07-12-2013, 02:16 PM | #261 | |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Quote:
What is the weight of the vehicle RTR? What wheels are you using and how wide are they? What tires are you using? Do those tires have any tires mods? What is the intended purpose of the vehicle? (Slow technical rock crawling, or more trail / speed terrain?) Answer those questions on any build and I can get you pointed in the right direction. | |
07-12-2013, 03:43 PM | #262 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
I appreciate that. But it was intended as more of a generic question although limited to comp crawling. I wasn't looking for someone to tell me what to put in there...rather, how to test and decide for myself.
08-05-2013, 02:51 PM | #263 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
I'm getting ready to buy some beadlock wheels for my Wraith. Either the Axial TR beadlocks or a set of VP KMC's. Question I have is how do I figure out what foams I need? I'll be using the R35 compound Ripsaws. Do I need to weigh the rig? Or is there a standard set to use with my combo? Just weighed my Wraith. It came in at 7lb 2oz all up. I use it mostly for G6's and bashing in the back yard. What combination of foams should I buy? Last edited by 65BAJA; 08-05-2013 at 07:29 PM. Reason: Added weight. |
08-10-2013, 04:46 PM | #264 |
Rock Crawler Join Date: May 2011 Location: SoCal
Has anyone experienced slicing the rubber near the ID of the tire, along the outer edge of the beadlock ring? I'm wondering if the new fatter CC foams are pushing too hard on the inner sidewall. I've always used narrows in the past. Tire is Boss Claw, wheel is DH1, and the ring does have a small chamfer on inside edge. So it shouldn't be a knife, but it is. Cut both new fronts in just two packs. |
08-11-2013, 01:58 PM | #265 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
08-29-2013, 05:04 AM | #266 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
Any word on the med size being back in stock today?
08-30-2013, 09:55 AM | #267 | ||
Med Front Firm Rear Quote:
More material arrived yesterday and they are being machined today. Back orders will ship today and all new orders will ship Tuesday after the Monday holiday. | ||
08-30-2013, 10:35 AM | #268 | |
If it happens again, I'll remove a tad of foam from that area. | |
10-27-2013, 07:59 PM | #269 |
Newbie Join Date: Jun 2013 Location: Australia
Got my new foams in the mail the other day and love them. 5.5 comp cut and they work so well. Thanks guys.
11-06-2013, 08:57 AM | #270 |
hey Eddie, looking for some advice got a 2.2 fullsize tube frame C3 Blazer scaler with aluminum wraith axles. 2.2 Pitbull tires on 1" rim will be used 99% for slow technical crawling on rock. brushed power (crawlmaster 16T) dont know final weight yet. ~TSS~ "Gus" what DD foam setup would you suggest? take my money! Cory |
11-06-2013, 09:09 AM | #271 | |
I assume you are using the Rock Beast 2 tires (5.75" tall). If so; 6.0 Double Deuce Standard Inner Med Outer / Front / No tuning ring Firm Outer / Rear / No tuning ring | |
11-06-2013, 12:16 PM | #272 |
thank you! yep thank you again! gonna pick up one of your tranny extensions too and thinking about trying your maxx shafts for the first time. thanks Eddie. hopeing to meet you soon at a ETX event |
11-24-2013, 02:34 PM | #273 |
RCC Addict Join Date: Jan 2010 Location: Vermont
Hi Eddie, I just purchased some VP KMC Enduros, and obviously with my old CI wide foams (was running CAC EZ Locs before) they cannot mount up because of the wide foam width. It says on your site you no longer do the narrow and wide foams, and every foam in the DD line is 1.75 wide. I just measured my wide foams and they are 1.75 inches wide as well... Am I missing something? I really want to mount these suckers up! Please let me know at your own convenience, Ted |
12-04-2013, 04:03 PM | #274 |
Rock Crawler Join Date: Sep 2008 Location: Mid Mo.
Thank you for the fast shipping on foams and tires. I look forward to trying them out soon |
12-20-2013, 09:33 PM | #275 |
I kind of wonder if there's a problem with this one-size-fits-all approach to the cc inners. I've narrowed some tires and the few cc foams I've tried haven't fit well. Seems like since the foam is almost semi-rigid, it needs to be a very good fit at the wheel and a pretty good fit at the sidewall. So I guess I'll try cutting some down. Is there a rule of thumb I can apply to resizing a foam? Like make the width match the wheel width at the inner diameter, and make the width 1/4" wider than tread width at mid sidewall. Any reason why that approach wouldn't work, and would you agree or disagree with my made up numbers?
12-22-2013, 10:54 AM | #276 | |
Got the stock foams stuck in my rig now... Last edited by tedo; 12-22-2013 at 06:14 PM. Reason: Grmmmmrr | |
12-22-2013, 06:09 PM | #277 |
The design is not going to change. Factory 2.2 tires average 2 inches wide. And factory wheels average 1.35 wide. So the foams are shaped for the majority of what is out there internationally. If you would like to pay for custom foams, which I have already been making for pro drivers, they will be $25 a pair, & they will be shaped specifically to your wheel and tire. Please email me if you are interested. .. Sent from the lab @ the CI compound |
03-03-2014, 09:50 AM | #278 |
Newbie Join Date: Dec 2013 Location: United States
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Truck Weight RTR?___________7 lbs, Axial SCX10 Rubicon Truck usage (bashing (fast) or rock crawling (slow)?____________slow/medium trail running and rock crawling What brand manufacture tire, compound, any tire mods?_________Unmodded Proline 2.2 Hammers (#1145 on side of tire, no dot)AND 2.2 Flat Irons (#1146 on side of tire, no dot)-(different recommendations if applicable, though the sizes of the two are very close) How wide are the bead locks?_________Couple of options: Proline 8-shooter beadlocks are 37mm out-out of ring (27mm wheel face-face); Hot Racing Beadlocks are 48mm out-out of ring (42mm wheel face-face) Thank you for any recommendations you can give for these options on this rig. If you need any further info, please let me know. Bryan Keyser RCRNV |
03-05-2014, 06:54 PM | #279 | |
5.25 Double Deuce Standard Inner / Medium Outer = Front Standard Inner / Firm Outer = Rear | |
06-17-2014, 12:13 PM | #280 |
Newbie Join Date: Nov 2008 Location: Post Falls
Hey Eddie, I've been lurking for quite some time and am finally ready to get some of your awesome foams. Could you possibly give me a hand choosing which Double Deuce foams to get? I'd really appreciate it. Axial Wraith weight: around 7 lbs Usage: Mostly crawling, and a little bit of rock racing and trail runs Tires: Hot Bodies Rovers (white dot) Bead lock width: 1.7" (they're Axial VWS) Thanks in advance for your assistance. Shane |
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* - Similar Threads | ||||
Double Deuce foams for HB Rovers on XR10? | Rock Spider | Axial XR10 | 6 | 06-01-2011 04:49 PM |
Deuce Nova's and Lil Nova's Dual stage foams! | bigflex | Tires and Wheels | 6 | 10-06-2009 10:50 PM |
