsome products and all of the bonus tuning rings! |
08-31-2012, 04:15 AM | #183 |
I got my sets just the other day. Was surprised to feel the huge difference in stiffness between "medium" and "soft". I have Rover tires, and mounted a pair with 5.0" mediums plus soft tuning rings. The tuning rings are only 0.25" thick, and the tires are about 5.20" diameter inside, so I can't say the added "soft" makes a difference (compared to running 5.25" mediums with no tuning rings). It would be really cool to have tuning rings (or rather a standard third stage) 0.50" thick on 2nd stage foams 1.00" smaller than the tire. |
09-02-2012, 04:01 PM | #184 |
Pebble Pounder Join Date: May 2008 Location: IN
Does the closed cell inner foam change in size when going from say 5.0 to 5.25 to 5.5 or is just the outer foam the only size changing?
09-12-2012, 05:25 AM | #185 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* |
09-16-2012, 07:48 PM | #186 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Just ordered up my dd rover combo saved some moolah too, thanks Eddie
09-23-2012, 02:49 PM | #187 |
RCC Addict Join Date: Jul 2009 Location: AT THE DRAGON'S LAIR
What is the O.D. on a 5.0, and 5.25 closed cell inner foam? Thanks! |
10-06-2012, 02:54 PM | #188 |
Quarry Creeper Join Date: May 2010 Location: Flooriduh
I just ordered a set of 2.2 x 1.25 wheels and want to get the new Pitbull Rockbeast II when they come out. My question is should I use 5.5 or 6.0 inner foams? This will be a scale trail rig.
10-06-2012, 10:57 PM | #189 |
I'm HUGE in Japan! Join Date: Dec 2011 Location: Clearwater - home of the endless summer
Just picked up a set of your Khoas with the 2.2 sedona sidewalls.. Would the 5.25 be the ideal foams for these?
10-11-2012, 12:33 AM | #190 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
I ordered 5.25" soft front, medium rear foams for my 5.00 lb switch 2 months ago that are inside of red dot boss claws mounted to 1" slw and found soft front was way to soft. The tire just completely collapsed on breakover and anything down hill. I moved the medium rears to the front and put stock bc foam in rear and saw an immediate 100 times fold better performance. The boss claws are totally shaved btw. Just thought id let anyone whos interested know my findings.
10-11-2012, 04:42 AM | #191 | |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Quote:
Ran out of 5.5 inners or I would have used them instead as Ive got quite a collection of outers. | |
10-21-2012, 12:11 PM | #192 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
I have been tuning my rig with these foams and I have found that with 1" wide wheels and a 5 lb rig and shaved rovers the best foams for me are 5.0 front with soft outers and and 5.25 rear with medium outers cut the same width as the inner foams. |
10-22-2012, 10:11 PM | #193 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
I tried to search but couldn't find a clear answer. What is the reason for firmer foams in the rear even though the front of the rigs are heavier? Is it for climbing purposes because more weight will be distributed to the back and same when you are accelerating?
10-23-2012, 12:15 AM | #194 | |
Yes, it's because you're climbing uphill a lot of the time, and that's when the grip is really needed. Stability for side slopes is provided by the very stiff inner foams. I've also noticed that there's a huge difference in stiffness between vented and unvented tires. | |
10-23-2012, 09:42 PM | #195 |
I just placed an order for 4 pairs of 6.0 double deuces... well actually 3 by mistake of my dumb phone. I paid the one and emailed you about my mistake.
10-24-2012, 04:39 AM | #196 |
Rock Stacker Join Date: Jan 2011 Location: Greece
iam a bit confused..crawler king weight is 8lbs,60/40 f/r weight distribution,used for rock crawling only,i have the chisels with 1.25'' width mayhem engineering 2.2 monsters vented.what would be the best combo to order? do i have to drill holes in the inners as well? thanks!!! |
10-26-2012, 07:57 AM | #197 | ||
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
These have been both taken care of through email. Thank you both for your business. I don't check RCC often, but I am always available through direct email @: novasark@crawlerinnovations.com | ||
11-07-2012, 08:36 PM | #198 |
Newbie Join Date: Feb 2012 Location: us
Just got my foams today!! Been playing with mem foams, stock foams, and cutting them down, adding foam rings...ect for about 3 weeks to no avail in my white dot rovers. a 10 minute complete foam change made all of the difference. narrow 5.25's firm rears soft fronts on chaotic switch. excellent product and excellent service.
11-23-2012, 05:02 PM | #199 | |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
Losi Night Crawler for sportsman & 2.2S competition. 6 lbs RTR, typical upgrades, knuckle weights, lipo on front links. Cut red Boss Claws, on stock LCC wheels. Weighted to 14/10 oz. Mostly high traction granite rock at the comp site. I see Del Monte was happy with 5.25/softs in his BC's, but he's a LOT lighter than me. Wouldn't I need something stiffer? | |
11-26-2012, 08:29 AM | #200 | |
As for your application, the 5.5 might be better. The Crawl Space in Colorado sells mostly 5.5's because of the rock in their area. | |
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* - Similar Threads | ||||
Double Deuce foams for HB Rovers on XR10? | Rock Spider | Axial XR10 | 6 | 06-01-2011 04:49 PM |
Deuce Nova's and Lil Nova's Dual stage foams! | bigflex | Tires and Wheels | 6 | 10-06-2009 10:50 PM |
