02-29-2012, 07:38 PM | #41 | |
Quarry Creeper Join Date: Sep 2010 Location: too close to LRC.... Jealous????
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Quote:
02-29-2012, 10:39 PM | #42 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
I'd like a set for some stock pl tsl's should I get the narrow or wide in the 5.5's Also do you have any ideas when there will be some for the 1.9 pitbulls thanks J-bird |
02-29-2012, 11:29 PM | #43 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
Ordered some of the new foams recently and when I went to install on .960 DH II wheels, it seemed like the inners weren't letting air out of the breather holes. I was like a giant balloon. Curious if I have to shave the ID to allow the air to escape? Like I said, just got these and would really like to give these a go! |
03-01-2012, 06:36 AM | #44 | |
03-01-2012, 07:17 AM | #45 | ||||
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Wide is 1.75" wide If you buy a wide foam and have a narrow wheel, the closed cell foams will not mount without modifying the foam yourself. As for your tire question... How wide is the wheel the tire is being mounted on? How much does the truck weigh RTR? Are the tires stock or modified? Quote:
The 1.9's inner and outers have arrived. One of the sizes was cut wrong and the outer tuning rings don't look like they will work either. So I have some issues to iron out before I add them to the web site. Quote:
How wide is the wheel the tire is being mounted on? How much does the truck weigh RTR? Are the tires stock or modified? In regards to the 1.9's; The 1.9's inner and outers have arrived. One of the sizes was cut wrong and the outer tuning rings don't look like they will work either. So I have some issues to iron out before I add them to the web site. Quote:
03-01-2012, 07:45 AM | #46 | |
03-01-2012, 07:48 AM | #47 | |
Try drilling 1/4" holes in the foam for venting if you haven't already. I have four 1/8" vents per wheel, and about six to eight 1/4" holes per foam. Works well Last edited by helhedded; 03-01-2012 at 07:50 AM. | |
03-01-2012, 08:07 AM | #48 | |
However, the closed cell is water proof. So the inner foam will not be damaged by water. The outers tend to stretch when they get wet. If you leave them in the tire, it's a non issue and they eventually dry out. That is what I do with my scalers and wraiths (I leave them in the tire wet). I have done that for several months now with no issues to report. Everyone is different and there is no right or wrong way. See my signature . That said, early on I drilled the closed cell inner foams and aligned them with the vent holes in my bead locks. I use 4S lipos on most of my crawlers and the foams were shifting inside the tire and closing off the breather holes. So I started venting the tire. In the past, I always suggested drilling the bead lock for breather holes to keep water out of the foams. But with this new design, it's much simpler and faster to vent the tire. It's also easier for the average person who may not have the proper tools or shop to modify the closed cell foams or bead locks. In regards to your DH2's, you could put a small 1/8" deep channel into the inner foam where it lines up with the DH2's vent channel. Anther idea is to slot the inner foam from left to right across the area where the foam meets with the bead lock wheel. They do this in 1/8 racing closed cells. You could also just drill the foams straight through. I heated up the end of a sharp scribe and pushed it through the closed cell foam early on. It created a clean hole that allowed air to move easily. Please post up what works for you | |
03-01-2012, 11:09 AM | #49 |
Rock Crawler Join Date: Jan 2005 Location: Windsor, VA
Just ordered a set for my new xr10. Have a set of the orginals in my ax10 rig. Can't wait to get them! Thanks for offering a great product! |
03-01-2012, 01:05 PM | #50 |
Well during my lunch hour i went home and did some work. Drilled 8 1/4" holes evenly spaced and then cut a small channel on the inside that is 1/4 wide. Made the channel like a V. It is letting air out!! I no longer have giant balloons! Although, the recovery of the tire is a little slow. I might make the channel a little bit wider. |
03-01-2012, 01:19 PM | #51 | |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Then just after the reply a pair each medium narrow and wide. Thanks for your help. Crawling in South Africa is exploding at the moment. One year ago, nothing but now already three day comps. | |
03-01-2012, 01:23 PM | #52 |
"Not water proof." Does it mean the foam will soak up water or will they deteriorate when exposed to water? |
03-01-2012, 02:13 PM | #53 | ||||
The conventional outer foams are like a foam sponge. I have not found a water proof material suitable for outers yet. However, the outer can become not very important in a scale-mud-water-bash situation. I have been running my daughters jeep with no outers. Just a large closed cell inner. I had to shape the inner and create a relief area in it for forward bite. I'm running modified RC4WD IROKS. Here is a thread with info about the tires: http://www.rccrawler.com/forum/tires-wheels/327544-crawler-innovations-1-9-irok-scale-comp-tire-lil-nova-foams.html So my daughter's Jeep and my 6x6 have no outers. The 6x6 has closed cell foams in it as well. What I have said all along, the outers tend to stretch when they get wet. If you leave them in the tire though, it's a non issue and they eventually dry out. The tire also does not hold as much water, because the inner foam repels water (or does not allow water in because it is so dense). If you squeeze the water out of your outers by hand at the end of the day, 75% of any water still in the tire will be pushed out altogether. That is exactly what I do with my scalers and wraiths (I leave them in the tire wet). I have done that for several months now with no issues to report. The outer foams aren't pretty after a couple months, but they still hold up well. For scalers and trail rigs, I'm liking medium outers in the front and either firm or medium outers in the back. Those densities have held up better to consistent water abuse more than the soft in my experience. | ||||
03-01-2012, 05:21 PM | #54 |
After working with the closed cell I would agree that the way to do these foams for venting is through the tire only. I drilled 8 5/16 holes around the diameter thinking that would work. I put them on my .7 wheels and the foam compressed itself shut almost entirely. Its really easy to see with my wheels since I can see the foam after the tire is mounted.
03-01-2012, 07:07 PM | #55 |
Here is what I came up with: 1/4" holes Made the channel a little wider I will admit there is more give with it cut up, but they're still firmer than the last inners. Sent from My Touch 2 |
03-01-2012, 08:58 PM | #56 |
Quarry Creeper Join Date: Sep 2011 Location: On PayPal trying to make funds appear.
i got these foams, and really like them. i have medium outers. i can really tell it helps since it basically will only compress so much. great product, and great customer support. it also helps keep the tires taller and they seem predictable. very happy customer right here. |
03-02-2012, 07:11 AM | #57 |
In regards to your TSL's: How wide is the wheel the tire is being mounted on? How much does the truck weigh RTR? Are the tires stock or modified? In regards to the 1.9's; The 1.9's inner and outers have arrived. One of the sizes was cut wrong and the outer tuning rings don't look like they will work either. So I have some issues to iron out before I add them to the web site. My wheels are 1" wide and the rig weighs about 8.5 to 10 lbs Please let me know what I need thanks Eddie J-bird |
03-10-2012, 01:03 AM | #58 |
Rock Crawler Join Date: Oct 2007 Location: south of France
no news on the 5.25 foam ?? or any advice for using the 5.5 w/ shaved Losi BC on 0.7 wheels my rig weight just a little under 5lbs thanks |
03-10-2012, 07:30 AM | #59 | |
There is nothing good to report on the 5.25 inner foam front. Our first run of the 5.25" inner was machined incorrectly. The cause has been identified and repaired, but it's honestly going to be at least 2 weeks before I will have any in hand to sell. In my opinion, I think the new 5.25 inner with the new die cut outer is the better foam option for the boss claw. Especially in light weight trucks. It allows for more tuning options. I will try and post a picture soon for comparison. Once you see the 5.25 next to a boss claw and the 5.5 next to the boss claw, you can really see the difference and it becomes obvious that the 5.25 is the better fit inside the boss claw. I wish the change over to the new design wasn't taking so long, but it's just the way it is. Thank you for your patience. | |
03-10-2012, 08:50 AM | #60 | |
Rock Crawler Join Date: May 2011 Location: SoCal
Unsure about the channel thing around the ID. If I glue a strip of lead tire weights around the rim, can I expand the new foam over the strips to get the channel aligned? Lastly, I currently use round lead "rope", 3/16" dia. I wrap it around the wheel and secure it with tape. But your piercing technique above -- do you think it would work to make up a 3/16" pointy thing (a sharpened screwdriver for example) and make a series of parallel holes, each taking an inch of the lead rope? I'd need a very large number. I wish I had a scrap to play with, so I'm not screwing up my new foams. But hearing from others, "been-thre-done-that", is almost as good. | |
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* - Similar Threads | ||||
Double Deuce foams for HB Rovers on XR10? | Rock Spider | Axial XR10 | 6 | 06-01-2011 04:49 PM |
Deuce Nova's and Lil Nova's Dual stage foams! | bigflex | Tires and Wheels | 6 | 10-06-2009 10:50 PM |
