07-01-2017, 08:54 AM | #161 |
Newbie Join Date: May 2017 Location: US
| Re: *_* C.I.'s Lil' Nova Closed Cell Competition Ready 1.9 Dual Stage Foams *_*
Thanks!
07-16-2017, 12:13 PM | #162 |
Newbie Join Date: Nov 2014 Location: Spain
Hi, for a Traxxas TRX-4 with Rock Beast XL you recommend me 4.50" or 4.75"? Thanks! |
07-19-2017, 07:27 AM | #163 | |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: *_* C.I.'s Lil' Nova Closed Cell Competition Ready 1.9 Dual Stage Foams *_* Quote:
I have found that 4.50" Tall Tires work better on the TRX4 due to the high center of gravity the truck has. I use the standard height 1.9 rock beast on my TRX4. | |
07-20-2017, 02:09 PM | #164 | |
Thanks! | |
07-20-2017, 02:15 PM | #165 | |
I am using the Standard height Pitbull 1.9 Rock Beast in the original compound on CI's TRX4 with CWR-2024 front and CWR-2025 rear (4.50 Lil Nova Comp Cuts). | |
07-21-2017, 07:47 AM | #166 | |
07-24-2017, 09:46 AM | #167 |
Pebble Pounder Join Date: Jun 2017 Location: United States
Not sure if anyone else has experienced this but I am new to RC and bought a Wraith from a guy and he shipped it to me. When I got it the tires were all flat on multiple sides and when driven it bounced all over. I order new foams from CI and I was trying to figure out why tires would end up like this. If you pushed on the tire part that was not flat it puffed out another side like a vacuum inside. Then it dawned on me, he shipped from Aurora, CO and I live in Sun Lakes, AZ and the altitude was a huge difference. When I popped the head on the head locks the tires went to normal.
07-24-2017, 09:50 AM | #168 | |
07-29-2017, 10:48 AM | #169 |
Rock Stacker Join Date: Apr 2016 Location: Meriden, CT
I have a custom chassis/cage, SCX10 axled rig. I am running standard rock beast 1.9 tires. Rig weighs in at 9.5 lbs fully loaded. Probably 50/50 trailing/crawling. Thinking the 4.75 med front and firm rear. Am I far off? The help is greatly appreciated. Sent from my Pixel using Tapatalk |
07-29-2017, 11:43 AM | #170 | |
Not for standard height 1.9 RB's. I recommend part #: CWR-2025 front CWR-2026 rear Those are 4.50" Lil Nova. Thank you. | |
07-29-2017, 01:23 PM | #171 | |
Sent from my Pixel using Tapatalk | |
08-26-2017, 12:45 PM | #172 |
Newbie Join Date: May 2017 Location: Linthicum
| Re: *_* C.I.'s Lil' Nova Closed Cell Competition Ready 1.9 Dual Stage Foams *_* |
09-12-2017, 06:22 PM | #173 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
Truck is 5-6 lbs rtr..mostly used for trailing and light rocks...1.9 pitbull xors on 1.9 VP OMF...would i be wrong in using the 4.50 size foams?
09-13-2017, 08:22 AM | #174 |
| Re: *_* C.I.'s Lil' Nova Closed Cell Competition Ready 1.9 Dual Stage Foams *_* The tiny tires are a new challenge. CI can provide a single stage foam for tiny tires, but it seems most customers want a dual stage. It is difficult to machine foam, let alone tiny foams. Operator safety is an issue. Also, with soo many small tires, which one do you build around? All the tire companies are now offering poor quality foams with re-inforced rubber tires. That is not the best combo for performance tuning. CI has experimented with a few tiny tire foams over the 2017 summer and have some strong single stage designs we could offer. But with customers concerned with buying the tires w/ the foams, more americans will be out of work. CI foams are made and machined by Americans in Texas. You cannot say that about the tire and foam companies. When you buy from them, you are employing overseas labor. My desire is to have foam options for each rc class so that CI dominates any rc crawling competition. I want my customers to have the advantage and confidence quality parts bring. |
09-13-2017, 08:23 AM | #175 |
08-12-2019, 11:38 PM | #176 |
Newbie Join Date: Aug 2019 Location: San Marcos
I have a 8.25lb scx10ii, 75% rock crawling, 25% trail with an occasional dip in the creek. I am currently rolling on Proline KM3's in the 4.75 flavor, with chanquish beadlocks that are 1.1" width what do you suggest in the lil nova line up?
Last edited by northsandiegoRC; 08-12-2019 at 11:40 PM. Reason: Spelling and grammer |
02-02-2020, 07:30 AM | #177 |
Newbie Join Date: Dec 2015 Location: Central Ohio
What would you suggest for my TRX4 Blazer. Fully loaded she weighs in at 8lbs 2 oz and I'm using the stock Canyon tires. I do mostly slow technical crawling. |
02-02-2020, 08:51 AM | #178 | |
Hi. Two possibilities; 4.50" = More tire forward bite/squish CWR-2025 front CWR-2026 rear -OR- 4.75" = Less tire forward bite/squish P/N; CWR-2034 front CWR-2035 rear Optional Tuning aid: CWR-3015 (one disc on the outside of each foam for added support) Use discount code; iamworthy For 11% off your order. Thank you for your interest in CI products. | |
02-02-2020, 10:38 AM | #179 | |
It looks like the 4.5's are all out of stock. Any ETA as to when you will get more? | |
03-31-2020, 06:31 PM | #180 |
Newbie Join Date: Oct 2019 Location: FRANCE
Hello, I would like double deuce foam for my RC4WD 2.2 MTR GOODYEAR WRANGLER tires, my SCX10.2 weighs 10lbs, I only do rockcrawling, Only on your site even with the calculator I do not know if I have to take 5.5 or 6 because my tires are only 5.63 "x 2.04"? Thanks for your advices |
*_* C.I.'s Lil' Nova Closed Cell Competition Ready 1.9 Dual Stage Foams *_* - Similar Threads | ||||
Crawler Innovations Proto type 4.75 Dual Stage Lil' Nova Foams for Scale Crawlers | Nova's Ark | Tires and Wheels | 103 | 02-24-2020 01:01 PM |
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* | Nova's Ark | Crawler Innovations | 295 | 10-26-2018 10:55 AM |
*_* C.I.'s Super Nova Closed Cell Competition Ready Dual Stage Foams *_* | Nova's Ark | Crawler Innovations | 14 | 05-22-2014 06:13 PM |
Deuce Nova's and Lil Nova's Dual stage foams! | bigflex | Tires and Wheels | 6 | 10-06-2009 10:50 PM |
