Go Back   RCCrawler Forums > Vendors > Crawler Innovations
Thread: --- C.I.'s Single Stage Double Deuce Foams ---
Old 02-29-2012, 04:28 PM   #1
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Default --- C.I.'s Single Stage Double Deuce Foams ---
Crawler Innovations is now offering an over-sized single stage Double Deuce foam.
The single stage foams are 5.750" Tall x 2.250" Wide
Single Stage Double Deuce Density Choices:
Soft
Medium
Firm
Nova's Ark is offline   Reply With Quote
Old 02-29-2012, 04:32 PM   #2
Nova's Ark's Avatar
Default Re: --- C.I.'s Single Stage Double Deuce Foams ---
This is a product that had been talked about since the beginning. Early on we talked about the possible need for a foam like this because of the Mayhem Ultimate Competition Bead Lock wheels. It also applied to the folks that were using custom made internal rings on their 2.2 wheels. I'm also aware that some drivers prefer single stage foams, especially when experimenting with ultra light weight comp rigs. I also would get requests from people wanting to experiment. No matter what your reason, I'm happy to finally be able to offer a quality single stage 2.2 foam. These foams are die cut from the same material that we use for the Dual Stage Outer foam lines.
Old 03-01-2012, 07:41 AM   #3
Very cool, Eddie. I am glad that these have finally come to life. Thanks for making it possible
The price isn't bad either
helhedded is offline   Reply With Quote
Old 03-01-2012, 08:12 AM   #4
Nova's Ark's Avatar
You helped to make this possible Ashton, so thank you.
Old 03-01-2012, 08:32 AM   #5
Looks great! I'll have to try some for my scalers!
chicklet is offline   Reply With Quote
Old 03-01-2012, 08:36 AM   #6
Nova's Ark's Avatar
Thank you Britt, but you're gonna want the dual stage closed cell for your scalers Fo Sho. I'm also working on foams for your EXO Terra Buggy. Our buggy should arrive today and Gavin has been commissioned to build it. I have been testing FOFF foams and I am liking them a lot. The tires are staring to get so much traction it sheered the drive pin on the top shaft of the transmission in a 2WD slash.
Old 03-01-2012, 09:39 AM   #7
Yes sir!!! I will wait for the new duals then! Can't wait for the Exo foams! I'm actually going to run two different wheel and tire setups...stock and street
Old 03-01-2012, 10:32 AM   #8
I'm also working on foams for your EXO Terra Buggy. :
I want some for mine too
ittybitty is offline   Reply With Quote
--- C.I.'s Single Stage Double Deuce Foams --- - Similar Threads
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Nova's Ark Crawler Innovations 295 10-26-2018 10:55 AM
Double Deuce foams for HB Rovers on XR10? Rock Spider Axial XR10 6 06-01-2011 04:49 PM
You may edit your posts
