11-26-2012, 09:18 AM | #201 | |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Quote:
I had been thinking 5.25's with med/med or even med/firm to stand the pins up, but I'll stay with your suggestions. | |
11-26-2012, 09:24 AM | #202 | |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I think this would be a good option also: 5.25's with med/med | |
11-27-2012, 09:53 AM | #203 | |
Rock Crawler Join Date: May 2007 Location: Arnold
11-27-2012, 01:45 PM | #204 | |
Mainly the oven drying is to get all the water/moisture/build up out of the open cells in the foam. But I have dried several sets of water logged open celled foams with good results. Eddie or someone, correct me if I am wrong. | |
11-27-2012, 01:50 PM | #205 | ||
What size are they? Quote:
11-27-2012, 10:25 PM | #206 |
[QUOTE=Nova's Ark;4034579]How old are your foams? What size are they? Thay are about 4 months old,Thay have three comps on them and two practice sessions.Thay are 5.5 nerrows |
11-30-2012, 09:31 PM | #207 | |
The 5.5 narrow foam is 1.50" wide. The .7 wheel is half the width so it's applying a steady pressure on the closed cell inner. Keep in mind that most 2.2 tires average about 2" wide at the tread. They become skinnier when the side walls are shaved. | |
12-19-2012, 05:36 PM | #208 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
So I quickly scanned some pages and did not see any one that put up Suggestions for a 4lbs rig with .7 wheels and BOSS CLAW I do not use boss claws but I am sure no one runs Leopards and the boss claw is the closest in size. So what would you run in a .7 wheel with boss claws and a 4lbs rig Here is the list of foams I just got from you in the mail today I hope the right starting point is in my list HAHA 5.0 soft 5.0 med 5.25 soft 5.25 med outer tuning rings soft med hard I was thinking of starting with the 2.25 soft up front and the 2.25 med in the rear. But I would love to hear your input. Thanks for the great service and fast shipping |
12-19-2012, 06:10 PM | #209 | |
I'm using: 5.25 Double Deuce Narrow / Soft - Front + 5.0" Tuning Discs on both sides 5.0 Double Deuce Narrow / Medium - Rear Thank you for your business. | |
12-19-2012, 07:48 PM | #210 |
Ok so maybe I need to run the 5.0 all the way around when I said 4lbs I should have clarified I am 4 lbs 1.2 oz. But you kind of have me a good starting point based on weight of the truck. Thank you. |
01-11-2013, 05:03 PM | #211 |
When I shaved my rovers, the tires softened up a great deal and got pretty wimpy with 5.5 CC/soft. So I tried to fit a medium tuning ring over the outer and had no success at all in getting it installed. No matter which order I installed things in, I always wound up with folds in the ring and sometimes folds in the outer. What's the trick? I finally gave up and went to 525/mediums to avoid needing rings.
01-16-2013, 06:01 AM | #212 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
My order is in! I am anxiously awaiting my set of closed cells. |
01-16-2013, 08:58 AM | #213 | |
01-16-2013, 09:27 AM | #214 |
I think my wheels are a hair over 1" which was borderline between the two foams and I went with wide. I tried to preinstall the tuning ring over the outer, but when I folded them to get them into the tire it wouldn't unfold properly. Almost like the tuning ring is too long and has no place for the excess to go. I wish Eddie made oversize outers available when more stuffing is needed. My rovers were wadding up very badly on 5.5 soft, but seem happier with 5.25/medium. But I've never run a medium in a front before as I generally like soft tires.
01-16-2013, 09:33 AM | #215 | |
Keep in mind that you softened up the Rover considerably by shaving it so it will need a stiffer foam to make up for the difference. I run shaved Rovers on my Shafty. With .75" wheels I use a 5.5 Soft combo up front BUT the rig weighs in at 4.5lbs. Any heavier and I'd be looking into more foam support. Last edited by helhedded; 01-16-2013 at 09:36 AM. | |
02-07-2013, 01:29 PM | #216 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
Trying to figure out which foams to buy. I have a heavy solid rod tuber with 2.2 proline super swampers on Mayhem 1" wide wheels. I will be using it for a mix of rock crawling and southern buggy style hill shooting. Thanks for the help!
02-07-2013, 01:38 PM | #217 | |
I don't know what it weighs but the bead on the Pro-Line SX Swamper sucks. If it is heavy (whatever that means), putting a foam big enough to hold the weight won't matter cause the bead won't hold (such as a 6.0" inner for example). So my suggestion is: 5.5 Double Deuce Narrow / Medium Narrow / Firm | |
02-07-2013, 02:42 PM | #218 | |
I will go with what you recommended, it has to be a lot better than the stock memory foams in it now. Last edited by Turn'Nburn; 02-07-2013 at 03:24 PM. | |
02-11-2013, 01:58 PM | #219 |
Newbie Join Date: Jan 2012 Location: oxford
I have a wraith that weighs 8lbs to be used for mainly crawling. I have PB2's but need foams oh yeah vanquish omf wheels.
05-21-2013, 04:15 PM | #220 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Hey guy's, I need your wisdom. I just got my Voodoo's in, silver and blue compounds. I already have a set of 4 DD close cell in 5.25". I think soft and med. My rig is around 4.5 lbs with 1" VP v5 repun slw's and I would like to know what do you recommend to fill the tire. Thanks for your help. |
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* - Similar Threads | ||||
Double Deuce foams for HB Rovers on XR10? | Rock Spider | Axial XR10 | 6 | 06-01-2011 04:49 PM |
Deuce Nova's and Lil Nova's Dual stage foams! | bigflex | Tires and Wheels | 6 | 10-06-2009 10:50 PM |
